ElementScene Class Reference
The ElementScene class This class is the canvas allowing the visual edition of an electrical element. It displays the various primitives composing the drawing of the element, the border due to its fixed size and its hotspot. More...
#include <elementscene.h>
Inherits QGraphicsScene.
Collaboration diagram for ElementScene:
Public Types
enum  Behavior { Normal , PasteArea , AddPart }
enum  ItemOption {
  SortByZValue = 1 , IncludeTerminals = 2 , IncludeHelperItems = 4 , Selected = 8 ,
  NonSelected = 16 , SelectedOrNot = 24
Public Slots
void slot_select (const ElementContent &)
 ElementScene::slot_select Select the item in content, every others items in the scene are deselected.
void slot_selectAll ()
 ElementScene::slot_selectAll Select all items.
void slot_deselectAll ()
 ElementScene::slot_deselectAll deselect all item.
void slot_invertSelection ()
 ElementScene::slot_invertSelection Inverse Selection.
void slot_delete ()
 ElementScene::slot_delete Delete selected items.
void slot_editNames ()
 ElementScene::slot_editNames Launch a dialog for edit the names of the edited element.
void slot_editAuthorInformations ()
 ElementScene::slot_editAuthorInformations Starts a dialog to edit the additional information of this element. Concretely, this free field is intended to receive information on the author of the element, its license, etc.
void slot_editProperties ()
 ElementScene::slot_editProperties Open dialog to edit the element properties.
void managePrimitivesGroups ()
 ElementScene::managePrimitivesGroups Ensure the decorator is adequately shown, hidden or updated so it always represents the current selection.
void stackAction (ElementEditionCommand *)
 ElementScene::stackAction Push the provided command on the undo stack.
Signals
void partsAdded ()
 Signal emitted after one or several parts were added.
void partsRemoved ()
 Signal emitted after one or several parts were removed.
void partsZValueChanged ()
 Signal emitted when the zValue of one or several parts change.
void pasteAreaDefined (const QRectF &)
 Signal emitted when users have defined the copy/paste area.
void needZoomFit ()
 Signal emitted when need zoomFit.
void elementInfoChanged ()
void elementTypeChanged ()
 Signal emitted when the element type changes.
void mouseMoved (const QPointF &pos)
 Signal emitted with the current cursor position (scene coordinates) on every mouse move.
 ElementScene (QETElementEditor *, QObject *=nullptr)
 ElementScene::ElementScene constructor.
 ~ElementScene () override
 ElementScene::~ElementScene.
ElementData elementData ()
 ElementScene::elementData.
void setElementData (ElementData data)
void setEventInterface (ESEventInterface *event_interface)
 ElementScene::setEventInterface Set a new event interface.
void clearEventInterface ()
 ElementScene::clearEventInterface Clear the current event interface.
void setBehavior (ElementScene::Behavior)
 ElementScene::setBehavior Modify the current behavior of this scene.
ElementScene::Behavior behavior () const
QPointF snapToGrid (QPointF point)
 ElementScene::snapToGrid Rounds the coordinates of the point passed as a parameter so that this point is aligned with the grid.
virtual int xGrid () const
 ElementScene::xGrid.
virtual int yGrid () const
 ElementScene::yGrid.
virtual void setGrid (int, int)
 ElementScene::setGrid.
virtual const QDomDocument toXml (bool=true)
 ElementScene::toXml Export this element as a xml file.
virtual QRectF boundingRectFromXml (const QDomDocument &)
 ElementScene::boundingRectFromXml.
virtual void fromXml (const QDomDocument &, const QPointF &=QPointF(), bool=true, ElementContent *=nullptr)
 ElementScene::fromXml Imports the element described in an XML document. If a position is specified, the imported elements are positioned in such a way that the upper left corner of the smallest rectangle that can surround them all (the bounding rect) either at this position.
virtual void reset ()
 ElementScene::reset Remove all QGraphicsItems in the scene and clear the undo stack.
virtual QList< CustomElementPart * > primitives () const
 ElementScene::primitives.
virtual QList< QGraphicsItem * > zItems (ItemOptions options=ItemOptions(SortByZValue|IncludeTerminals|SelectedOrNot)) const
 ElementScene::zItems.
virtual ElementContent selectedContent () const
 ElementScene::selectedContent.
virtual void getPasteArea (const QRectF &)
 ElementScene::getPasteArea.
QRectF elementSceneGeometricRect () const
 ElementScene::elementSceneGeometricRect.
bool containsTerminals () const
 ElementScene::containsTerminals.
QUndoStack & undoStack ()
 ElementScene::undoStack.
QGIManager & qgiManager ()
 ElementScene::qgiManager.
bool wasCopiedFromThisElement (const QString &)
 ElementScene::wasCopiedFromThisElement.
void cut ()
 ElementScene::cut Handles the fact of cutting the selection = exporting it in XML to the clipboard then deleting it.
void copy ()
 ElementScene::copy Handles the fact of copying the selection = exporting it as XML to the clipboard.
QETElementEditor * editor () const
 ElementScene::editor.
void addItems (QVector< QGraphicsItem * > items)
 ElementScene::addItems Add items to the scene and emit partsAdded. Prefer always use this method instead of QGraphicsScene::addItem even if you want to add one item, for gain the signal emission.
void removeItems (QVector< QGraphicsItem * > items)
 ElementScene::removeItems Remove items from the scene and emit partsRemoved. Prefer always use this method instead of QGraphicsScene::removeItem even if you want to remove one item, for gain the signal emission.
void setHotspotVisible (bool visible)
bool hotspotVisible () const
static bool clipboardMayContainElement ()
 ElementScene::clipboardMayContainElement.
Protected Member Functions
void mouseMoveEvent (QGraphicsSceneMouseEvent *) override
 ElementScene::mouseMoveEvent.
void mousePressEvent (QGraphicsSceneMouseEvent *) override
 ElementScene::mousePressEvent.
void mouseReleaseEvent (QGraphicsSceneMouseEvent *) override
 ElementScene::mouseReleaseEvent.
 ElementScene::mouseDoubleClickEvent.
void keyPressEvent (QKeyEvent *event) override
 ElementScene::keyPressEvent manage key press event.
void contextMenuEvent (QGraphicsSceneContextMenuEvent *event) override
 ElementScene::contextMenuEvent Display the context menu event, only if behavior are Normal.
void drawForeground (QPainter *, const QRectF &) override
 ElementScene::drawForeground Draws the background of the editor, ie the hotspot indicator.
 ElementScene (const ElementScene &)
QRectF elementContentBoundingRect (const ElementContent &) const
 ElementScene::elementContentBoundingRect.
ElementContent loadContent (const QDomDocument &)
 ElementScene::loadContent Create and load the content describe in the xml document.
ElementContent addContent (const ElementContent &)
 ElementScene::addContent Add content content to this element.
ElementContent addContentAtPos (const ElementContent &, const QPointF &)
 ElementScene::addContentAtPos Add content content to this element.
void addPrimitive (QGraphicsItem *)
 ElementScene::addPrimitive Add a primitive to the scene by wrapping it within an ElementPrimitiveDecorator group.
void initPasteArea ()
 ElementScene::initPasteArea Initializes the paste area.
void centerElementToOrigin ()
 ElementScene::centerElementToOrigin try to center better is possible the element to the scene.
static bool zValueLessThan (QGraphicsItem *, QGraphicsItem *)
 ElementScene::zValueLessThan.
ElementData m_element_data
QGIManager m_qgi_manager
 ElementData. Actually in transition with old data storage.
QUndoStack m_undo_stack
ESEventInterface * m_event_interface = nullptr
Behavior m_behavior
QETElementEditor * m_element_editor = nullptr
QGraphicsRectItem * m_paste_area
QRectF m_defined_paste_area
QString m_last_copied
ElementPrimitiveDecorator * m_decorator = nullptr
 Decorator item displayed when at least one item is selected.
int m_x_grid
int m_y_grid
QPointer< CustomElementGraphicPart > m_single_selected_item
bool m_hotspot_visible = true
QMutex * m_decorator_lock
Friends
class ChangePropertiesCommand
For add and remove item prefer use custom method addItems and removeItems instead of addItem and removeItem, because these methods emit signal partAdded and partRemoved.
◆ Behavior
Enumerator
Normal
PasteArea
AddPart
◆ ItemOption
Enumerator
SortByZValue
IncludeTerminals
IncludeHelperItems
Selected
NonSelected
SelectedOrNot
◆ ElementScene() [1/2]
ElementScene::ElementScene ( QETElementEditor * editor,
QObject * parent = nullptr )
editor: Element editor concerned
parent: Widget parent
◆ ~ElementScene()
ElementScene::~ElementScene ( )
◆ ElementScene() [2/2]
ElementScene::ElementScene ( const ElementScene & )
◆ addContent()
ElementContent ElementScene::addContent ( const ElementContent & content)
content: content (= list of parts) to load
Content adds
◆ addContentAtPos()
ElementContent ElementScene::addContentAtPos ( const ElementContent & content,
const QPointF & pos )
pos: Position of the upper left corner of the content after being added
Content adds
◆ addItems()
void ElementScene::addItems ( QVector< QGraphicsItem * > items)
items
◆ addPrimitive()
void ElementScene::addPrimitive ( QGraphicsItem * primitive)
primitive
◆ behavior()
ElementScene::Behavior ElementScene::behavior ( ) const
◆ boundingRectFromXml()
QRectF ElementScene::boundingRectFromXml ( const QDomDocument & xml_document)
virtual
xml_document: an XML document describing an element
the boundingRect of the element's content
◆ centerElementToOrigin()
void ElementScene::centerElementToOrigin ( )
◆ clearEventInterface()
void ElementScene::clearEventInterface ( )
◆ clipboardMayContainElement()
bool ElementScene::clipboardMayContainElement ( )
static
true if the clipboard appears to contain an element
◆ containsTerminals()
bool ElementScene::containsTerminals ( ) const
true if the element has at least one terminal, false if it has none.
◆ contextMenuEvent()
void ElementScene::contextMenuEvent ( QGraphicsSceneContextMenuEvent * event)
overrideprotected
event
◆ copy()
void ElementScene::copy ( )
◆ cut()
void ElementScene::cut ( )
◆ drawForeground()
void ElementScene::drawForeground ( QPainter * p,
const QRectF &  )
overrideprotected
p: The QPainter to use for drawing
◆ editor()
QETElementEditor * ElementScene::editor ( ) const
◆ elementContentBoundingRect()
QRectF ElementScene::elementContentBoundingRect ( const ElementContent & content) const
content: Content (= parts) of an element
the boundingRect of these parts, expressed in the coordinates of the scene
◆ elementData()
ElementData ElementScene::elementData ( )
the elementdata using by the scene
◆ elementInfoChanged
void ElementScene::elementInfoChanged ( )
signal
◆ elementSceneGeometricRect()
QRectF ElementScene::elementSceneGeometricRect ( ) const
the minimum, margin-less rectangle the element can fit into, in scene coordinates. It is different from itemsBoundingRect() because it is not supposed to imply any margin.
◆ elementTypeChanged
void ElementScene::elementTypeChanged ( )
signal
◆ fromXml()
void ElementScene::fromXml ( const QDomDocument & xml_document,
const QPointF & position = QPointF(),
bool consider_informations = true,
ElementContent * content_ptr = nullptr )
virtual
xml_document: an XML document describing the element
position: The position of the imported parts
consider_informations: If true, additional information (dimensions, hotspot, etc.) will be taken into account
content_ptr: if this pointer to an ElementContent is different from 0, it will be filled with the content added to the element by the fromXml
◆ getPasteArea()
void ElementScene::getPasteArea ( const QRectF & to_paste)
virtual
to_paste: Rectangle enclosing the parts to be glued
the rectangle where you will have to glue these parts
◆ hotspotVisible()
bool ElementScene::hotspotVisible ( ) const
inline
◆ initPasteArea()
void ElementScene::initPasteArea ( )
◆ keyPressEvent()
void ElementScene::keyPressEvent ( QKeyEvent * event)
overrideprotected
event
◆ loadContent()
ElementContent ElementScene::loadContent ( const QDomDocument & xml_document)
xml_document: xml dom document to analyze
the loaded content
◆ managePrimitivesGroups
void ElementScene::managePrimitivesGroups ( )
slot
◆ mouseDoubleClickEvent()
void ElementScene::mouseDoubleClickEvent ( QGraphicsSceneMouseEvent * event)
overrideprotected
event
◆ mouseMoved
void ElementScene::mouseMoved ( const QPointF & pos)
signal
◆ mouseMoveEvent()
void ElementScene::mouseMoveEvent ( QGraphicsSceneMouseEvent * e)
overrideprotected
e
◆ mousePressEvent()
void ElementScene::mousePressEvent ( QGraphicsSceneMouseEvent * e)
overrideprotected
e
◆ mouseReleaseEvent()
void ElementScene::mouseReleaseEvent ( QGraphicsSceneMouseEvent * e)
overrideprotected
e
◆ needZoomFit
void ElementScene::needZoomFit ( )
signal
◆ partsAdded
void ElementScene::partsAdded ( )
signal
◆ partsRemoved
void ElementScene::partsRemoved ( )
signal
◆ partsZValueChanged
void ElementScene::partsZValueChanged ( )
signal
◆ pasteAreaDefined
void ElementScene::pasteAreaDefined ( const QRectF & )
signal
◆ primitives()
QList< CustomElementPart * > ElementScene::primitives ( ) const
virtual
the list of primitives currently present on the scene.
◆ qgiManager()
QGIManager & ElementScene::qgiManager ( )
the QGraphicsItem manager of this item editor
◆ removeItems()
void ElementScene::removeItems ( QVector< QGraphicsItem * > items)
items
◆ reset()
void ElementScene::reset ( )
virtual
◆ selectedContent()
ElementContent ElementScene::selectedContent ( ) const
virtual
the selected graphic parts
◆ setBehavior()
void ElementScene::setBehavior ( ElementScene::Behavior b)
b
◆ setElementData()
void ElementScene::setElementData ( ElementData data)
◆ setEventInterface()
void ElementScene::setEventInterface ( ESEventInterface * event_interface)
event_interface
◆ setGrid()
void ElementScene::setGrid ( int x_g,
int y_g )
virtual
x_g: Horizontal grid size
y_g: Vertical grid size
◆ setHotspotVisible()
void ElementScene::setHotspotVisible ( bool visible)
inline
Whether drawForeground() draws the red hotspot cross. On by default (the normal editing view); turned off around a render() call meant to capture the element's actual content only, e.g. exporting to SVG – the cross is an editing aid, not part of the drawn symbol.
◆ slot_delete
void ElementScene::slot_delete ( )
slot
◆ slot_deselectAll
void ElementScene::slot_deselectAll ( )
slot
◆ slot_editAuthorInformations
void ElementScene::slot_editAuthorInformations ( )
slot
◆ slot_editNames
void ElementScene::slot_editNames ( )
slot
◆ slot_editProperties
void ElementScene::slot_editProperties ( )
slot
◆ slot_invertSelection
void ElementScene::slot_invertSelection ( )
slot
◆ slot_select
void ElementScene::slot_select ( const ElementContent & content)
slot
content
◆ slot_selectAll
void ElementScene::slot_selectAll ( )
slot
◆ snapToGrid()
QPointF ElementScene::snapToGrid ( QPointF point)
point: a reference to a QPointF. This object will be modified.
point
◆ stackAction
void ElementScene::stackAction ( ElementEditionCommand * command)
slot
command
◆ toXml()
const QDomDocument ElementScene::toXml ( bool all_parts = true)
virtual
all_parts: (true by default) if true, export the entire element in xml, if false, only export the selected parts.
an xml document that describe the element.
◆ undoStack()
QUndoStack & ElementScene::undoStack ( )
the undo stack of this element editor
◆ wasCopiedFromThisElement()
bool ElementScene::wasCopiedFromThisElement ( const QString & clipboard_content)
clipboard_content: character string, probably coming from the clipboard.
true if clipboard_content has been copied from this element.
◆ xGrid()
int ElementScene::xGrid ( ) const
virtual
the horizontal size of the grid
◆ yGrid()
int ElementScene::yGrid ( ) const
virtual
vertical grid size
◆ zItems()
QList< QGraphicsItem * > ElementScene::zItems ( ItemOptions options = ItemOptions(SortByZValue  | IncludeTerminals  | SelectedOrNot)) const
virtual
options
the parts of the element ordered by increasing zValue
◆ zValueLessThan()
bool ElementScene::zValueLessThan ( QGraphicsItem * item1,
QGraphicsItem * item2 )
staticprivate
item1: QGraphicsItem
item2: QGraphicsItem
true if item1's zValue() is less than item2's.
◆ ChangePropertiesCommand
friend class ChangePropertiesCommand
friend
◆ m_behavior
Behavior ElementScene::m_behavior
◆ m_decorator
ElementPrimitiveDecorator* ElementScene::m_decorator = nullptr
◆ m_decorator_lock
QMutex* ElementScene::m_decorator_lock
◆ m_defined_paste_area
QRectF ElementScene::m_defined_paste_area
◆ m_element_data
ElementData ElementScene::m_element_data
◆ m_element_editor
QETElementEditor* ElementScene::m_element_editor = nullptr
◆ m_event_interface
ESEventInterface* ElementScene::m_event_interface = nullptr
◆ m_hotspot_visible
bool ElementScene::m_hotspot_visible = true
◆ m_last_copied
QString ElementScene::m_last_copied
◆ m_paste_area
QGraphicsRectItem* ElementScene::m_paste_area
◆ m_qgi_manager
QGIManager ElementScene::m_qgi_manager
◆ m_single_selected_item
QPointer<CustomElementGraphicPart> ElementScene::m_single_selected_item
◆ m_undo_stack
QUndoStack ElementScene::m_undo_stack
◆ m_x_grid
int ElementScene::m_x_grid
◆ m_y_grid
int ElementScene::m_y_grid
