QetGraphicsTableItem Class Reference
The QetGraphicsTableItem class This item display a table destined to represent the content of a QAbstractItemModel The table have a few parameters to edit her visual aspect. Margins, to edit the margin between the cell and the text. Text font. Text alignment in the cell These three parameters are not settable directly with the table but through the model to be displayed by the table. The table search these parameters only in the index(0,0) for all the table. By consequence, set data in other index than 0,0 is useless also these parameter can't be set individually for each cell. The margins is stored in the model in index Qt::UserRole+1 and for value a QString. See QETUtils::marginsFromString and QETUtils::marginsToString. More...
#include <qetgraphicstableitem.h>
Inheritance diagram for QetGraphicsTableItem:
Collaboration diagram for QetGraphicsTableItem:
Public Types
enum  { Type = UserType + 1300 }
 QetGraphicsTableItem (QGraphicsItem *parent=nullptr)
 QetGraphicsTableItem::QetGraphicsTableItem Default constructor.
virtual ~QetGraphicsTableItem () override
int type () const override
void setModel (QAbstractItemModel *model=nullptr)
 QetGraphicsTableItem::setModel Set the model presented by this item. Since QetGraphicsTableItem don't take ownership of model, if item already have a model, it's your responsibility to delete it.
QAbstractItemModel * model () const
 QetGraphicsTableItem::model.
virtual QRectF boundingRect () const override
 QetGraphicsTableItem::boundingRect Reimplemented from QGraphicsObject.
virtual void paint (QPainter *painter, const QStyleOptionGraphicsItem *option, QWidget *widget) override
 QetGraphicsTableItem::paint Draw the table.
QetGraphicsHeaderItem * headerItem () const
void setSize (const QSize &size)
 QetGraphicsTableItem::setSize Set the current size of the table to size.
QSize size () const
 QetGraphicsTableItem::size.
QSize minimumSize () const
 QetGraphicsTableItem::minimumSize.
void setDisplayNRow (const int &number)
 QetGraphicsTableItem::setDisplayNRow Limit the number of row to display.
int displayNRow () const
 QetGraphicsTableItem::displayNRow.
void setPreviousTable (QetGraphicsTableItem *table=nullptr)
 QetGraphicsTableItem::setPreviousTable Set the previous table to table. If this table already have a previous table, the previous table will be replaced. Set new table to nullptr to remove an existing previous table. The table uses the model of the new previous table. Since the table does not take ownership of the model, it is your responsibility to manage the old model. Linked tables (table with next and/or previous table) share the same model, a table always take the model of the previous table. When remove a previous table (set to nullptr) from a table, the model is also removed, you need to set a new model.
void setNextTable (QetGraphicsTableItem *table=nullptr)
 QetGraphicsTableItem::setNextTable Set the next table to table nullptr will remove an existing next table.
void setTableName (const QString &name)
QString tableName () const
int displayNRowOffset () const
 QetGraphicsTableItem::displayNRowOffset.
int displayedRowCount () const
 QetGraphicsTableItem::displayedRowCount.
QPointer< QetGraphicsTableItem > previousTable () const
QPointer< QetGraphicsTableItem > nextTable () const
void setToMinimumHeight ()
 QetGraphicsTableItem::setToMinimumHeight Set the height to the the minimum. The width stay unchanged.
void initLink ()
QUuid uuid () const
int minimumRowHeight () const
 QetGraphicsTableItem::minimumRowHeight.
QDomElement toXml (QDomDocument &dom_document) const
 QetGraphicsTableItem::toXml Save the table to xml.
void fromXml (const QDomElement &dom_element)
 QetGraphicsTableItem::fromXml Restore the table from xml. Make this item is already in a diagram to.
virtual bool toDXF (const QString &filepath)
 QetGraphicsTableItem::toDXF Draw this table to the dxf document.
Public Member Functions inherited from QetGraphicsItem
 QetGraphicsItem (QGraphicsItem *parent=nullptr)
 ~QetGraphicsItem () override=0
Diagram * diagram () const
virtual void setPos (const QPointF &p)
virtual void setPos (qreal x, qreal y)
virtual bool isMovable () const
virtual void setMovable (bool movable)
bool isHovered () const
QPointF hoverMousePos () const
virtual void editProperty ()
virtual QString name () const
QET::GraphicsItemState state () const
 QetGraphicsItem::state.
static void adjustTableToFolio (QetGraphicsTableItem *table, QMargins margins=QMargins(20, 20, 20, 0))
 QetGraphicsTableItem::adjustTableToFolio Adjust the table to fit at best the folio.
static void checkInsufficientRowsCount (QetGraphicsTableItem *first_table)
 QetGraphicsTableItem::checkInsufficientRowsCount Check if the number of rows of table + linked table is enough to display all content of the model, if not open a dialog to advise user what to do.
static QString xmlTagName ()
Static Public Member Functions inherited from QetGraphicsItem
static void showItem (QetGraphicsItem *item)
 QetGraphicsItem::QetGraphicsItem Default constructor.
Protected Member Functions
virtual void hoverEnterEvent (QGraphicsSceneHoverEvent *event) override
 QetGraphicsTableItem::hoverEnterEvent Reimplemented from QetGraphicsItem.
virtual void hoverLeaveEvent (QGraphicsSceneHoverEvent *event) override
 QetGraphicsTableItem::hoverLeaveEvent Reimplemented from QetGraphicsItem.
virtual bool sceneEventFilter (QGraphicsItem *watched, QEvent *event) override
 QetGraphicsTableItem::sceneEventFilter Reimplemented from QetGraphicsItem.
virtual QVariant itemChange (GraphicsItemChange change, const QVariant &value) override
 QetGraphicsTableItem::itemChange.
Protected Member Functions inherited from QetGraphicsItem
 QetGraphicsItem::mouseReleaseEvent handle mouse release click.
void hoverMoveEvent (QGraphicsSceneHoverEvent *event) override
Properties
QSize size
int displayNRow
void modelReseted ()
 QetGraphicsTableItem::modelReseted.
void setUpColumnAndRowMinimumSize ()
 QetGraphicsTableItem::setUpColumnAndRowMinimumSize Calculate the minimum row height and the minimum column width for each columns this function doesn't change the geometry of the table.
void setUpBoundingRect ()
 QetGraphicsTableItem::setUpBoundingRect.
void adjustHandlerPos ()
 QetGraphicsTableItem::adjustHandlerPos Adjust the pos of the handler item.
void setUpHandler ()
 QetGraphicsTableItem::setUpHandler.
void handlerMousePressEvent (QGraphicsSceneMouseEvent *event)
void handlerMouseMoveEvent (QGraphicsSceneMouseEvent *event)
void handlerMouseReleaseEvent (QGraphicsSceneMouseEvent *event)
void adjustColumnsWidth ()
 QetGraphicsTableItem::adjustColumnsWidth Adjust the size of each column according to the current table width by setting the sectionSize of the header item.
void dataChanged (const QModelIndex &topLeft, const QModelIndex &bottomRight, const QVector< int > &roles)
void headerSectionResized ()
void adjustSize ()
 QetGraphicsTableItem::adjustSize If needed, this function resize the current height and width of table and/or the size of columns. according to there minimum.
void previousTableDisplayRowChanged ()
void removeUselessNextTable (bool recursive=true)
 QetGraphicsTableItem::removeUselessNextTable Remove next table if useless, an useless table with 0 row displayed. If recursive is true check and remove for all sub next table.
QPointer< QAbstractItemModel > m_model
QVector< int > m_minimum_column_width
int m_minimum_row_height
int m_number_of_row_to_display = 0
int m_br_margin = 10
QSize m_current_size
QSize m_old_size
QSize m_pending_size
QRectF m_bounding_rect
QetGraphicsHandlerItem m_handler_item
QetGraphicsHeaderItem * m_header_item = nullptr
QPointer< QetGraphicsTableItem > m_previous_table
QPointer< QetGraphicsTableItem > m_next_table
QString m_name
QUuid m_uuid = QUuid::createUuid()
QUuid m_pending_previous_table_uuid
Additional Inherited Members
Protected Attributes inherited from QetGraphicsItem
bool is_movable_
bool m_first_move
bool snap_to_grid_
QPointF m_mouse_to_origin_movement
QET::GraphicsItemState m_state = QET:: GIOK
◆ anonymous enum
anonymous enum
Enumerator
Type
◆ QetGraphicsTableItem()
QetGraphicsTableItem::QetGraphicsTableItem ( QGraphicsItem * parent = nullptr)
parent
◆ ~QetGraphicsTableItem()
QetGraphicsTableItem::~QetGraphicsTableItem ( )
overridevirtual
◆ adjustColumnsWidth()
void QetGraphicsTableItem::adjustColumnsWidth ( )
◆ adjustHandlerPos()
void QetGraphicsTableItem::adjustHandlerPos ( )
◆ adjustSize()
void QetGraphicsTableItem::adjustSize ( )
◆ adjustTableToFolio()
void QetGraphicsTableItem::adjustTableToFolio ( QetGraphicsTableItem * table,
QMargins margins = QMargins(20,20,20,0) )
static
table: table to adjust
margins: margins between table and folio.
◆ boundingRect()
QRectF QetGraphicsTableItem::boundingRect ( ) const
overridevirtual
◆ checkInsufficientRowsCount()
void QetGraphicsTableItem::checkInsufficientRowsCount ( QetGraphicsTableItem * table)
static
table
◆ dataChanged()
void QetGraphicsTableItem::dataChanged ( const QModelIndex & topLeft,
const QModelIndex & bottomRight,
const QVector< int > & roles )
◆ displayedRowCount()
int QetGraphicsTableItem::displayedRowCount ( ) const
the number of row displayed by this table
◆ displayNRow()
int QetGraphicsTableItem::displayNRow ( ) const
the number of row displayed. A value of 0 or less mean there is no limit
◆ displayNRowOffset()
int QetGraphicsTableItem::displayNRowOffset ( ) const
the offset (aka the last displayed row) of displayed row. If this item have a previous table, the previous offset is added.
◆ fromXml()
void QetGraphicsTableItem::fromXml ( const QDomElement & dom_element)
dom_element
◆ handlerMouseMoveEvent()
void QetGraphicsTableItem::handlerMouseMoveEvent ( QGraphicsSceneMouseEvent * event)
◆ handlerMousePressEvent()
void QetGraphicsTableItem::handlerMousePressEvent ( QGraphicsSceneMouseEvent * event)
◆ handlerMouseReleaseEvent()
void QetGraphicsTableItem::handlerMouseReleaseEvent ( QGraphicsSceneMouseEvent * event)
◆ headerItem()
QetGraphicsHeaderItem * QetGraphicsTableItem::headerItem ( ) const
inline
◆ headerSectionResized()
void QetGraphicsTableItem::headerSectionResized ( )
◆ hoverEnterEvent()
void QetGraphicsTableItem::hoverEnterEvent ( QGraphicsSceneHoverEvent * event)
overrideprotectedvirtual
event
◆ hoverLeaveEvent()
void QetGraphicsTableItem::hoverLeaveEvent ( QGraphicsSceneHoverEvent * event)
event
◆ initLink()
void QetGraphicsTableItem::initLink ( )
◆ itemChange()
QVariant QetGraphicsTableItem::itemChange ( GraphicsItemChange change,
const QVariant & value )
change
value
◆ minimumRowHeight()
int QetGraphicsTableItem::minimumRowHeight ( ) const
the minimum height of a row
◆ minimumSize()
QSize QetGraphicsTableItem::minimumSize ( ) const
the minimum size the table can be The returned size take care of the table's minimum width, but also the header item's minimum width
◆ model()
QAbstractItemModel * QetGraphicsTableItem::model ( ) const
The model that this item is presenting
◆ modelReseted()
void QetGraphicsTableItem::modelReseted ( )
◆ nextTable()
QPointer< QetGraphicsTableItem > QetGraphicsTableItem::nextTable ( ) const
◆ paint()
void QetGraphicsTableItem::paint ( QPainter * painter,
const QStyleOptionGraphicsItem * option,
QWidget * widget )
overridevirtual
painter
option
widget
◆ previousTable()
QPointer< QetGraphicsTableItem > QetGraphicsTableItem::previousTable ( ) const
◆ previousTableDisplayRowChanged()
void QetGraphicsTableItem::previousTableDisplayRowChanged ( )
◆ removeUselessNextTable()
void QetGraphicsTableItem::removeUselessNextTable ( bool recursive = true)
recursive
◆ sceneEventFilter()
bool QetGraphicsTableItem::sceneEventFilter ( QGraphicsItem * watched,
QEvent * event )
watched
event
◆ setDisplayNRow()
void QetGraphicsTableItem::setDisplayNRow ( const int & number)
number: set to 0 or less to disabled the limit of row to display
◆ setModel()
void QetGraphicsTableItem::setModel ( QAbstractItemModel * model = nullptr)
model
◆ setNextTable()
void QetGraphicsTableItem::setNextTable ( QetGraphicsTableItem * table = nullptr)
table
◆ setPreviousTable()
void QetGraphicsTableItem::setPreviousTable ( QetGraphicsTableItem * table = nullptr)
table
◆ setSize()
void QetGraphicsTableItem::setSize ( const QSize & size)
size
◆ setTableName()
void QetGraphicsTableItem::setTableName ( const QString & name)
◆ setToMinimumHeight()
void QetGraphicsTableItem::setToMinimumHeight ( )
◆ setUpBoundingRect()
void QetGraphicsTableItem::setUpBoundingRect ( )
◆ setUpColumnAndRowMinimumSize()
void QetGraphicsTableItem::setUpColumnAndRowMinimumSize ( )
◆ setUpHandler()
void QetGraphicsTableItem::setUpHandler ( )
◆ size()
QSize QetGraphicsTableItem::size ( ) const
The current size of the table
◆ tableName()
QString QetGraphicsTableItem::tableName ( ) const
◆ toDXF()
bool QetGraphicsTableItem::toDXF ( const QString & filepath)
virtual
filepathfile path of the the dxf document
true if draw success
◆ toXml()
QDomElement QetGraphicsTableItem::toXml ( QDomDocument & dom_document) const
dom_document: parent document
the dom_element that describe the table
◆ type()
int QetGraphicsTableItem::type ( ) const
inlineoverride
◆ uuid()
QUuid QetGraphicsTableItem::uuid ( ) const
inline
◆ xmlTagName()
QString QetGraphicsTableItem::xmlTagName ( )
inlinestatic
◆ m_bounding_rect
QRectF QetGraphicsTableItem::m_bounding_rect
◆ m_br_margin
int QetGraphicsTableItem::m_br_margin = 10
◆ m_current_size
QSize QetGraphicsTableItem::m_current_size
◆ m_handler_item
QetGraphicsHandlerItem QetGraphicsTableItem::m_handler_item
◆ m_header_item
QetGraphicsHeaderItem* QetGraphicsTableItem::m_header_item = nullptr
◆ m_minimum_column_width
QVector<int> QetGraphicsTableItem::m_minimum_column_width
◆ m_minimum_row_height
int QetGraphicsTableItem::m_minimum_row_height
◆ m_model
QPointer<QAbstractItemModel> QetGraphicsTableItem::m_model
◆ m_name
QString QetGraphicsTableItem::m_name
◆ m_next_table
QPointer<QetGraphicsTableItem> QetGraphicsTableItem::m_next_table
◆ m_number_of_row_to_display
int QetGraphicsTableItem::m_number_of_row_to_display = 0
◆ m_old_size
QSize QetGraphicsTableItem::m_old_size
◆ m_pending_previous_table_uuid
QUuid QetGraphicsTableItem::m_pending_previous_table_uuid
◆ m_pending_size
QSize QetGraphicsTableItem::m_pending_size
◆ m_previous_table
QPointer<QetGraphicsTableItem> QetGraphicsTableItem::m_previous_table
◆ m_uuid
QUuid QetGraphicsTableItem::m_uuid = QUuid::createUuid()
Property Documentation
◆ displayNRow
readwrite
◆ size
readwrite
