DeleteQGraphicsItemCommand Class Reference
#include <deleteqgraphicsitemcommand.h>
Inheritance diagram for DeleteQGraphicsItemCommand:
Collaboration diagram for DeleteQGraphicsItemCommand:
 DeleteQGraphicsItemCommand (Diagram *diagram, const DiagramContent &content, QUndoCommand *parent=nullptr)
 DeleteQGraphicsItemCommand::DeleteQGraphicsItemCommand.
 ~DeleteQGraphicsItemCommand () override
void undo () override
 DeleteQGraphicsItemCommand::undo Undo this command.
void redo () override
 DeleteQGraphicsItemCommand::redo Redo the delete command.
static bool hasNonDeletableTerminal (const DiagramContent &content)
 DeleteQGraphicsItemCommand::hasNonDeletableTerminal Return true if @content have terminal element which can't be deleted. The reason why a terminal can't be deleted is because they have bridge or belong to a physical terminal with more than one level.
 DeleteQGraphicsItemCommand (const DeleteQGraphicsItemCommand &)
void setPotentialsOfRemovedElements ()
 DeleteQGraphicsItemCommand::setPotentialsOfRemovedElements This function creates new conductors (if needed) for conserve the electrical potentials present at the terminals of each removed elements.
Terminal * terminalInSamePotential (Terminal *terminal, Conductor *conductor_to_exclude)
 DeleteQGraphicsItemCommand::terminalInSamePotential Return a terminal at the same potential of terminal, by traveling through the conductors connected to terminal only if the owner element of the terminal is not delete by this undo command. Return nullptr if a terminal can't be found.
DiagramContent m_removed_contents
Diagram * m_diagram
QHash< Element *, QList< Element * > > m_link_hash
QHash< DynamicElementTextItem *, Element * > m_elmt_text_hash
 keep linked element for each removed element linked to other element.
QHash< DynamicElementTextItem *, ElementTextItemGroup * > m_grp_texts_hash
 Keep the parent element of each deleted dynamic element text item.
QList< std::pair< Terminal *, Terminal * > > m_connected_terminals
 Keep the parent group of each deleted element text item.
QHash< QetGraphicsTableItem *, QPointer< QGraphicsScene > > m_table_scene_hash
bool m_remove_linked_table = false
◆ DeleteQGraphicsItemCommand() [1/2]
DeleteQGraphicsItemCommand::DeleteQGraphicsItemCommand ( Diagram * diagram,
const DiagramContent & content,
diagram: diagram where this undo work
content: content to remove
parent: parent undo
◆ ~DeleteQGraphicsItemCommand()
DeleteQGraphicsItemCommand::~DeleteQGraphicsItemCommand ( )
◆ DeleteQGraphicsItemCommand() [2/2]
DeleteQGraphicsItemCommand::DeleteQGraphicsItemCommand ( const DeleteQGraphicsItemCommand & )
◆ hasNonDeletableTerminal()
bool DeleteQGraphicsItemCommand::hasNonDeletableTerminal ( const DiagramContent & content)
static
diagram
content
dialog
◆ redo()
void DeleteQGraphicsItemCommand::redo ( )
◆ setPotentialsOfRemovedElements()
void DeleteQGraphicsItemCommand::setPotentialsOfRemovedElements ( )
◆ terminalInSamePotential()
Terminal * DeleteQGraphicsItemCommand::terminalInSamePotential ( Terminal * terminal,
Conductor * conductor_to_exclude )
terminal- terminal from search
conductor_to_exclude- a conductor to exlcude from search.
◆ undo()
void DeleteQGraphicsItemCommand::undo ( )
◆ m_connected_terminals
QList<std::pair<Terminal *, Terminal *> > DeleteQGraphicsItemCommand::m_connected_terminals
◆ m_diagram
Diagram* DeleteQGraphicsItemCommand::m_diagram
◆ m_elmt_text_hash
QHash<DynamicElementTextItem *, Element *> DeleteQGraphicsItemCommand::m_elmt_text_hash
◆ m_grp_texts_hash
QHash<DynamicElementTextItem *, ElementTextItemGroup *> DeleteQGraphicsItemCommand::m_grp_texts_hash
◆ m_link_hash
QHash<Element *, QList<Element *> > DeleteQGraphicsItemCommand::m_link_hash
◆ m_remove_linked_table
bool DeleteQGraphicsItemCommand::m_remove_linked_table = false
◆ m_removed_contents
DiagramContent DeleteQGraphicsItemCommand::m_removed_contents
◆ m_table_scene_hash
QHash<QetGraphicsTableItem *, QPointer<QGraphicsScene> > DeleteQGraphicsItemCommand::m_table_scene_hash
