PolygonEditor Class Reference
#include <polygoneditor.h>
Inheritance diagram for PolygonEditor:
Collaboration diagram for PolygonEditor:
 PolygonEditor (QETElementEditor *editor, PartPolygon *part=nullptr, QWidget *parent=nullptr)
 PolygonEditor::PolygonEditor.
 ~PolygonEditor () override
 PolygonEditor::~PolygonEditor.
bool setPart (CustomElementPart *part) override
 PolygonEditor::setPart.
CustomElementPart * currentPart () const override
 PolygonEditor::currentPart.
QList< CustomElementPart * > currentParts () const override
void updateForm () override
 PolygonEditor::updateForm Update the widget.
QVector< QPointF > pointsFromTree ()
 PolygonEditor::pointsFromTree.
bool eventFilter (QObject *watched, QEvent *event) override
Public Member Functions inherited from ElementItemEditor
 ElementItemEditor (QETElementEditor *, QWidget *=nullptr)
 ~ElementItemEditor () override
virtual QString elementTypeName () const
virtual void setElementTypeName (const QString &)
virtual void detach ()
virtual bool setParts (QList< CustomElementPart * >)
Private Slots
void on_m_close_polygon_cb_stateChanged (int arg1)
 PolygonEditor::on_m_close_polygon_cb_stateChanged.
void on_m_points_list_tree_itemChanged (QTreeWidgetItem *item, int column)
 PolygonEditor::on_m_points_list_tree_itemChanged Update the polygon according to the current value of the tree editor.
void on_m_points_list_tree_itemSelectionChanged ()
 PolygonEditor::on_m_points_list_tree_itemSelectionChanged Used to change the color of the current selected point.
void on_m_add_point_action_triggered ()
void on_m_remove_point_action_triggered ()
void setUpChangeConnections ()
 setUpChangeConnections Setup the connection from the line(s) to the widget, to update it when the line(s) are changed (moved ...)
void disconnectChangeConnections ()
Ui::PolygonEditor * ui
StyleEditor * m_style = nullptr
PartPolygon * m_part = nullptr
QList< QMetaObject::Connection > m_change_connections
◆ PolygonEditor()
PolygonEditor::PolygonEditor ( QETElementEditor * editor,
PartPolygon * part = nullptr,
QWidget * parent = nullptr )
explicit
editor
part
parent
◆ ~PolygonEditor()
PolygonEditor::~PolygonEditor ( )
◆ currentPart()
CustomElementPart * PolygonEditor::currentPart ( ) const
overridevirtual
the current edited part
Implements ElementItemEditor.
◆ currentParts()
QList< CustomElementPart * > PolygonEditor::currentParts ( ) const
overridevirtual
◆ disconnectChangeConnections()
void PolygonEditor::disconnectChangeConnections ( )
◆ eventFilter()
bool PolygonEditor::eventFilter ( QObject * watched,
QEvent * event )
◆ on_m_add_point_action_triggered
void PolygonEditor::on_m_add_point_action_triggered ( )
privateslot
◆ on_m_close_polygon_cb_stateChanged
void PolygonEditor::on_m_close_polygon_cb_stateChanged ( int arg1)
privateslot
◆ on_m_points_list_tree_itemChanged
void PolygonEditor::on_m_points_list_tree_itemChanged ( QTreeWidgetItem * item,
int column )
privateslot
◆ on_m_points_list_tree_itemSelectionChanged
void PolygonEditor::on_m_points_list_tree_itemSelectionChanged ( )
privateslot
◆ on_m_remove_point_action_triggered
void PolygonEditor::on_m_remove_point_action_triggered ( )
privateslot
◆ pointsFromTree()
QVector< QPointF > PolygonEditor::pointsFromTree ( )
the point of polygon from the current value of the tree editor if part coordinate.
◆ setPart()
bool PolygonEditor::setPart ( CustomElementPart * new_part)
overridevirtual
new_part
◆ setUpChangeConnections()
void PolygonEditor::setUpChangeConnections ( )
◆ updateForm()
void PolygonEditor::updateForm ( )
overridevirtual
◆ m_change_connections
QList<QMetaObject::Connection> PolygonEditor::m_change_connections
◆ m_part
PartPolygon* PolygonEditor::m_part = nullptr
◆ m_style
StyleEditor* PolygonEditor::m_style = nullptr
◆ ui
Ui::PolygonEditor* PolygonEditor::ui
