PartDynamicTextField Class Reference
The PartDynamicTextField class This class represents an editable dynamic text field which may be used to compose the drawing of an electrical element within the element editor. The field will remain editable once the element is added onto a diagram. More...
#include <partdynamictextfield.h>
Inheritance diagram for PartDynamicTextField:
Collaboration diagram for PartDynamicTextField:
Public Types
enum  { Type = UserType + 1110 }
Signals
void taggChanged (QString tagg)
void textChanged (QString text)
void textFromChanged (DynamicElementTextItem::TextFrom text_from)
void infoNameChanged (QString info)
void compositeTextChanged (QString text)
void colorChanged (QColor color)
void frameChanged (bool frame)
void textWidthChanged (qreal width)
void alignmentChanged (Qt::Alignment alignment)
void fontChanged (QFont font)
void keepVisualRotationChanged (bool keep)
void rotationPointCenterChanged (bool center)
void setProperty (const char *name, const QVariant &value) override
 PROPERTY.
QVariant property (const char *name) const override
 PartDynamicTextField (QETElementEditor *editor, QGraphicsItem *parent=nullptr)
int type () const override
QString xmlName () const override
bool isUseless () const override
QRectF sceneGeometricRect () const override
void startUserTransformation (const QRectF &initial_selection_rect) override
 PartDynamicTextField::startUserTransformation.
void handleUserTransformation (const QRectF &initial_selection_rect, const QRectF &new_selection_rect) override
 PartDynamicTextField::handleUserTransformation.
const QDomElement toXml (QDomDocument &dom_doc) const override
 PartDynamicTextField::toXml.
void fromXml (const QDomElement &dom_elmt) override
 PartDynamicTextField::fromXml.
void fromTextFieldXml (const QDomElement &dom_element)
 PartDynamicTextField::fromTextFieldXml Setup this text from the xml definition of a text field (The xml tagg of a text field is "input");.
DynamicElementTextItem::TextFrom textFrom () const
 PartDynamicTextField::textFrom.
void setTextFrom (DynamicElementTextItem::TextFrom text_from)
 PartDynamicTextField::setTextFrom Set the final text is created from.
QString text () const
 PartDynamicTextField::text.
void setText (const QString &text)
 PartDynamicTextField::setText Set the text of this text.
void setInfoName (const QString &info_name)
QString infoName () const
 PartDynamicTextField::infoName.
void setCompositeText (const QString &text)
 PartDynamicTextField::setCompositeText Set the composite text of this text item to text.
QString compositeText () const
 PartDynamicTextField::compositeText.
void setColor (const QColor &color)
 PartDynamicTextField::setColor.
QColor color () const
 PartDynamicTextField::color.
void setFrame (bool frame)
bool frame () const
void setTextWidth (qreal width)
void setPlainText (const QString &text)
void setAlignment (Qt::Alignment alignment)
Qt::Alignment alignment () const
void setFont (const QFont &font)
void setKeepVisualRotation (const bool &keep)
bool keepVisualRotation () const
void setRotationPointCenter (const bool &center)
bool rotationPointCenter () const
void setRotation (qreal angle)
void mirror (qreal axis_x=0)
void flip (qreal axis_y=0)
Public Member Functions inherited from CustomElementPart
 CustomElementPart (QETElementEditor *editor)
 CustomElementPart Constructor.
virtual ~CustomElementPart ()
 ~CustomElementPart Destructor
virtual void updateCurrentPartEditor () const
virtual QGraphicsItem * toItem ()
virtual QET::ScalingMethod preferredScalingMethod () const
static QString xmlTaggName ()
Protected Member Functions
 PartDynamicTextField::mouseMoveEvent.
 PartDynamicTextField::mousePressEvent.
 PartDynamicTextField::mouseReleaseEvent.
QVariant itemChange (GraphicsItemChange change, const QVariant &value) override
 PartDynamicTextField::itemChange.
void paint (QPainter *painter, const QStyleOptionGraphicsItem *option, QWidget *widget) override
Protected Member Functions inherited from CustomElementPart
QList< QPointF > mapPoints (const QRectF &, const QRectF &, const QList< QPointF > &)
Properties
QString text
QString infoName
QColor color
bool frame
qreal textWidth
QFont font
void elementInfoChanged ()
 PartDynamicTextField::elementInfoChanged Used to up to date this text field, when the element information (see elementScene) changed.
void prepareAlignment ()
void finishAlignment ()
QPointF m_origin_pos
QPointF m_saved_point
QString m_text
QString m_info_name
QString m_composite_text
DynamicElementTextItem::TextFrom m_text_from = DynamicElementTextItem::UserText
QUuid m_uuid
bool m_frame = false
bool m_first_add = true
bool m_block_alignment = false
bool m_keep_visual_rotation = false
bool m_rotation_point_center = false
qreal m_text_width = -1
Qt::Alignment m_alignment = Qt::AlignTop|Qt::AlignLeft
QRectF m_alignment_rect
◆ anonymous enum
anonymous enum
Enumerator
Type
◆ PartDynamicTextField()
PartDynamicTextField::PartDynamicTextField ( QETElementEditor * editor,
QGraphicsItem * parent = nullptr )
◆ alignment()
Qt::Alignment PartDynamicTextField::alignment ( ) const
◆ alignmentChanged
void PartDynamicTextField::alignmentChanged ( Qt::Alignment alignment)
signal
◆ color()
QColor PartDynamicTextField::color ( ) const
The color of this text
◆ colorChanged
void PartDynamicTextField::colorChanged ( QColor color)
signal
◆ compositeText()
QString PartDynamicTextField::compositeText ( ) const
◆ compositeTextChanged
void PartDynamicTextField::compositeTextChanged ( QString text)
signal
◆ elementInfoChanged()
void PartDynamicTextField::elementInfoChanged ( )
◆ finishAlignment()
void PartDynamicTextField::finishAlignment ( )
◆ flip()
void PartDynamicTextField::flip ( qreal axis_y = 0)
◆ fontChanged
void PartDynamicTextField::fontChanged ( QFont font)
signal
◆ frame()
bool PartDynamicTextField::frame ( ) const
◆ frameChanged
void PartDynamicTextField::frameChanged ( bool frame)
signal
◆ fromTextFieldXml()
void PartDynamicTextField::fromTextFieldXml ( const QDomElement & dom_element)
dom_element
◆ fromXml()
void PartDynamicTextField::fromXml ( const QDomElement & dom_elmt)
overridevirtual
dom_elmt
Implements CustomElementPart.
◆ handleUserTransformation()
void PartDynamicTextField::handleUserTransformation ( const QRectF & initial_selection_rect,
const QRectF & new_selection_rect )
overridevirtual
new_selection_rectHandle the user-induced transformation from initial_selection_rect to new_selection_rect
◆ infoName()
QString PartDynamicTextField::infoName ( ) const
the info name of this text
◆ infoNameChanged
void PartDynamicTextField::infoNameChanged ( QString info)
signal
◆ isUseless()
bool PartDynamicTextField::isUseless ( ) const
inlineoverridevirtual
whether the primitive appears to be useless (e.g. 0-length line) Typically, useless primitives are discarded when saving the element.
◆ itemChange()
QVariant PartDynamicTextField::itemChange ( GraphicsItemChange change,
const QVariant & value )
overrideprotected
change
value
◆ keepVisualRotation()
bool PartDynamicTextField::keepVisualRotation ( ) const
◆ keepVisualRotationChanged
void PartDynamicTextField::keepVisualRotationChanged ( bool keep)
signal
◆ mirror()
void PartDynamicTextField::mirror ( qreal axis_x = 0)
◆ mouseMoveEvent()
void PartDynamicTextField::mouseMoveEvent ( QGraphicsSceneMouseEvent * event)
overrideprotected
event
◆ mousePressEvent()
void PartDynamicTextField::mousePressEvent ( QGraphicsSceneMouseEvent * event)
overrideprotected
◆ mouseReleaseEvent()
void PartDynamicTextField::mouseReleaseEvent ( QGraphicsSceneMouseEvent * event)
overrideprotected
event
◆ name()
QString PartDynamicTextField::name ( ) const
overridevirtual
the name of the primitive
◆ paint()
void PartDynamicTextField::paint ( QPainter * painter,
const QStyleOptionGraphicsItem * option,
QWidget * widget )
overrideprotected
◆ prepareAlignment()
void PartDynamicTextField::prepareAlignment ( )
◆ property()
QVariant PartDynamicTextField::property ( const char * name) const
Get the current value of a specific primitive property
◆ rotationPointCenter()
bool PartDynamicTextField::rotationPointCenter ( ) const
◆ rotationPointCenterChanged
void PartDynamicTextField::rotationPointCenterChanged ( bool center)
signal
◆ sceneGeometricRect()
QRectF PartDynamicTextField::sceneGeometricRect ( ) const
◆ setAlignment()
void PartDynamicTextField::setAlignment ( Qt::Alignment alignment)
◆ setColor()
void PartDynamicTextField::setColor ( const QColor & color)
colorset text color to color
◆ setCompositeText()
void PartDynamicTextField::setCompositeText ( const QString & text)
text
◆ setFont()
void PartDynamicTextField::setFont ( const QFont & font)
◆ setFrame()
void PartDynamicTextField::setFrame ( bool frame)
◆ setInfoName()
void PartDynamicTextField::setInfoName ( const QString & info_name)
◆ setKeepVisualRotation()
void PartDynamicTextField::setKeepVisualRotation ( const bool & keep)
◆ setPlainText()
void PartDynamicTextField::setPlainText ( const QString & text)
◆ setProperty()
void PartDynamicTextField::setProperty ( const char * name,
PROPERTY.
◆ setRotation()
void PartDynamicTextField::setRotation ( qreal angle)
Redefines setRotation
angle
◆ setRotationPointCenter()
void PartDynamicTextField::setRotationPointCenter ( const bool & center)
◆ setText()
void PartDynamicTextField::setText ( const QString & text)
text
◆ setTextFrom()
void PartDynamicTextField::setTextFrom ( DynamicElementTextItem::TextFrom text_from)
text_from
◆ setTextWidth()
void PartDynamicTextField::setTextWidth ( qreal width)
◆ startUserTransformation()
void PartDynamicTextField::startUserTransformation ( const QRectF & initial_selection_rect)
overridevirtual
initial_selection_rectStart the user-induced transformation, provided this primitive is contained within the initial_selection_rect bounding rectangle.
◆ taggChanged
void PartDynamicTextField::taggChanged ( QString tagg)
signal
◆ text()
QString PartDynamicTextField::text ( ) const
◆ textChanged
void PartDynamicTextField::textChanged ( QString text)
signal
◆ textFrom()
DynamicElementTextItem::TextFrom PartDynamicTextField::textFrom ( ) const
what the final text is created from.
◆ textFromChanged
void PartDynamicTextField::textFromChanged ( DynamicElementTextItem::TextFrom text_from)
signal
◆ textWidthChanged
void PartDynamicTextField::textWidthChanged ( qreal width)
signal
◆ toXml()
const QDomElement PartDynamicTextField::toXml ( QDomDocument & dom_doc) const
overridevirtual
dom_doc
◆ type()
int PartDynamicTextField::type ( ) const
inlineoverride
◆ xmlName()
QString PartDynamicTextField::xmlName ( ) const
overridevirtual
the name that will be used as XML tag when exporting the primitive
◆ xmlTaggName()
QString PartDynamicTextField::xmlTaggName ( )
inlinestatic
◆ m_alignment
Qt::Alignment PartDynamicTextField::m_alignment = Qt::AlignTop|Qt::AlignLeft
◆ m_alignment_rect
QRectF PartDynamicTextField::m_alignment_rect
◆ m_block_alignment
bool PartDynamicTextField::m_block_alignment = false
◆ m_composite_text
QString PartDynamicTextField::m_composite_text
◆ m_first_add
bool PartDynamicTextField::m_first_add = true
◆ m_frame
bool PartDynamicTextField::m_frame = false
◆ m_info_name
QString PartDynamicTextField::m_info_name
◆ m_keep_visual_rotation
bool PartDynamicTextField::m_keep_visual_rotation = false
◆ m_origin_pos
QPointF PartDynamicTextField::m_origin_pos
◆ m_rotation_point_center
bool PartDynamicTextField::m_rotation_point_center = false
◆ m_saved_point
QPointF PartDynamicTextField::m_saved_point
◆ m_text
QString PartDynamicTextField::m_text
◆ m_text_from
DynamicElementTextItem::TextFrom PartDynamicTextField::m_text_from = DynamicElementTextItem::UserText
◆ m_text_width
qreal PartDynamicTextField::m_text_width = -1
◆ m_uuid
QUuid PartDynamicTextField::m_uuid
Property Documentation
◆ alignment
readwrite
◆ color
readwrite
◆ compositeText
readwrite
◆ font
QFont PartDynamicTextField::font
readwrite
◆ frame
readwrite
◆ infoName
readwrite
readwrite
readwrite
◆ text
readwrite
◆ textFrom
readwrite
◆ textWidth
qreal PartDynamicTextField::textWidth
readwrite
