DynamicElementTextItem Class Reference
The DynamicElementTextItem class This class provide a simple text field of element who can be added or removed directly from the diagram editor. This text is created to compensate a big lack of the ElementTextItem : ElementTextItem can't be added or removed directly in the diagram editor. More...
#include <dynamicelementtextitem.h>
Inheritance diagram for DynamicElementTextItem:
Collaboration diagram for DynamicElementTextItem:
Public Types
enum  TextFrom { UserText , ElementInfo , CompositeText }
enum  { Type = UserType + 1010 }
Public Types inherited from DiagramTextItem
enum  { Type = UserType + 1004 }
Signals
void textChanged (QString text)
void textFromChanged (DynamicElementTextItem::TextFrom text_from)
void infoNameChanged (QString info)
void compositeTextChanged (QString text)
void frameChanged (bool frame)
void plainTextChanged ()
void textWidthChanged (qreal width)
void keepVisualRotationChanged (bool keep)
void rotationPointCenterChanged (bool center)
Signals inherited from DiagramTextItem
void colorChanged (QColor color)
void alignmentChanged (Qt::Alignment alignment)
void textEdited (const QString &old_str, const QString &new_str)
void fontChanged (QFont font)
int type () const override
 DynamicElementTextItem (Element *parent_element)
 DynamicElementTextItem::DynamicElementTextItem Constructor.
 ~DynamicElementTextItem () override
QDomElement toXml (QDomDocument &dom_doc) const override
 DynamicElementTextItem::toXml Export this text to xml.
void fromXml (const QDomElement &dom_elmt) override
 DynamicElementTextItem::fromXml Import this text from xml.
Element * parentElement () const
 DynamicElementTextItem::ParentElement.
QGraphicsTextItem * slaveXrefItem () const
 PDF export: slave cross-reference text item ("(folio-pos)") and its master target.
CrossRefItem * masterXrefItem () const
Element * masterElement () const
 DynamicElementTextItem::masterElement.
ElementTextItemGroup * parentGroup () const
 DynamicElementTextItem::parentGroup.
Element * elementUseForInfo () const
 DynamicElementTextItem::elementUseForInfo.
void refreshLabelConnection ()
 DynamicElementTextItem::refreshLabelConnection Refresh the connection of this text when the source of text is label, or composite text, with a variable %{label}.
DynamicElementTextItem::TextFrom textFrom () const
 DynamicElementTextItem::textFrom.
void setTextFrom (DynamicElementTextItem::TextFrom text_from)
 DynamicElementTextItem::setTextFrom Set the final text is created from.
QString text () const
 DynamicElementTextItem::text.
void setText (const QString &text)
 DynamicElementTextItem::setText Set the text of this text.
void setInfoName (const QString &info_name)
 DynamicElementTextItem::setInfoName Set the information name of the parent element.
QString infoName () const
 DynamicElementTextItem::infoName.
void setCompositeText (const QString &text)
 DynamicElementTextItem::setCompositeText Set the composite text of this text item to text.
QString compositeText () const
 DynamicElementTextItem::compositeText.
void setFrame (const bool frame)
bool frame () const
QUuid uuid () const
void updateXref ()
 DynamicElementTextItem::updateXref Create or delete the Xref according to the current properties of the project.
void setPlainText (const QString &text)
void setTextWidth (qreal width)
void setXref_item (Qt::AlignmentFlag m_exHrefPos, int slave_offset=0)
void setKeepVisualRotation (bool set)
bool keepVisualRotation () const
void setRotationPointCenter (bool set)
bool rotationPointCenter () const
Public Member Functions inherited from DiagramTextItem
 DiagramTextItem (QGraphicsItem *=nullptr)
 DiagramTextItem::DiagramTextItem.
 DiagramTextItem (const QString &, QGraphicsItem *=nullptr)
Diagram * diagram () const
 DiagramTextItem::diagram.
void edit ()
 Edit the text with HtmlEditor.
QPointF mapMovementToScene (const QPointF &) const
QPointF mapMovementFromScene (const QPointF &) const
QPointF mapMovementToParent (const QPointF &) const
QPointF mapMovementFromParent (const QPointF &) const
void setFont (const QFont &font)
void setColor (const QColor &color)
QColor color () const
void setNoEditable (bool e=true)
void setAlignment (const Qt::Alignment &alignment)
Qt::Alignment alignment () const
QRectF frameRect () const
 DiagramTextItem::frameRect.
void setHtml (const QString &text)
bool isHtml () const
static QMetaEnum textFromMetaEnum ()
 DynamicElementTextItem::textFromMetaEnum.
static QString xmlTagName ()
Protected Member Functions
 DynamicElementTextItem::mousePressEvent.
 DynamicElementTextItem::mouseMoveEvent.
 DynamicElementTextItem::mouseReleaseEvent.
 DynamicElementTextItem::mouseDoubleClickEvent Reimplemented functions, for add extra feature when this text is owned by a slave. In this case if the parent slave element is linked to a master, and this text display the label of the master (both if the 'text from' is 'element info' or 'composite text') the QGraphicsView go to master and select it.
 DynamicElementTextItem::hoverEnterEvent If the parent element of this text is a folio report or a slave element, the element is linked and the text display the variable "label" we set the text blue for signal the user that the text act like a link when we double click on.
 DynamicElementTextItem::hoverLeaveEvent.
void paint (QPainter *painter, const QStyleOptionGraphicsItem *option, QWidget *widget) override
QVariant itemChange (GraphicsItemChange change, const QVariant &value) override
bool sceneEventFilter (QGraphicsItem *watched, QEvent *event) override
Protected Member Functions inherited from DiagramTextItem
void paint (QPainter *, const QStyleOptionGraphicsItem *, QWidget *) override
 DiagramTextItem::paint Draw this text field. This method draws the text by calling QGraphicsTextItem::paint. If text is hovered, this method draws the bounding rect in grey.
void focusInEvent (QFocusEvent *) override
 DiagramTextItem::focusInEvent.
void focusOutEvent (QFocusEvent *) override
 DiagramTextItem::focusOutEvent.
 DiagramTextItem::mousePressEvent.
 DiagramTextItem::mouseMoveEvent.
 DiagramTextItem::mouseReleaseEvent.
void hoverEnterEvent (QGraphicsSceneHoverEvent *) override
void hoverLeaveEvent (QGraphicsSceneHoverEvent *) override
void hoverMoveEvent (QGraphicsSceneHoverEvent *) override
virtual void applyRotation (const qreal &)
void prepareAlignment ()
 DiagramTextItem::prepareAlignment Call this function before changing the bounding rect of this text.
void finishAlignment ()
 DiagramTextItem::finishAlignment Call this function after changing the bounding rect of this text to set the position of this text according to the alignment property.
Properties
QString text
TextFrom textFrom
QString infoName
bool frame
qreal textWidth
Properties inherited from DiagramTextItem
QColor color
QString plainText
QFont font
 DynamicElementTextItem (const DynamicElementTextItem &)
void elementInfoChanged ()
void masterChanged ()
 DynamicElementTextItem::masterChanged This function is only use when the parent element is a slave. Call when the master element linked to the parent slave element of this text change.
void reportChanged ()
 DynamicElementTextItem::reportChanged This function is only use when parent element of this text is a folio report The linked report of the parent element was changed.
void reportFormulaChanged ()
 DynamicElementTextItem::reportFormulaChanged The report formula use in the project was changed.
void setConnectionForReportFormula (const QString &formula)
void removeConnectionForReportFormula (const QString &formula)
void setupFormulaConnection ()
 DynamicElementTextItem::setupFormulaConnection Setup the required connection for the formula of the label.
void clearFormulaConnection ()
void updateReportFormulaConnection ()
void updateReportText ()
 DynamicElementTextItem::updateReportText This function is only use when this text is owned by a report, and this text have for info the Label.
void updateLabel ()
 DynamicElementTextItem::updateLabel Update the displayed text, when this dynamic text is based on the label of the parent element. This function is notably use when the label itself is based from a formula. If this dynamic text isn't based on label, this function do nothing.
void conductorWasAdded (Conductor *conductor)
 DynamicElementTextItem::conductorWasAdded Function only use when parent element is a folio report.
void conductorWasRemoved (Conductor *conductor)
 DynamicElementTextItem::conductorWasRemoved Function only use when parent element is a folio report.
void setPotentialConductor ()
 DynamicElementTextItem::setPotentialConductor This function is only used when the parent element of this text is a report element Get a conductor in the potential of the parent report.
void conductorPropertiesChanged ()
 DynamicElementTextItem::conductorPropertiesChanged This function is only used when the parent element of this text is a report element.
QString reportReplacedCompositeText () const
 DynamicElementTextItem::reportReplacedCompositeText This function is only used when the parent element of this text is a report element.
void zoomToLinkedElement ()
 DynamicElementTextItem::zoomToLinkedElement If the parent element is a folio report or a slave element, and is linked, zoom to the linked element.
void parentElementRotationChanged ()
 DynamicElementTextItem::parentElementRotationChanged Called when the parent element is rotated.
void thisRotationChanged ()
 DynamicElementTextItem::thisRotationChanged This function is called when user change the rotation of the text and "keep visual rotation" is to true to keep in memory the visual rotation wanted by the user.
QPointer< Element > m_parent_element
QPointer< Element > m_master_element
QPointer< Element > m_other_report
QPointer< Conductor > m_watched_conductor
QString m_text
QString m_info_name
QString m_composite_text
QString m_report_formula
QString m_F_str
DynamicElementTextItem::TextFrom m_text_from = UserText
QUuid m_uuid
QMetaObject::Connection m_report_formula_con
QList< QMetaObject::Connection > m_formula_connection
QList< QMetaObject::Connection > m_update_slave_Xref_connection
QColor m_user_color
bool m_frame = false
bool m_first_scene_change = true
CrossRefItem * m_Xref_item = nullptr
QGraphicsTextItem * m_slave_Xref_item = nullptr
qreal m_text_width = -1
QPointF m_initial_position
bool m_keep_visual_rotation = true
bool m_rotation_point_center = false
qreal m_visual_rotation_ref = 0
bool m_move_parent = true
Friends
class DynamicTextItemDelegate
class CompositeTextEditDialog
class Element
Additional Inherited Members
Public Attributes inherited from DiagramTextItem
bool m_block_alignment = false
Protected Attributes inherited from DiagramTextItem
bool m_mouse_hover = false
bool m_first_move = true
bool m_no_editable
bool m_is_html = false
bool m_non_left_alignment = false
QString m_previous_html_text
QString m_previous_text
QPointF m_mouse_to_origin_movement
◆ anonymous enum
anonymous enum
Enumerator
Type
◆ TextFrom
Enumerator
UserText
ElementInfo
CompositeText
◆ DynamicElementTextItem() [1/3]
DynamicElementTextItem::DynamicElementTextItem ( Element * parent_element)
parent_element
◆ ~DynamicElementTextItem()
DynamicElementTextItem::~DynamicElementTextItem ( )
◆ DynamicElementTextItem() [2/3]
DynamicElementTextItem::DynamicElementTextItem ( )
◆ DynamicElementTextItem() [3/3]
DynamicElementTextItem::DynamicElementTextItem ( const DynamicElementTextItem & )
◆ clearFormulaConnection()
void DynamicElementTextItem::clearFormulaConnection ( )
◆ compositeText()
QString DynamicElementTextItem::compositeText ( ) const
◆ compositeTextChanged
void DynamicElementTextItem::compositeTextChanged ( QString text)
signal
◆ conductorPropertiesChanged()
void DynamicElementTextItem::conductorPropertiesChanged ( )
◆ conductorWasAdded()
void DynamicElementTextItem::conductorWasAdded ( Conductor * conductor)
conductor
◆ conductorWasRemoved()
void DynamicElementTextItem::conductorWasRemoved ( Conductor * conductor)
conductor
◆ elementInfoChanged()
void DynamicElementTextItem::elementInfoChanged ( )
◆ elementUseForInfo()
Element * DynamicElementTextItem::elementUseForInfo ( ) const
a pointer to the element we must use for the variable information. If this text is owned by a simple element, the simple element is returned, this is the same element returned by the function parentElement(). If this text is owned by a master element, the master element is returned, this is the same element returned by the function parentElement(). If this text is owned by a report element, the report element is returned, this is the same element returned by the function parentElement(). If this text is owned by a terminal element, the terminal element is returned, this is the same element returned by the function parentElement(). If this text is owned by a slave element, we return the master element set as master of the parent slave element, if the parent slave is not linked to a master, this function return a nullptr. If this text have no parent element, return nullptr
◆ frame()
bool DynamicElementTextItem::frame ( ) const
◆ frameChanged
void DynamicElementTextItem::frameChanged ( bool frame)
signal
◆ fromXml()
void DynamicElementTextItem::fromXml ( const QDomElement & dom_elmt)
overridevirtual
dom_elmt
Implements DiagramTextItem.
◆ hoverEnterEvent()
void DynamicElementTextItem::hoverEnterEvent ( QGraphicsSceneHoverEvent * event)
overrideprotected
event
◆ hoverLeaveEvent()
void DynamicElementTextItem::hoverLeaveEvent ( QGraphicsSceneHoverEvent * event)
overrideprotected
event
◆ infoName()
QString DynamicElementTextItem::infoName ( ) const
the info name of this text
◆ infoNameChanged
void DynamicElementTextItem::infoNameChanged ( QString info)
signal
◆ itemChange()
QVariant DynamicElementTextItem::itemChange ( GraphicsItemChange change,
const QVariant & value )
overrideprotected
◆ keepVisualRotation()
bool DynamicElementTextItem::keepVisualRotation ( ) const
◆ keepVisualRotationChanged
void DynamicElementTextItem::keepVisualRotationChanged ( bool keep)
signal
◆ masterChanged()
void DynamicElementTextItem::masterChanged ( )
◆ masterElement()
Element * DynamicElementTextItem::masterElement ( ) const
the master element for slave elements, or the parent element for others. For PLC slaves, returns the actual master from linkedElements() instead of m_master_element (which points to self because elementUseForInfo() returns self for PLC slaves to resolve %{plc_*} variables).
◆ masterXrefItem()
CrossRefItem * DynamicElementTextItem::masterXrefItem ( ) const
inline
DXF export: the master-side cross-reference item (the table/cross drawn next to a report/master element), if this text item has one.
◆ mouseDoubleClickEvent()
void DynamicElementTextItem::mouseDoubleClickEvent ( QGraphicsSceneMouseEvent * event)
overrideprotected
event
◆ mouseMoveEvent()
void DynamicElementTextItem::mouseMoveEvent ( QGraphicsSceneMouseEvent * event)
overrideprotected
event
◆ mousePressEvent()
void DynamicElementTextItem::mousePressEvent ( QGraphicsSceneMouseEvent * event)
overrideprotected
event
◆ mouseReleaseEvent()
void DynamicElementTextItem::mouseReleaseEvent ( QGraphicsSceneMouseEvent * event)
overrideprotected
event
◆ paint()
void DynamicElementTextItem::paint ( QPainter * painter,
const QStyleOptionGraphicsItem * option,
QWidget * widget )
overrideprotected
◆ parentElement()
Element * DynamicElementTextItem::parentElement ( ) const
a pointer to the parent element. Note the pointer can be null. Note that the text can return a parent element, even if the text belong to a group of this same element.
◆ parentElementRotationChanged()
void DynamicElementTextItem::parentElementRotationChanged ( )
◆ parentGroup()
ElementTextItemGroup * DynamicElementTextItem::parentGroup ( ) const
The group where this text belong, if this item is note in a group, return nullptr.
◆ plainTextChanged
void DynamicElementTextItem::plainTextChanged ( )
signal
◆ refreshLabelConnection()
void DynamicElementTextItem::refreshLabelConnection ( )
◆ removeConnectionForReportFormula()
void DynamicElementTextItem::removeConnectionForReportFormula ( const QString & formula)
◆ reportChanged()
void DynamicElementTextItem::reportChanged ( )
◆ reportFormulaChanged()
void DynamicElementTextItem::reportFormulaChanged ( )
◆ reportReplacedCompositeText()
QString DynamicElementTextItem::reportReplacedCompositeText ( ) const
the composite text with the variable replaced by the real value. If the parent element of this text is not a folio report, return a default QString.
◆ rotationPointCenter()
bool DynamicElementTextItem::rotationPointCenter ( ) const
◆ rotationPointCenterChanged
void DynamicElementTextItem::rotationPointCenterChanged ( bool center)
signal
◆ sceneEventFilter()
bool DynamicElementTextItem::sceneEventFilter ( QGraphicsItem * watched,
QEvent * event )
overrideprotected
◆ setCompositeText()
void DynamicElementTextItem::setCompositeText ( const QString & text)
text
◆ setConnectionForReportFormula()
void DynamicElementTextItem::setConnectionForReportFormula ( const QString & formula)
◆ setFrame()
void DynamicElementTextItem::setFrame ( const bool frame)
◆ setInfoName()
void DynamicElementTextItem::setInfoName ( const QString & info_name)
info_name
◆ setKeepVisualRotation()
void DynamicElementTextItem::setKeepVisualRotation ( bool set)
◆ setPlainText()
void DynamicElementTextItem::setPlainText ( const QString & text)
◆ setPotentialConductor()
void DynamicElementTextItem::setPotentialConductor ( )
◆ setRotationPointCenter()
void DynamicElementTextItem::setRotationPointCenter ( bool set)
◆ setText()
void DynamicElementTextItem::setText ( const QString & text)
text
◆ setTextFrom()
void DynamicElementTextItem::setTextFrom ( DynamicElementTextItem::TextFrom text_from)
text_from
◆ setTextWidth()
void DynamicElementTextItem::setTextWidth ( qreal width)
◆ setupFormulaConnection()
void DynamicElementTextItem::setupFormulaConnection ( )
◆ setXref_item()
void DynamicElementTextItem::setXref_item ( Qt::AlignmentFlag m_exHrefPos,
int slave_offset = 0 )
◆ slaveXrefItem()
QGraphicsTextItem * DynamicElementTextItem::slaveXrefItem ( ) const
inline
◆ text()
QString DynamicElementTextItem::text ( ) const
◆ textChanged
void DynamicElementTextItem::textChanged ( QString text)
signal
◆ textFrom()
DynamicElementTextItem::TextFrom DynamicElementTextItem::textFrom ( ) const
what the final text is created from.
◆ textFromChanged
void DynamicElementTextItem::textFromChanged ( DynamicElementTextItem::TextFrom text_from)
signal
◆ textFromMetaEnum()
QMetaEnum DynamicElementTextItem::textFromMetaEnum ( )
static
The QMetaEnum of the enum TextFrom
◆ textWidthChanged
void DynamicElementTextItem::textWidthChanged ( qreal width)
signal
◆ thisRotationChanged()
void DynamicElementTextItem::thisRotationChanged ( )
◆ toXml()
QDomElement DynamicElementTextItem::toXml ( QDomDocument & dom_doc) const
overridevirtual
dom_doc
Reimplemented from DiagramTextItem.
◆ type()
int DynamicElementTextItem::type ( ) const
inlineoverride
◆ updateLabel()
void DynamicElementTextItem::updateLabel ( )
◆ updateReportFormulaConnection()
void DynamicElementTextItem::updateReportFormulaConnection ( )
◆ updateReportText()
void DynamicElementTextItem::updateReportText ( )
◆ updateXref()
void DynamicElementTextItem::updateXref ( )
◆ uuid()
QUuid DynamicElementTextItem::uuid ( ) const
◆ xmlTagName()
QString DynamicElementTextItem::xmlTagName ( )
inlinestatic
◆ zoomToLinkedElement()
void DynamicElementTextItem::zoomToLinkedElement ( )
◆ CompositeTextEditDialog
friend class CompositeTextEditDialog
friend
◆ DynamicTextItemDelegate
friend class DynamicTextItemDelegate
friend
◆ Element
friend class Element
friend
◆ m_composite_text
QString DynamicElementTextItem::m_composite_text
◆ m_F_str
QString DynamicElementTextItem::m_F_str
◆ m_first_scene_change
bool DynamicElementTextItem::m_first_scene_change = true
◆ m_formula_connection
QList<QMetaObject::Connection> DynamicElementTextItem::m_formula_connection
◆ m_frame
bool DynamicElementTextItem::m_frame = false
◆ m_info_name
QString DynamicElementTextItem::m_info_name
◆ m_initial_position
QPointF DynamicElementTextItem::m_initial_position
◆ m_keep_visual_rotation
bool DynamicElementTextItem::m_keep_visual_rotation = true
◆ m_master_element
QPointer<Element> DynamicElementTextItem::m_master_element
◆ m_move_parent
bool DynamicElementTextItem::m_move_parent = true
◆ m_other_report
QPointer<Element> DynamicElementTextItem::m_other_report
◆ m_parent_element
QPointer<Element> DynamicElementTextItem::m_parent_element
◆ m_report_formula
QString DynamicElementTextItem::m_report_formula
◆ m_report_formula_con
QMetaObject::Connection DynamicElementTextItem::m_report_formula_con
◆ m_rotation_point_center
bool DynamicElementTextItem::m_rotation_point_center = false
◆ m_slave_Xref_item
QGraphicsTextItem* DynamicElementTextItem::m_slave_Xref_item = nullptr
◆ m_text
QString DynamicElementTextItem::m_text
◆ m_text_from
DynamicElementTextItem::TextFrom DynamicElementTextItem::m_text_from = UserText
◆ m_text_width
qreal DynamicElementTextItem::m_text_width = -1
◆ m_update_slave_Xref_connection
QList<QMetaObject::Connection> DynamicElementTextItem::m_update_slave_Xref_connection
◆ m_user_color
QColor DynamicElementTextItem::m_user_color
◆ m_uuid
QUuid DynamicElementTextItem::m_uuid
◆ m_visual_rotation_ref
qreal DynamicElementTextItem::m_visual_rotation_ref = 0
◆ m_watched_conductor
QPointer<Conductor> DynamicElementTextItem::m_watched_conductor
◆ m_Xref_item
CrossRefItem* DynamicElementTextItem::m_Xref_item = nullptr
Property Documentation
◆ compositeText
readwrite
◆ frame
readwrite
◆ infoName
readwrite
readwrite
readwrite
◆ text
readwrite
◆ textFrom
readwrite
◆ textWidth
qreal DynamicElementTextItem::textWidth
readwrite
