Terminal Class Reference
The Terminal class This class represents a terminal of an electrical element, i.e. a possible plug point for conductors. This class handles all mouse events for connecting conductors. More...
#include <terminal.h>
Inherits QGraphicsObject.
Collaboration diagram for Terminal:
Public Types
enum  { Type = UserType + 1002 }
Signals
void conductorWasAdded (Conductor *conductor)
void conductorWasRemoved (Conductor *conductor)
 Terminal (TerminalData *data, Element *e=nullptr)
 ~Terminal () override
 Terminal::~Terminal Destruction of the terminal, and also docked conductor.
int type () const override
 type Enable the use of qgraphicsitem_cast to safely cast a QGraphicsItem into a Terminal
void paint (QPainter *painter, const QStyleOptionGraphicsItem *, QWidget *) override
 Terminal::paint Fonction de dessin des bornes.
void drawHelpLine (bool draw=true)
 Terminal::drawHelpLine.
QLineF HelpLine () const
 Terminal::HelpLine.
 Terminal::boundingRect.
Terminal * alignedWithTerminal () const
 Terminal::alignedWithTerminal If this terminal is aligned with an other terminal and is orientation is opposed return the other terminal else return nullptr.
bool addConductor (Conductor *conductor)
 Terminal::addConductor Add a conductor to this terminal.
void removeConductor (Conductor *conductor)
 Terminal::removeConductor Remove a conductor from this terminal.
int conductorsCount () const
 Terminal::conductorsCount.
Diagram * diagram () const
 Terminal::diagram.
Element * parentElement () const
 Terminal::parentElement.
QUuid uuid () const
QUuid stableUuid () const
 Terminal::stableUuid An identity for this terminal that exists on every element, not only on those saved by a uuid-aware element editor.
QString name () const
QString baseName () const
 Terminal::baseName Return the original terminal name (T1, T2...) without master label override. Used for sorting when linking.
TerminalData::Type terminalType () const
 Terminal::terminalType.
bool useMasterLabel () const
void setUseMasterLabel (bool use)
 Terminal::setUseMasterLabel Set whether this terminal uses a label from the master's contact group.
int masterLabelIndex () const
void setMasterLabelIndex (int index)
 Terminal::setMasterLabelIndex Set the index into the master's contact group labels.
QList< Conductor * > conductors () const
 Terminal::conductors.
Qet::Orientation orientation () const
QPointF dockConductor () const
 Terminal::dockConductor.
void updateConductor ()
 Terminal::updateConductor Update the path of conductor docked to this terminal.
bool isLinkedTo (Terminal *)
 Terminal::isLinkedTo.
bool canBeLinkedTo (Terminal *)
 Terminal::canBeLinkedTo Checking if the terminal can be linked to other_terminal or not Reasons for not linable:
bool fromXml (QDomElement &)
 Terminal::fromXml Enables you to find out whether an XML element represents this terminal. Warning, the XML element is not checked Permet de savoir si un element XML represente cette borne. Attention, l'element XML n'est pas verifie.
QDomElement toXml (QDomDocument &) const
 Terminal::toXml Methode d'export en XML.
static bool valideXml (QDomElement &)
 Terminal::valideXml Permet de savoir si un element XML represente une borne.
Public Attributes
QPointF dock_elmt_
 docking point for parent element
Static Public Attributes
static const qreal terminalSize = 4.0
static const qreal Z = 1000
static QColor neutralColor = QColor(Qt::blue)
 default color
static QColor allowedColor = QColor(Qt::darkGreen)
 color for legal actions
static QColor warningColor = QColor("#ff8000")
 color for allowed but fuzzy or not recommended actions
static QColor forbiddenColor = QColor(Qt::red)
 color for forbidden actions
Protected Member Functions
void hoverEnterEvent (QGraphicsSceneHoverEvent *) override
 Terminal::hoverEnterEvent Gere l'entree de la souris sur la zone de la Borne.
void hoverMoveEvent (QGraphicsSceneHoverEvent *) override
 Terminal::hoverMoveEvent Gere les mouvements de la souris sur la zone de la Borne.
void hoverLeaveEvent (QGraphicsSceneHoverEvent *) override
 Terminal::hoverLeaveEvent Gere le fait que la souris sorte de la zone de la Borne.
void mousePressEvent (QGraphicsSceneMouseEvent *) override
 Terminal::mousePressEvent Gere le fait qu'on enfonce un bouton de la souris sur la Borne.
void mouseMoveEvent (QGraphicsSceneMouseEvent *) override
 Terminal::mouseMoveEvent Gere le fait qu'on bouge la souris sur la Borne.
void mouseReleaseEvent (QGraphicsSceneMouseEvent *) override
 Terminal::mouseReleaseEvent.
 Terminal (const Terminal &)
void init ()
 Terminal::init Methode privee pour initialiser la borne. Private method to initialize the terminal.
void init (QPointF pf, Qet::Orientation o)
bool m_draw_help_line {false}
QGraphicsLineItem * m_help_line {nullptr}
QGraphicsLineItem * m_help_line_a {nullptr}
TerminalData * d
Element * parent_element_ {nullptr}
 Parent electrical element.
QList< Conductor * > m_conductors_list
 List of conductors attached to the terminal.
QRectF m_br
Terminal * m_previous_terminal = nullptr
 Last terminal seen through an attached conductor.
bool m_hovered = false
 Whether the mouse pointer is hovering the terminal.
QColor m_hovered_color = Terminal::neutralColor
 Color used for the hover effect.
◆ anonymous enum
anonymous enum
Enumerator
Type
◆ Terminal() [1/2]
Terminal::Terminal ( TerminalData * data,
Element * e = nullptr )
◆ ~Terminal()
Terminal::~Terminal ( )
◆ Terminal() [2/2]
Terminal::Terminal ( const Terminal & )
◆ addConductor()
bool Terminal::addConductor ( Conductor * conductor)
conductor: the conductor to add.
true if the conductor was successfully added
◆ alignedWithTerminal()
Terminal * Terminal::alignedWithTerminal ( ) const
◆ baseName()
QString Terminal::baseName ( ) const
◆ boundingRect()
QRectF Terminal::boundingRect ( ) const
Le rectangle (en precision flottante) delimitant la borne et ses alentours.
◆ canBeLinkedTo()
bool Terminal::canBeLinkedTo ( Terminal * other_terminal)
  • other_terminal is this terminal
  • this terminal is already connected to other_terminal
    other_terminal
    true if this terminal can be linked to other_terminal, otherwise false
◆ conductors()
QList< Conductor * > Terminal::conductors ( ) const
La liste des conducteurs lies a cette borne
◆ conductorsCount()
int Terminal::conductorsCount ( ) const
inline
the number of conductors attached to the terminal.
◆ conductorWasAdded
void Terminal::conductorWasAdded ( Conductor * conductor)
signal
◆ conductorWasRemoved
void Terminal::conductorWasRemoved ( Conductor * conductor)
signal
◆ diagram()
Diagram * Terminal::diagram ( ) const
Terminal::diagram.
le Diagram auquel cette borne appartient, ou 0 si cette borne est independant
◆ dockConductor()
QPointF Terminal::dockConductor ( ) const
the position, relative to the scene, of the docking point for conductors.
◆ drawHelpLine()
void Terminal::drawHelpLine ( bool draw = true)
draw: true, display the help line false, hide it.
◆ fromXml()
bool Terminal::fromXml ( QDomElement & terminal)
terminalLe QDomElement a analyser / QDomElement to check
true si la borne "se reconnait" (memes coordonnes, meme orientation), false sinon true, if the terminal ‘recognises’ itself (same coordinates, same orientation), false otherwise
◆ HelpLine()
QLineF Terminal::HelpLine ( ) const
Terminal::HelpLine.
a line with coordinate P1 the dock point of conductor and P2 the border of diagram, according to the orientation of terminal The line is in scene coordinate;
◆ hoverEnterEvent()
void Terminal::hoverEnterEvent ( QGraphicsSceneHoverEvent * )
overrideprotected
◆ hoverLeaveEvent()
void Terminal::hoverLeaveEvent ( QGraphicsSceneHoverEvent * )
overrideprotected
◆ hoverMoveEvent()
void Terminal::hoverMoveEvent ( QGraphicsSceneHoverEvent * )
overrideprotected
◆ init() [1/2]
void Terminal::init ( )
numberof terminal
nameof terminal
hiddenName
◆ init() [2/2]
void Terminal::init ( QPointF pf,
Qet::Orientation o )
◆ isLinkedTo()
bool Terminal::isLinkedTo ( Terminal * other_terminal)
other_terminalAutre borne
true si cette borne est reliee a other_terminal, false sion
◆ masterLabelIndex()
int Terminal::masterLabelIndex ( ) const
inline
◆ mouseMoveEvent()
void Terminal::mouseMoveEvent ( QGraphicsSceneMouseEvent * e)
overrideprotected
eL'evenement souris correspondant
◆ mousePressEvent()
void Terminal::mousePressEvent ( QGraphicsSceneMouseEvent * e)
overrideprotected
◆ mouseReleaseEvent()
void Terminal::mouseReleaseEvent ( QGraphicsSceneMouseEvent * e)
overrideprotected
e
◆ name()
QString Terminal::name ( ) const
◆ orientation()
Qet::Orientation Terminal::orientation ( ) const
Permet de connaitre l'orientation de la borne. Si le parent de la borne est bien un Element, cette fonction renvoie l'orientation par rapport a la scene de la borne, en tenant compte du fait que l'element ait pu etre pivote. Sinon elle renvoie son sens normal. Used to find out the orientation of the terminal. If the terminal's parent is in fact an Element, this function returns the orientation of the terminal with respect to the scene, taking into account the angle of rotation. scene, taking into account the fact that the element may have been rotated. Otherwise it returns its normal direction.
L'orientation actuelle de la Terminal.
◆ paint()
void Terminal::paint ( QPainter * painter,
const QStyleOptionGraphicsItem * options,
QWidget *  )
painterLe QPainter a utiliser
optionsLes options de dessin
◆ parentElement()
Element * Terminal::parentElement ( ) const
L'element auquel cette borne est rattachee
◆ removeConductor()
void Terminal::removeConductor ( Conductor * conductor)
conductor: conductor to remove
◆ setMasterLabelIndex()
void Terminal::setMasterLabelIndex ( int index)
indexthe label index (0-based)
◆ setUseMasterLabel()
void Terminal::setUseMasterLabel ( bool use)
usetrue to use master label
◆ stableUuid()
QUuid Terminal::stableUuid ( ) const
uuid() comes from the catalog .elmt definition and is empty for every element authored before that field existed – which is most of the installed base. Anything keyed on uuid() alone therefore cannot see those elements at all.
When there is no uuid, derive one from the terminal's local position and orientation inside its element. That is not an arbitrary choice: it is the same thing the project format itself uses to match a conductor back to a terminal ("each connection is made by using the local position of the terminal and a dynamic id" – TerminalData::m_uuid). m_pos is the position read from the definition and is not touched by moving the element on the folio, so the result is stable across loads, saves and folio moves, and it is unique within an element except where a definition genuinely declares two terminals at the same point – three cases in the whole example corpus, and harmless, because two terminals sharing a position and orientation are indistinguishable in every observable respect: they merge to one terminal row and every conductor on either of them still resolves to the right element and name.
Derived values are UUID v5 in a fixed namespace, so they are reproducible without being written to the file, and cannot collide with the v4 uuids the element editor generates.
the terminal's own uuid when it has one, otherwise a derived one
◆ terminalType()
TerminalData::Type Terminal::terminalType ( ) const
the type of this terminal (Generic, Inner, Outer, No, Nc, Common)
◆ toXml()
QDomElement Terminal::toXml ( QDomDocument & doc) const
docLe Document XML a utiliser pour creer l'element XML
un QDomElement representant cette borne
◆ type()
int Terminal::type ( ) const
inlineoverride
the QGraphicsItem type
◆ updateConductor()
void Terminal::updateConductor ( )
◆ useMasterLabel()
bool Terminal::useMasterLabel ( ) const
inline
◆ uuid()
QUuid Terminal::uuid ( ) const
◆ valideXml()
bool Terminal::valideXml ( QDomElement & terminal)
static
true si le QDomElement passe en parametre est une borne, false sinon
◆ allowedColor
QColor Terminal::allowedColor = QColor(Qt::darkGreen)
static
◆ d
TerminalData* Terminal::d
◆ dock_elmt_
QPointF Terminal::dock_elmt_
◆ forbiddenColor
QColor Terminal::forbiddenColor = QColor(Qt::red)
static
◆ m_br
QRectF Terminal::m_br
◆ m_conductors_list
QList<Conductor *> Terminal::m_conductors_list
◆ m_draw_help_line
bool Terminal::m_draw_help_line {false}
◆ m_help_line
QGraphicsLineItem* Terminal::m_help_line {nullptr}
◆ m_help_line_a
QGraphicsLineItem* Terminal::m_help_line_a {nullptr}
◆ m_hovered
bool Terminal::m_hovered = false
◆ m_hovered_color
QColor Terminal::m_hovered_color = Terminal::neutralColor
◆ m_previous_terminal
Terminal* Terminal::m_previous_terminal = nullptr
◆ neutralColor
QColor Terminal::neutralColor = QColor(Qt::blue)
static
default color
◆ parent_element_
Element* Terminal::parent_element_ {nullptr}
◆ terminalSize
const qreal Terminal::terminalSize = 4.0
static
◆ warningColor
QColor Terminal::warningColor = QColor("#ff8000")
static
◆ Z
const qreal Terminal::Z = 1000
static
