Element Class Reference
#include <element.h>
Inheritance diagram for Element:
Collaboration diagram for Element:
struct  LinkInfo
 The LinkInfo struct Stores link data for element connections. For slave elements, group_index indicates which contact group of the master this slave is assigned to (-1 = no group assigned). More...
Public Types
enum  kind {
  Simple = 1 , NextReport = 2 , PreviousReport = 4 , AllReport = 6 ,
  Master = 8 , Slave = 16 , Terminale = 32 , Thumbnail = 64 ,
  ConductorDefinition = 128
 The kind enum Used to know the kind of this element (master, slave, report ect...). More...
enum  { Type = UserType + 1000 }
Public Slots
void updateConductorTexts ()
 Element::updateConductorTexts Slot that is triggered when a cable is * connected to or disconnected from a terminal on this component.
Signals
void linkedElementChanged ()
void elementInfoChange (DiagramContext old_info, DiagramContext new_info)
void textAdded (DynamicElementTextItem *deti)
void textRemoved (DynamicElementTextItem *deti)
void textsGroupAdded (ElementTextItemGroup *group)
void textsGroupAboutToBeRemoved (ElementTextItemGroup *group)
void textAddedToGroup (DynamicElementTextItem *text, ElementTextItemGroup *group)
void textRemovedFromGroup (DynamicElementTextItem *text, ElementTextItemGroup *group)
 Element (const ElementsLocation &location, QGraphicsItem *=nullptr, int *state=nullptr, Element::kind link_type=Element::Simple)
 Element::Element.
 ~Element () override
 Element::~Element.
int type () const override
QList< Terminal * > terminals () const
 Element::terminals.
QList< Conductor * > conductors () const
 Element::conductors.
QList< QPair< Terminal *, Terminal * > > AlignedFreeTerminals () const
 Element::AlignedFreeTerminals.
DiagramContext elementInformations () const
virtual void setElementInformations (DiagramContext dc)
 Element::setElementInformations Set new information for this element. If new information is different of current infotmation emit elementInfoChange.
ElementData elementData () const
 Element::elementData.
void setElementData (ElementData data)
 Element::setElementData Set new data for this element. If m_information of data is changed, emit elementInfoChange.
DiagramContext kindInformations () const
 kindInformations
autonum::sequentialNumbers sequenceStruct () const
autonum::sequentialNumbers & rSequenceStruct ()
void setUpFormula (bool code_letter=true, QUndoCommand *parent_undo=nullptr)
 Element::setUpFormula Set up the formula used to create the label of this element.
void setPrefix (QString)
 Element::setPrefix set Element Prefix.
QString getPrefix () const
 Element::getPrefix get Element Prefix.
void freezeLabel (bool freeze)
 Element::freezeLabel Freeze this element label.
bool isFreezeLabel () const
void freezeNewAddedElement ()
 Element::freezeNewAddedElement Freeze this label if needed.
QString actualLabel ()
 Element::actualLabel Always return the current label to be displayed. This function is useful when label is based on formula, because label can change at any time.
 Element::name.
ElementsLocation location () const
virtual void setHighlighted (bool)
void displayHelpLine (bool b=true)
 Element::displayHelpLine Display the help line of each terminal if b is true.
QSize size () const
QPixmap pixmap ()
 Element::pixmap.
QPoint setHotspot (QPoint)
QPoint hotspot () const
void editProperty () override
virtual bool fromXml (QDomElement &, QHash< int, Terminal * > &)
 Element::fromXml Import the parameters of this element from a xml document. When call this function ensure this element is already in a scene, because the dynamic text item and element text item group (in the xml file) are created in this function and need a diagram for create their Xref, when this element is linked to another. If not the Xref can be not displayed, until the next call of update Xref of the group or text item.
virtual QDomElement toXml (QDomDocument &, QHash< Terminal *, int > &) const
 Element::toXml Allows to export the element in XML.
QUuid uuid () const
 Element::uuid.
int orientation () const
void addDynamicTextItem (DynamicElementTextItem *deti=nullptr)
 Element::addDynamiqueTextItem Add deti as a dynamic text item of this element, deti is reparented to this If deti is null, a new DynamicElementTextItem is created and added to this element.
void removeDynamicTextItem (DynamicElementTextItem *deti)
 Element::removeDynamicTextItem Remove deti, no matter if is a child of this element or a child of a group of this element. Set he parent item of deti to 0, deti is not deleted.
QList< DynamicElementTextItem * > dynamicTextItems () const
 Element::dynamicTextItems.
ElementTextItemGroup * addTextGroup (const QString &name)
 Element::addTextGroup Create and add an element text item group to this element. If this element already have a group with the same name, then name will renamed to name1 or name2 etc....
void addTextGroup (ElementTextItemGroup *group)
 Element::addTextGroup.
void removeTextGroup (ElementTextItemGroup *group)
 Element::removeTextGroup Remove the text group group from this element, and set the parent of group to 0. group is not deleted. All texts owned by the group will be reparented to this element.
ElementTextItemGroup * textGroup (const QString &name) const
 Element::textGroup.
QList< ElementTextItemGroup * > textGroups () const
 Element::textGroups.
bool addTextToGroup (DynamicElementTextItem *text, ElementTextItemGroup *group)
 Element::addTextToGroup Add the text text to the group group; If group isn't owned by this element return false. The text must be a text of this element.
bool removeTextFromGroup (DynamicElementTextItem *text, ElementTextItemGroup *group)
 Element::removeTextFromGroup Remove the text text from the group group, en reparent text to this element.
bool isFree () const
virtual void linkToElement (Element *)
virtual void unlinkAllElements ()
virtual void unlinkElement (Element *)
virtual void initLink (QETProject *)
 Element::initLink Initialise the link between this element and other elements. This method can be call once because init the link according to uuid store in a private list, after link, the list is clear, so call another time do nothing.
QList< Element * > linkedElements ()
 Element::linkedElements.
int groupIndexForElement (Element *elmt) const
 Element::groupIndexForElement Returns the group index assigned to the given linked element. For slave elements, this indicates which contact group of the master this slave is assigned to.
void setGroupIndexForElement (Element *elmt, int index)
 Element::setGroupIndexForElement Sets the group index for a linked element.
virtual kind linkType () const
 linkType use elementData function instead
QString linkTypeToString () const
 linkTypeToString use elementData function instead
void newUuid ()
void paint (QPainter *, const QStyleOptionGraphicsItem *, QWidget *) override
 Element::paint.
QList< QPointF > plcTablePositions () const
 Positions where the PLC IO table is drawn (from the .elmt file).
Public Member Functions inherited from QetGraphicsItem
 QetGraphicsItem (QGraphicsItem *parent=nullptr)
 ~QetGraphicsItem () override=0
Diagram * diagram () const
virtual void setPos (const QPointF &p)
virtual void setPos (qreal x, qreal y)
virtual bool isMovable () const
virtual void setMovable (bool movable)
bool isHovered () const
QPointF hoverMousePos () const
QET::GraphicsItemState state () const
 QetGraphicsItem::state.
static bool valideXml (QDomElement &)
Static Public Member Functions inherited from QetGraphicsItem
static void showItem (QetGraphicsItem *item)
 QetGraphicsItem::QetGraphicsItem Default constructor.
Protected Member Functions
void drawAxes (QPainter *, const QStyleOptionGraphicsItem *)
void setSize (int, int)
 Element::setSize Define the size of the element. The size must be a multiple of 10. If not, the dimensions indicated will be arrrondies to higher tens.
 Element::mouseMoveEvent.
 Element::mouseReleaseEvent.
void hoverEnterEvent (QGraphicsSceneHoverEvent *) override
void hoverLeaveEvent (QGraphicsSceneHoverEvent *) override
void drawPlcTable (QPainter *painter)
 Element::drawPlcTable Draw the PLC table directly from in-memory ElementData. This overlays the stale picture from the .elmt file with current data.
Protected Member Functions inherited from QetGraphicsItem
 QetGraphicsItem::mouseReleaseEvent handle mouse release click.
void hoverMoveEvent (QGraphicsSceneHoverEvent *event) override
Protected Attributes
QList< Element * > connected_elements
QList< LinkInfo > tmp_uuids_link
QHash< Element *, int > m_group_index_map
 Maps linked elements to their group index (for slave->master links).
QUuid m_uuid
kind m_link_type = Element::Simple
DiagramContext m_kind_informations
autonum::sequentialNumbers m_autoNum_seq
bool m_freeze_label = false
QString m_F_str
ElementsLocation m_location
QList< Terminal * > m_terminals
QPicture m_picture
QPicture m_low_zoom_picture
ElementData m_data
QList< QPointF > m_plc_table_positions
Protected Attributes inherited from QetGraphicsItem
bool is_movable_
bool m_first_move
bool snap_to_grid_
QPointF m_mouse_to_origin_movement
QET::GraphicsItemState m_state = QET:: GIOK
 Element (const Element &)
void drawHighlight (QPainter *, const QStyleOptionGraphicsItem *)
bool buildFromXml (const QDomElement &, int *=nullptr)
 Element::buildFromXml Build this element from an xml description.
bool parseElement (const QDomElement &dom)
 Element::parseElement Parse the element of the xml description of this element.
bool parseInput (const QDomElement &dom_element)
 Element::parseInput Parse the input (old text field) the parsed input are converted to dynamic text field, this function is only here to keep compatibility with old text.
DynamicElementTextItem * parseDynamicText (const QDomElement &dom_element)
 Element::parseDynamicText Create the dynamic text field described in dom_element.
Terminal * parseTerminal (const QDomElement &dom_element)
 Element::parseTerminal Parse partTerminal from xml structure.
bool m_must_highlight = false
QSize dimensions
QPoint hotspot_coord
bool m_mouse_over = false
QString m_prefix
QList< DynamicElementTextItem * > m_dynamic_text_list
QList< ElementTextItemGroup * > m_texts_group
Friends
class DiagramEventAddElement
class DynamicElementTextItem
This is the base class for electrical elements.
◆ anonymous enum
anonymous enum
Enable the use of qgraphicsitem_cast to safely cast a QGraphicsItem into an Element.
the QGraphicsItem type
Enumerator
Type
◆ kind
Enumerator
Simple
NextReport
PreviousReport
AllReport
Master
Slave
Terminale
Thumbnail
ConductorDefinition
◆ Element() [1/2]
Element::Element ( const ElementsLocation & location,
QGraphicsItem * parent = nullptr,
int * state = nullptr,
Element::kind link_type = Element::Simple )
Element::Element.
parent: parent graphics item
state: state of the instantiation
link_type
◆ ~Element()
Element::~Element ( )
◆ Element() [2/2]
Element::Element ( const Element & )
◆ actualLabel()
QString Element::actualLabel ( )
◆ addDynamicTextItem()
void Element::addDynamicTextItem ( DynamicElementTextItem * deti = nullptr)
deti
◆ addTextGroup() [1/2]
ElementTextItemGroup * Element::addTextGroup ( const QString & name)
name: the name of the group
the created group.
◆ addTextGroup() [2/2]
void Element::addTextGroup ( ElementTextItemGroup * group)
groupadd group to the group of this element. the group must not be owned by an element.
◆ addTextToGroup()
bool Element::addTextToGroup ( DynamicElementTextItem * text,
ElementTextItemGroup * group )
: true if the text was successfully added to the group.
◆ AlignedFreeTerminals()
QList< QPair< Terminal *, Terminal * > > Element::AlignedFreeTerminals ( ) const
a list of terminal (owned by this element) aligned to other terminal (from other element) The first Terminal of QPair is a Terminal owned by this element, this terminal haven't got any conductor docked. The second Terminal of QPair is a Terminal owned by an other element, which is aligned with the first Terminal. The second Terminal can have or not docked conductors.
◆ boundingRect()
QRectF Element::boundingRect ( ) const
Le rectangle delimitant le contour de l'element
◆ buildFromXml()
bool Element::buildFromXml ( const QDomElement & xml_def_elmt,
int * state = nullptr )
xml_def_elmt
stateOptional pointer which define the status of build 0 - evreything all right 4 - xml isn't a "definition" 5 - attribute of the definition isn't present or valid 6 - the definition is empty 7 - parsing of a xml node who describe a graphical part failed. 8 - No part of the drawing could be loaded
◆ conductors()
QList< Conductor * > Element::conductors ( ) const
The list of conductors docked to this element the list is sorted according to the position of the terminal where the conductor is docked from top to bottom, and left to right.
◆ displayHelpLine()
void Element::displayHelpLine ( bool b = true)
b
◆ drawAxes()
void Element::drawAxes ( QPainter * painter,
const QStyleOptionGraphicsItem * options )
protected
Dessine un petit repere (axes x et y) relatif a l'element
painterLe QPainter a utiliser pour dessiner les axes
optionsLes options de style a prendre en compte
◆ drawHighlight()
void Element::drawHighlight ( QPainter * painter,
Dessine le cadre de selection de l'element de maniere systematiquement non antialiasee.
painterLe QPainter a utiliser pour dessiner les bornes.
◆ drawPlcTable()
void Element::drawPlcTable ( QPainter * painter)
protected
◆ dynamicTextItems()
QList< DynamicElementTextItem * > Element::dynamicTextItems ( ) const
all dynamic text items of this element directly child of this element. Texts in text-groups belonging to this element are not returned by this function.
See also
ElementTextItemGroup::texts
◆ editProperty()
void Element::editProperty ( )
overridevirtual
Reimplemented from QetGraphicsItem.
◆ elementData()
ElementData Element::elementData ( ) const
the element data used by this element
◆ elementInfoChange
void Element::elementInfoChange ( DiagramContext old_info,
DiagramContext new_info )
signal
◆ elementInformations()
DiagramContext Element::elementInformations ( ) const
inline
◆ freezeLabel()
void Element::freezeLabel ( bool freeze)
◆ freezeNewAddedElement()
void Element::freezeNewAddedElement ( )
◆ fromXml()
bool Element::fromXml ( QDomElement & e,
QHash< int, Terminal * > & table_id_adr )
virtual
e: the dom element where the parameter is stored
table_id_adr: Reference to the mapping table between IDs of the XML file and the addresses in memory. If the import succeeds, it must be add the right couples (id, address).
◆ getPrefix()
QString Element::getPrefix ( ) const
◆ groupIndexForElement()
int Element::groupIndexForElement ( Element * elmt) const
elmtthe linked element to query
group index, or -1 if not assigned
◆ hotspot()
QPoint Element::hotspot ( ) const
Le hotspot courant de l'element
◆ hoverEnterEvent()
void Element::hoverEnterEvent ( QGraphicsSceneHoverEvent * e)
overrideprotected
When mouse over element change m_mouse_over to true (used in paint() function ) Also highlight linked elements
eQGraphicsSceneHoverEvent
◆ hoverLeaveEvent()
void Element::hoverLeaveEvent ( QGraphicsSceneHoverEvent * e)
overrideprotected
When mouse over element leave the position change m_mouse_over to false(used in paint() function ) Also un-highlight linked elements
◆ initLink()
void Element::initLink ( QETProject * prj)
virtual
prj: ownership project of this element and other element to be linked
Reimplemented in MasterElement, SimpleElement, and TerminalElement.
◆ isFree()
bool Element::isFree ( ) const
inline
◆ isFreezeLabel()
bool Element::isFreezeLabel ( ) const
inline
◆ kindInformations()
DiagramContext Element::kindInformations ( ) const
inline
kindInformations
Deprecated
◆ linkedElementChanged
void Element::linkedElementChanged ( )
signal
◆ linkedElements()
QList< Element * > Element::linkedElements ( )
inline
the list of linked elements, the list is sorted by position
◆ linkToElement()
virtual void Element::linkToElement ( Element * )
inlinevirtual
Reimplemented in MasterElement, ReportElement, and SlaveElement.
◆ linkType()
virtual kind Element::linkType ( ) const
inlinevirtual
◆ linkTypeToString()
QString Element::linkTypeToString ( ) const
Element::linkTypeToString.
Deprecated
use instead ElementData::typeToString
Todo
remove this function
◆ location()
ElementsLocation Element::location ( ) const
◆ mouseMoveEvent()
void Element::mouseMoveEvent ( QGraphicsSceneMouseEvent * event)
overrideprotected
event
◆ mouseReleaseEvent()
void Element::mouseReleaseEvent ( QGraphicsSceneMouseEvent * event)
overrideprotected
event
◆ name()
QString Element::name ( ) const
overridevirtual
Element::name.
the human name of this element
◆ newUuid()
void Element::newUuid ( )
inline
◆ orientation()
int Element::orientation ( ) const
inline
Indicate the current orientation of this element O = 0° 1 = 90° 2 = 180° 3 = 270°
◆ paint()
void Element::paint ( QPainter * painter,
const QStyleOptionGraphicsItem * options,
QWidget *  )
Element::paint.
painter
options
◆ parseDynamicText()
DynamicElementTextItem * Element::parseDynamicText ( const QDomElement & dom_element)
dom_element
◆ parseElement()
bool Element::parseElement ( const QDomElement & dom)
dom
◆ parseInput()
bool Element::parseInput ( const QDomElement & dom_element)
dom_element
◆ parseTerminal()
Terminal * Element::parseTerminal ( const QDomElement & dom_element)
dom_element
◆ pixmap()
QPixmap Element::pixmap ( )
Element::pixmap.
the pixmap of this element
◆ plcTablePositions()
QList< QPointF > Element::plcTablePositions ( ) const
inline
◆ removeDynamicTextItem()
void Element::removeDynamicTextItem ( DynamicElementTextItem * deti)
deti
◆ removeTextFromGroup()
bool Element::removeTextFromGroup ( DynamicElementTextItem * text,
true if text was successfully removed
◆ removeTextGroup()
void Element::removeTextGroup ( ElementTextItemGroup * group)
group
◆ rSequenceStruct()
autonum::sequentialNumbers & Element::rSequenceStruct ( )
inline
◆ sequenceStruct()
autonum::sequentialNumbers Element::sequenceStruct ( ) const
inline
◆ setElementData()
void Element::setElementData ( ElementData data)
data
◆ setElementInformations()
void Element::setElementInformations ( DiagramContext dc)
virtual
dc
◆ setGroupIndexForElement()
void Element::setGroupIndexForElement ( Element * elmt,
int index )
indexthe group index to assign
◆ setHighlighted()
void Element::setHighlighted ( bool hl)
virtual
hltrue pour mettre l'element en evidence, false sinon
◆ setHotspot()
QPoint Element::setHotspot ( QPoint hs)
Definit le hotspot de l'element par rapport au coin superieur gauche de son rectangle delimitant. Necessite que la taille ait deja ete definie
hsCoordonnees du hotspot
◆ setPrefix()
void Element::setPrefix ( QString prefix)
◆ setSize()
void Element::setSize ( int wid,
int hei )
protected
wid
hei
◆ setUpFormula()
void Element::setUpFormula ( bool code_letter = true,
QUndoCommand * parent_undo = nullptr )
code_letter: Q_UNUSED(code_letter) if true set tagged text to code letter (ex K for coil) with condition : formula is empty, text tagged "label" is emptty or "_";
◆ size()
QSize Element::size ( ) const
la taille de l'element sur le schema
◆ terminals()
QList< Terminal * > Element::terminals ( ) const
Element::terminals.
the list of terminals of this element.
◆ textAdded
void Element::textAdded ( DynamicElementTextItem * deti)
signal
◆ textAddedToGroup
void Element::textAddedToGroup ( DynamicElementTextItem * text,
signal
◆ textGroup()
ElementTextItemGroup * Element::textGroup ( const QString & name) const
Element::textGroup.
name
the text group named name or nullptr if this element haven't got a group with this name
◆ textGroups()
QList< ElementTextItemGroup * > Element::textGroups ( ) const
All texts groups of this element
◆ textRemoved
void Element::textRemoved ( DynamicElementTextItem * deti)
signal
◆ textRemovedFromGroup
void Element::textRemovedFromGroup ( DynamicElementTextItem * text,
signal
◆ textsGroupAboutToBeRemoved
void Element::textsGroupAboutToBeRemoved ( ElementTextItemGroup * group)
signal
◆ textsGroupAdded
void Element::textsGroupAdded ( ElementTextItemGroup * group)
signal
◆ toXml()
QDomElement Element::toXml ( QDomDocument & document,
QHash< Terminal *, int > & table_adr_id ) const
virtual
document: XML document to use
table_adr_id: Correspondence table between the addresses of the terminals and their id in the XML representation; this table completed by this method
The XML element representing this electrical element
◆ type()
int Element::type ( ) const
inlineoverride
◆ unlinkAllElements()
virtual void Element::unlinkAllElements ( )
inlinevirtual
◆ unlinkElement()
virtual void Element::unlinkElement ( Element * )
inlinevirtual
◆ updateConductorTexts
void Element::updateConductorTexts ( )
slot
◆ uuid()
QUuid Element::uuid ( ) const
inline
Element::uuid.
the uuid of this element
◆ valideXml()
bool Element::valideXml ( QDomElement & e)
static
Permet de savoir si un element XML (QDomElement) represente bien un element
eLe QDomElement a valide
true si l'element XML est un Element, false sinon
◆ DiagramEventAddElement
friend class DiagramEventAddElement
friend
◆ DynamicElementTextItem
friend class DynamicElementTextItem
friend
◆ connected_elements
QList<Element *> Element::connected_elements
protected
◆ dimensions
QSize Element::dimensions
◆ hotspot_coord
QPoint Element::hotspot_coord
◆ m_autoNum_seq
autonum::sequentialNumbers Element::m_autoNum_seq
protected
◆ m_data
ElementData Element::m_data
protected
◆ m_dynamic_text_list
QList<DynamicElementTextItem *> Element::m_dynamic_text_list
◆ m_F_str
QString Element::m_F_str
protected
◆ m_freeze_label
bool Element::m_freeze_label = false
protected
◆ m_group_index_map
QHash<Element *, int> Element::m_group_index_map
protected
◆ m_kind_informations
DiagramContext Element::m_kind_informations
protected
◆ m_link_type
kind Element::m_link_type = Element::Simple
protected
◆ m_location
ElementsLocation Element::m_location
protected
◆ m_low_zoom_picture
QPicture Element::m_low_zoom_picture
protected
◆ m_mouse_over
bool Element::m_mouse_over = false
◆ m_must_highlight
bool Element::m_must_highlight = false
◆ m_picture
QPicture Element::m_picture
protected
◆ m_plc_table_positions
QList<QPointF> Element::m_plc_table_positions
protected
◆ m_prefix
QString Element::m_prefix
◆ m_terminals
QList<Terminal *> Element::m_terminals
protected
◆ m_texts_group
QList<ElementTextItemGroup *> Element::m_texts_group
◆ m_uuid
QUuid Element::m_uuid
protected
◆ tmp_uuids_link
QList<LinkInfo> Element::tmp_uuids_link
protected
