CustomElementPart Class Referenceabstract
The CustomElementPart class This abstract class represents a primitive of the visual representation of an electrical element. The Element, FixedElement and CustomElement classes do not embed its attributes and methods in order to remain lightweight; indeed, there is no point for those classes to store their visual representation with anything more complex than a QImage. More...
#include <customelementpart.h>
Inheritance diagram for CustomElementPart:
Collaboration diagram for CustomElementPart:
 CustomElementPart (QETElementEditor *editor)
 CustomElementPart Constructor.
virtual ~CustomElementPart ()
 ~CustomElementPart Destructor
virtual void fromXml (const QDomElement &)=0
virtual const QDomElement toXml (QDomDocument &) const =0
virtual void setProperty (const char *name, const QVariant &value)=0
virtual QVariant property (const char *name) const =0
virtual bool isUseless () const =0
virtual QRectF sceneGeometricRect () const =0
virtual void startUserTransformation (const QRectF &)=0
virtual void handleUserTransformation (const QRectF &, const QRectF &)=0
virtual void updateCurrentPartEditor () const
virtual QString name () const =0
virtual QString xmlName () const =0
virtual QGraphicsItem * toItem ()
virtual QET::ScalingMethod preferredScalingMethod () const
Protected Member Functions
QList< QPointF > mapPoints (const QRectF &, const QRectF &, const QList< QPointF > &)
 CustomElementPart (const CustomElementPart &)
QETElementEditor * element_editor
◆ CustomElementPart() [1/2]
CustomElementPart::CustomElementPart ( QETElementEditor * editor)
inline
editorElement editor this primitive is attached to
◆ ~CustomElementPart()
virtual CustomElementPart::~CustomElementPart ( )
inlinevirtual
◆ CustomElementPart() [2/2]
CustomElementPart::CustomElementPart ( const CustomElementPart & )
◆ elementEditor()
QETElementEditor * CustomElementPart::elementEditor ( ) const
virtual
a pointer to the parent element editor
le QETElementEditor auquel cet editeur appartient
◆ elementScene()
ElementScene * CustomElementPart::elementScene ( ) const
virtual
a pointer to the parent editing scene
l'ElementScene contenant les parties editees par cet editeur
◆ fromXml()
virtual void CustomElementPart::fromXml ( const QDomElement & )
pure virtual
Load the primitive from an XML element that describes it
Implemented in PartArc, PartDynamicTextField, PartEllipse, PartLine, PartPlcTable, PartPolygon, PartRectangle, PartTerminal, and PartText.
◆ handleUserTransformation()
virtual void CustomElementPart::handleUserTransformation ( const QRectF & ,
const QRectF &  )
pure virtual
Make this part fit into the provided rectangle.
Implemented in AbstractPartEllipse, PartDynamicTextField, PartLine, PartPlcTable, PartPolygon, PartRectangle, PartTerminal, and PartText.
◆ isUseless()
virtual bool CustomElementPart::isUseless ( ) const
pure virtual
whether the primitive appears to be useless (e.g. 0-length line) Typically, useless primitives are discarded when saving the element.
◆ mapPoints()
QList< QPointF > CustomElementPart::mapPoints ( const QRectF & initial_selection_rect,
const QRectF & new_selection_rect,
const QList< QPointF > & points )
protected
Helper method to map points in CustomElementPart::handleUserTransformation()
initial_selection_rectSelection rectangle when the movement started, in scene coordinates
new_selection_rectNew selection rectangle, in scene coordinates
pointsList of points when the movement started, in scene coordinates.
The list of points mapped from initial_selection_rect to new_selection_rect
◆ name()
virtual QString CustomElementPart::name ( ) const
pure virtual
the name of the primitive
◆ preferredScalingMethod()
QET::ScalingMethod CustomElementPart::preferredScalingMethod ( ) const
virtual
This method is called by the decorator when it needs to determine the best way to interactively scale a primitive. It is typically called when only a single primitive is being scaled. The default implementation systematically returns QET::SnapScalingPointToGrid
Reimplemented in PartPolygon.
◆ property()
virtual QVariant CustomElementPart::property ( const char * name) const
pure virtual
Get the current value of a specific primitive property
Implemented in CustomElementGraphicPart, PartDynamicTextField, and PartText.
◆ sceneGeometricRect()
virtual QRectF CustomElementPart::sceneGeometricRect ( ) const
pure virtual
◆ setProperty()
virtual void CustomElementPart::setProperty ( const char * name,
const QVariant & value )
pure virtual
Set a specific property of the primitive
◆ startUserTransformation()
virtual void CustomElementPart::startUserTransformation ( const QRectF & )
pure virtual
Inform this part a user-induced transformation is about to begin. This method can be used to save data required by handleUserTransformation().
◆ toItem()
QGraphicsItem * CustomElementPart::toItem ( )
virtual
this primitive as a QGraphicsItem
◆ toXml()
virtual const QDomElement CustomElementPart::toXml ( QDomDocument & ) const
pure virtual
Export the primitive as an XML element
◆ undoStack()
QUndoStack & CustomElementPart::undoStack ( ) const
virtual
the element editor undo stack
la QUndoStack a utiliser pour les annulations
◆ updateCurrentPartEditor()
void CustomElementPart::updateCurrentPartEditor ( ) const
virtual
Call the updateCurrentPartEditor() slot of the editor
See also
QETElementEditor::updateCurrentPartEditor()
Appelle le slot updateCurrentPartEditor de l'editeur
See also
◆ xmlName()
virtual QString CustomElementPart::xmlName ( ) const
pure virtual
the name that will be used as XML tag when exporting the primitive
◆ element_editor
QETElementEditor* CustomElementPart::element_editor
