StyleEditor Class Reference
#include <styleeditor.h>
Inheritance diagram for StyleEditor:
Collaboration diagram for StyleEditor:
Public Slots
void updateForm () override
 StyleEditor::updateForm Update the edition form according to the value of edited part(s).
void updatePartAntialiasing ()
 Update antialiasing with undo command.
void updatePartColor ()
 Update color with undo command.
void updatePartLineStyle ()
 Update style with undo command.
void updatePartLineWeight ()
 Update weight with undo command.
void updatePartFilling ()
 Update color filling with undo command.
 StyleEditor (QETElementEditor *, CustomElementGraphicPart *=nullptr, QWidget *=nullptr)
 ~StyleEditor () override
 Destructeur.
bool setPart (CustomElementPart *) override
 StyleEditor::setPart Set the part to edit by this editor. Note : editor can accept or refuse to edit a part.
bool setParts (QList< CustomElementPart * >) override
 StyleEditor::setParts Set several parts to edit by this editor. Note : editor can accept or refuse to edit several parts.
CustomElementPart * currentPart () const override
QList< CustomElementPart * > currentParts () const override
Public Member Functions inherited from ElementItemEditor
 ElementItemEditor (QETElementEditor *, QWidget *=nullptr)
 ~ElementItemEditor () override
virtual QString elementTypeName () const
virtual void setElementTypeName (const QString &)
virtual void detach ()
virtual void updateForm ()=0
static bool isStyleEditable (QList< CustomElementPart * > cep_list)
 StyleEditor::isStyleEditable.
 StyleEditor (const StyleEditor &)
void activeConnections (bool)
void makeUndo (const QString &undo_text, const char *property_name, const QVariant &new_value)
CustomElementGraphicPart * part
QList< CustomElementGraphicPart * > m_part_list
QList< CustomElementPart * > m_cep_list
QCheckBox * antialiasing
QComboBox * filling_color
QComboBox * outline_color
QComboBox * size_weight
QComboBox * line_style
This class provides a widget to edit styles (color, pen style and thickness, filling, antialiasing) common to most primitives within the element editor. Its appendWidget() method makes the insertion of another widget below it easier.
◆ StyleEditor() [1/2]
StyleEditor::StyleEditor ( QETElementEditor * editor,
CustomElementGraphicPart * p = nullptr,
QWidget * parent = nullptr )
Constructeur / Constructor
editorL'editeur d'element concerne
pLa partie a editer
parentle Widget parent
◆ ~StyleEditor()
StyleEditor::~StyleEditor ( )
Destructeur.
◆ StyleEditor() [2/2]
StyleEditor::StyleEditor ( const StyleEditor & )
◆ activeConnections()
void StyleEditor::activeConnections ( bool active)
Active ou desactive les connexionx signaux/slots entre les widgets internes.
activetrue pour activer les connexions, false pour les desactiver
◆ currentPart()
CustomElementPart * StyleEditor::currentPart ( ) const
overridevirtual
la primitive actuellement editee, ou 0 si ce widget n'en edite pas
Implements ElementItemEditor.
◆ currentParts()
QList< CustomElementPart * > StyleEditor::currentParts ( ) const
overridevirtual
◆ isStyleEditable()
bool StyleEditor::isStyleEditable ( QList< CustomElementPart * > cep_list)
static
cep_list
true if all of the content of cep_list can be edited by style editor, else return false.
◆ makeUndo()
void StyleEditor::makeUndo ( const QString & undo_text,
const char * property_name,
const QVariant & new_value )
◆ setPart()
bool StyleEditor::setPart ( CustomElementPart * new_part)
overridevirtual
new_part: part to edit
true if editor accept to edit this CustomElementPart otherwise false
◆ setParts()
bool StyleEditor::setParts ( QList< CustomElementPart * > part_list)
overridevirtual
part_list
true if every customeElementPart stored in part_list can be edited by this part editor, otherwise return false (see StyleEditor::isStyleEditable)
Reimplemented from ElementItemEditor.
◆ updateForm
void StyleEditor::updateForm ( )
overrideslot
◆ updatePartAntialiasing
void StyleEditor::updatePartAntialiasing ( )
slot
◆ updatePartColor
void StyleEditor::updatePartColor ( )
slot
◆ updatePartFilling
void StyleEditor::updatePartFilling ( )
slot
◆ updatePartLineStyle
void StyleEditor::updatePartLineStyle ( )
slot
◆ updatePartLineWeight
void StyleEditor::updatePartLineWeight ( )
slot
◆ antialiasing
QCheckBox* StyleEditor::antialiasing
◆ filling_color
QComboBox* StyleEditor::filling_color
◆ line_style
QComboBox * StyleEditor::line_style
◆ m_cep_list
QList<CustomElementPart *> StyleEditor::m_cep_list
◆ m_part_list
QList<CustomElementGraphicPart *> StyleEditor::m_part_list
◆ outline_color
QComboBox * StyleEditor::outline_color
◆ part
CustomElementGraphicPart* StyleEditor::part
◆ size_weight
QComboBox * StyleEditor::size_weight
