SimpleElement Class Reference
The SimpleElement class this class represente a simple element with no specific attribute. More...
#include <simpleelement.h>
Inheritance diagram for SimpleElement:
Collaboration diagram for SimpleElement:
 SimpleElement (const ElementsLocation &, QGraphicsItem *=nullptr, int *=nullptr)
 SimpleElement::SimpleElement.
 ~SimpleElement () override
 SimpleElement::~SimpleElement.
void initLink (QETProject *project) override
 SimpleElement::initLink.
Public Member Functions inherited from Element
 Element (const ElementsLocation &location, QGraphicsItem *=nullptr, int *state=nullptr, Element::kind link_type=Element::Simple)
 Element::Element.
 ~Element () override
 Element::~Element.
int type () const override
QList< Terminal * > terminals () const
 Element::terminals.
QList< Conductor * > conductors () const
 Element::conductors.
QList< QPair< Terminal *, Terminal * > > AlignedFreeTerminals () const
 Element::AlignedFreeTerminals.
DiagramContext elementInformations () const
virtual void setElementInformations (DiagramContext dc)
 Element::setElementInformations Set new information for this element. If new information is different of current infotmation emit elementInfoChange.
ElementData elementData () const
 Element::elementData.
void setElementData (ElementData data)
 Element::setElementData Set new data for this element. If m_information of data is changed, emit elementInfoChange.
DiagramContext kindInformations () const
 kindInformations
autonum::sequentialNumbers sequenceStruct () const
autonum::sequentialNumbers & rSequenceStruct ()
void setUpFormula (bool code_letter=true, QUndoCommand *parent_undo=nullptr)
 Element::setUpFormula Set up the formula used to create the label of this element.
void setPrefix (QString)
 Element::setPrefix set Element Prefix.
QString getPrefix () const
 Element::getPrefix get Element Prefix.
void freezeLabel (bool freeze)
 Element::freezeLabel Freeze this element label.
bool isFreezeLabel () const
void freezeNewAddedElement ()
 Element::freezeNewAddedElement Freeze this label if needed.
QString actualLabel ()
 Element::actualLabel Always return the current label to be displayed. This function is useful when label is based on formula, because label can change at any time.
 Element::name.
ElementsLocation location () const
virtual void setHighlighted (bool)
void displayHelpLine (bool b=true)
 Element::displayHelpLine Display the help line of each terminal if b is true.
QSize size () const
QPixmap pixmap ()
 Element::pixmap.
QPoint setHotspot (QPoint)
QPoint hotspot () const
void editProperty () override
virtual bool fromXml (QDomElement &, QHash< int, Terminal * > &)
 Element::fromXml Import the parameters of this element from a xml document. When call this function ensure this element is already in a scene, because the dynamic text item and element text item group (in the xml file) are created in this function and need a diagram for create their Xref, when this element is linked to another. If not the Xref can be not displayed, until the next call of update Xref of the group or text item.
virtual QDomElement toXml (QDomDocument &, QHash< Terminal *, int > &) const
 Element::toXml Allows to export the element in XML.
QUuid uuid () const
 Element::uuid.
int orientation () const
void addDynamicTextItem (DynamicElementTextItem *deti=nullptr)
 Element::addDynamiqueTextItem Add deti as a dynamic text item of this element, deti is reparented to this If deti is null, a new DynamicElementTextItem is created and added to this element.
void removeDynamicTextItem (DynamicElementTextItem *deti)
 Element::removeDynamicTextItem Remove deti, no matter if is a child of this element or a child of a group of this element. Set he parent item of deti to 0, deti is not deleted.
QList< DynamicElementTextItem * > dynamicTextItems () const
 Element::dynamicTextItems.
ElementTextItemGroup * addTextGroup (const QString &name)
 Element::addTextGroup Create and add an element text item group to this element. If this element already have a group with the same name, then name will renamed to name1 or name2 etc....
void addTextGroup (ElementTextItemGroup *group)
 Element::addTextGroup.
void removeTextGroup (ElementTextItemGroup *group)
 Element::removeTextGroup Remove the text group group from this element, and set the parent of group to 0. group is not deleted. All texts owned by the group will be reparented to this element.
ElementTextItemGroup * textGroup (const QString &name) const
 Element::textGroup.
QList< ElementTextItemGroup * > textGroups () const
 Element::textGroups.
bool addTextToGroup (DynamicElementTextItem *text, ElementTextItemGroup *group)
 Element::addTextToGroup Add the text text to the group group; If group isn't owned by this element return false. The text must be a text of this element.
bool removeTextFromGroup (DynamicElementTextItem *text, ElementTextItemGroup *group)
 Element::removeTextFromGroup Remove the text text from the group group, en reparent text to this element.
bool isFree () const
virtual void linkToElement (Element *)
virtual void unlinkAllElements ()
virtual void unlinkElement (Element *)
QList< Element * > linkedElements ()
 Element::linkedElements.
int groupIndexForElement (Element *elmt) const
 Element::groupIndexForElement Returns the group index assigned to the given linked element. For slave elements, this indicates which contact group of the master this slave is assigned to.
void setGroupIndexForElement (Element *elmt, int index)
 Element::setGroupIndexForElement Sets the group index for a linked element.
virtual kind linkType () const
 linkType use elementData function instead
QString linkTypeToString () const
 linkTypeToString use elementData function instead
void newUuid ()
void paint (QPainter *, const QStyleOptionGraphicsItem *, QWidget *) override
 Element::paint.
QList< QPointF > plcTablePositions () const
 Positions where the PLC IO table is drawn (from the .elmt file).
Public Member Functions inherited from QetGraphicsItem
 QetGraphicsItem (QGraphicsItem *parent=nullptr)
 ~QetGraphicsItem () override=0
Diagram * diagram () const
virtual void setPos (const QPointF &p)
virtual void setPos (qreal x, qreal y)
virtual bool isMovable () const
virtual void setMovable (bool movable)
bool isHovered () const
QPointF hoverMousePos () const
QET::GraphicsItemState state () const
 QetGraphicsItem::state.
Additional Inherited Members
Public Types inherited from Element
enum  kind {
  Simple = 1 , NextReport = 2 , PreviousReport = 4 , AllReport = 6 ,
  Master = 8 , Slave = 16 , Terminale = 32 , Thumbnail = 64 ,
  ConductorDefinition = 128
 The kind enum Used to know the kind of this element (master, slave, report ect...). More...
enum  { Type = UserType + 1000 }
Public Slots inherited from Element
void updateConductorTexts ()
 Element::updateConductorTexts Slot that is triggered when a cable is * connected to or disconnected from a terminal on this component.
Signals inherited from Element
void linkedElementChanged ()
void elementInfoChange (DiagramContext old_info, DiagramContext new_info)
void textAdded (DynamicElementTextItem *deti)
void textRemoved (DynamicElementTextItem *deti)
void textsGroupAdded (ElementTextItemGroup *group)
void textsGroupAboutToBeRemoved (ElementTextItemGroup *group)
void textAddedToGroup (DynamicElementTextItem *text, ElementTextItemGroup *group)
void textRemovedFromGroup (DynamicElementTextItem *text, ElementTextItemGroup *group)
Static Public Member Functions inherited from Element
static bool valideXml (QDomElement &)
Static Public Member Functions inherited from QetGraphicsItem
static void showItem (QetGraphicsItem *item)
 QetGraphicsItem::QetGraphicsItem Default constructor.
Protected Member Functions inherited from Element
void drawAxes (QPainter *, const QStyleOptionGraphicsItem *)
void setSize (int, int)
 Element::setSize Define the size of the element. The size must be a multiple of 10. If not, the dimensions indicated will be arrrondies to higher tens.
 Element::mouseMoveEvent.
 Element::mouseReleaseEvent.
void hoverEnterEvent (QGraphicsSceneHoverEvent *) override
void hoverLeaveEvent (QGraphicsSceneHoverEvent *) override
void drawPlcTable (QPainter *painter)
 Element::drawPlcTable Draw the PLC table directly from in-memory ElementData. This overlays the stale picture from the .elmt file with current data.
Protected Member Functions inherited from QetGraphicsItem
 QetGraphicsItem::mouseReleaseEvent handle mouse release click.
void hoverMoveEvent (QGraphicsSceneHoverEvent *event) override
Protected Attributes inherited from Element
QList< Element * > connected_elements
QList< LinkInfo > tmp_uuids_link
QHash< Element *, int > m_group_index_map
 Maps linked elements to their group index (for slave->master links).
QUuid m_uuid
kind m_link_type = Element::Simple
DiagramContext m_kind_informations
autonum::sequentialNumbers m_autoNum_seq
bool m_freeze_label = false
QString m_F_str
ElementsLocation m_location
QList< Terminal * > m_terminals
QPicture m_picture
QPicture m_low_zoom_picture
ElementData m_data
QList< QPointF > m_plc_table_positions
Protected Attributes inherited from QetGraphicsItem
bool is_movable_
bool m_first_move
bool snap_to_grid_
QPointF m_mouse_to_origin_movement
QET::GraphicsItemState m_state = QET:: GIOK
◆ SimpleElement()
SimpleElement::SimpleElement ( const ElementsLocation & location,
QGraphicsItem * qgi = nullptr,
int * state = nullptr )
explicit
location
qgi
state
◆ ~SimpleElement()
SimpleElement::~SimpleElement ( )
◆ initLink()
void SimpleElement::initLink ( QETProject * project)
overridevirtual
projectCall init Link from custom element and after call update label for setup it.
Reimplemented from Element.
