ArcEditor Class Reference
#include <arceditor.h>
Inheritance diagram for ArcEditor:
Collaboration diagram for ArcEditor:
Public Slots
void updateArcS ()
 ArcEditor::updateArcS Update the start angle of the arc according to the edited value.
void updateArcA ()
 ArcEditor::updateArcA Update the span angle of the arc according to the edited value.
void updateForm () override
 ArcEditor::updateForm Update the value of the widgets.
void updateRect ()
 ArcEditor (QETElementEditor *, PartArc *=nullptr, QWidget *=nullptr)
 ~ArcEditor () override
 Destructeur.
bool setPart (CustomElementPart *) override
 ArcEditor::setPart Specifie to this editor the part to edit. Note that an editor can accept or refuse to edit a part. This editor accept only partArc.
bool setParts (QList< CustomElementPart * > parts) override
CustomElementPartcurrentPart () const override
 ArcEditor::currentPart.
QList< CustomElementPart * > currentParts () const override
Public Member Functions inherited from ElementItemEditor
 ElementItemEditor (QETElementEditor *, QWidget *=nullptr)
 ~ElementItemEditor () override
virtual QETElementEditorelementEditor () const
virtual ElementSceneelementScene () const
virtual QString elementTypeName () const
virtual void setElementTypeName (const QString &)
virtual void detach ()
virtual void updateForm ()=0
 ArcEditor (const ArcEditor &)
void activeConnections (bool)
 ArcEditor::activeConnections Enable/disable connection between editor widget and slot editingFinished True == enable | false == disable.
void setUpChangeConnections ()
 setUpChangeConnections Setup the connection from the arc(s) to the widget, to update it when the arc(s) are changed (moved ...)
void disconnectChangeConnections ()
PartArcm_part
StyleEditorm_style
QDoubleSpinBox * x
QDoubleSpinBox * y
QDoubleSpinBox * h
QDoubleSpinBox * v
QSpinBox * angle
QSpinBox * start_angle
bool m_locked
QList< QMetaObject::Connection > m_change_connections
This class provides a widget to edit elliptical arcs within the element editor.
◆ ArcEditor() [1/2]
ArcEditor::ArcEditor ( QETElementEditor * editor,
PartArc * arc = nullptr,
QWidget * parent = nullptr )
Constructeur
editorL'editeur d'element concerne
arcL'arc a editer
parentle Widget parent
◆ ~ArcEditor()
ArcEditor::~ArcEditor ( )
Destructeur.
◆ ArcEditor() [2/2]
ArcEditor::ArcEditor ( const ArcEditor & )
◆ activeConnections()
void ArcEditor::activeConnections ( bool active)
active
◆ currentPart()
CustomElementPart * ArcEditor::currentPart ( ) const
overridevirtual
the current edited part, or 0 if there is no edited part
Implements ElementItemEditor.
◆ currentParts()
QList< CustomElementPart * > ArcEditor::currentParts ( ) const
overridevirtual
◆ disconnectChangeConnections()
void ArcEditor::disconnectChangeConnections ( )
◆ setPart()
bool ArcEditor::setPart ( CustomElementPart * new_part)
overridevirtual
new_part
◆ setParts()
bool ArcEditor::setParts ( QList< CustomElementPart * > parts)
overridevirtual
Reimplemented from ElementItemEditor.
◆ setUpChangeConnections()
void ArcEditor::setUpChangeConnections ( )
◆ updateArcA
void ArcEditor::updateArcA ( )
slot
◆ updateArcS
void ArcEditor::updateArcS ( )
slot
◆ updateForm
void ArcEditor::updateForm ( )
overrideslot
◆ updateRect
void ArcEditor::updateRect ( )
slot
◆ angle
QSpinBox* ArcEditor::angle
◆ h
QDoubleSpinBox * ArcEditor::h
◆ m_change_connections
QList<QMetaObject::Connection> ArcEditor::m_change_connections
◆ m_locked
bool ArcEditor::m_locked
◆ m_part
PartArc* ArcEditor::m_part
◆ m_style
StyleEditor* ArcEditor::m_style
◆ start_angle
QSpinBox * ArcEditor::start_angle
◆ v
QDoubleSpinBox * ArcEditor::v
◆ x
QDoubleSpinBox* ArcEditor::x
◆ y
QDoubleSpinBox * ArcEditor::y
