Modify conductor¶
QElectrotech draws by default a conductor minimizing the horizontal and vertical lines. Changing the route of the conductor for a clear understanding of the schema is some times necessary. QElectroTech allows modifying the route.
Figure: QElectroTech modify conductor¶
To modify the route of a conductor:
Select the conductor which route should be modified.
Press on a control point, blue points, from the conductor selected.
Without releasing the control point, displace the control point horizontally or vertically until desired position.
