DynamicTextFieldEditor Class Reference
The DynamicTextFieldEditor class This class provide a widget used to edit the property of a dynamic text field. More...
#include <dynamictextfieldeditor.h>
Inheritance diagram for DynamicTextFieldEditor:
Collaboration diagram for DynamicTextFieldEditor:
 DynamicTextFieldEditor (QETElementEditor *editor, PartDynamicTextField *text_field=nullptr, QWidget *parent=nullptr)
 ~DynamicTextFieldEditor () override
bool setPart (CustomElementPart *part) override
 DynamicTextFieldEditor::setPart Set part as current edited part of this widget.
bool setParts (QList< CustomElementPart * >) override
CustomElementPart * currentPart () const override
 DynamicTextFieldEditor::currentPart.
QList< CustomElementPart * > currentParts () const override
void updateForm () override
Public Member Functions inherited from ElementItemEditor
 ElementItemEditor (QETElementEditor *, QWidget *=nullptr)
 ~ElementItemEditor () override
virtual QString elementTypeName () const
virtual void setElementTypeName (const QString &)
virtual void detach ()
Private Slots
void on_m_x_sb_editingFinished ()
void on_m_y_sb_editingFinished ()
void on_m_rotation_sb_editingFinished ()
void on_m_user_text_le_editingFinished ()
void on_m_size_sb_editingFinished ()
void on_m_frame_cb_clicked ()
void on_m_width_sb_editingFinished ()
void on_m_elmt_info_cb_activated (int index)
void on_m_text_from_cb_activated (int index)
void on_m_composite_text_pb_clicked ()
void on_m_alignment_pb_clicked ()
void on_m_font_pb_clicked ()
void m_color_kpb_changed (QColor newColor)
void on_m_keep_visual_rotation_cb_clicked ()
void on_m_rotation_point_center_cb_clicked ()
void setupWidget ()
void fillInfoComboBox ()
 DynamicTextFieldEditor::fillInfoComboBox Fill the combo box "element information".
void setUpConnections ()
void disconnectConnections ()
void updateTextFromWidgetsEnabled (int index)
 DynamicTextFieldEditor::updateTextFromWidgetsEnabled Enable the widget matching index (the "text from" combo box's current index) and disable the other two. Purely cosmetic: called both from the real user-activated slot below and from updateForm() when the form is (re)filled for a part/selection, so it must never touch m_parts's data — see on_m_text_from_cb_activated() for the part-mutating counterpart.
Ui::DynamicTextFieldEditor * ui
QPointer< PartDynamicTextField > m_text_field
QList< PartDynamicTextField * > m_parts
QList< QMetaObject::Connection > m_connection_list
KColorButton * m_color_kpb = nullptr
◆ DynamicTextFieldEditor()
DynamicTextFieldEditor::DynamicTextFieldEditor ( QETElementEditor * editor,
PartDynamicTextField * text_field = nullptr,
QWidget * parent = nullptr )
explicit
◆ ~DynamicTextFieldEditor()
DynamicTextFieldEditor::~DynamicTextFieldEditor ( )
◆ currentPart()
CustomElementPart * DynamicTextFieldEditor::currentPart ( ) const
overridevirtual
The current edited part, note they can return nullptr if there is not a currently edited part.
Implements ElementItemEditor.
◆ currentParts()
QList< CustomElementPart * > DynamicTextFieldEditor::currentParts ( ) const
overridevirtual
◆ disconnectConnections()
void DynamicTextFieldEditor::disconnectConnections ( )
◆ fillInfoComboBox()
void DynamicTextFieldEditor::fillInfoComboBox ( )
◆ m_color_kpb_changed
void DynamicTextFieldEditor::m_color_kpb_changed ( QColor newColor)
privateslot
◆ on_m_alignment_pb_clicked
void DynamicTextFieldEditor::on_m_alignment_pb_clicked ( )
privateslot
◆ on_m_composite_text_pb_clicked
void DynamicTextFieldEditor::on_m_composite_text_pb_clicked ( )
privateslot
◆ on_m_elmt_info_cb_activated
void DynamicTextFieldEditor::on_m_elmt_info_cb_activated ( int index)
privateslot
◆ on_m_font_pb_clicked
void DynamicTextFieldEditor::on_m_font_pb_clicked ( )
privateslot
◆ on_m_frame_cb_clicked
void DynamicTextFieldEditor::on_m_frame_cb_clicked ( )
privateslot
◆ on_m_keep_visual_rotation_cb_clicked
void DynamicTextFieldEditor::on_m_keep_visual_rotation_cb_clicked ( )
privateslot
◆ on_m_rotation_point_center_cb_clicked
void DynamicTextFieldEditor::on_m_rotation_point_center_cb_clicked ( )
privateslot
◆ on_m_rotation_sb_editingFinished
void DynamicTextFieldEditor::on_m_rotation_sb_editingFinished ( )
privateslot
◆ on_m_size_sb_editingFinished
void DynamicTextFieldEditor::on_m_size_sb_editingFinished ( )
privateslot
◆ on_m_text_from_cb_activated
void DynamicTextFieldEditor::on_m_text_from_cb_activated ( int index)
privateslot
◆ on_m_user_text_le_editingFinished
void DynamicTextFieldEditor::on_m_user_text_le_editingFinished ( )
privateslot
◆ on_m_width_sb_editingFinished
void DynamicTextFieldEditor::on_m_width_sb_editingFinished ( )
privateslot
◆ on_m_x_sb_editingFinished
void DynamicTextFieldEditor::on_m_x_sb_editingFinished ( )
privateslot
◆ on_m_y_sb_editingFinished
void DynamicTextFieldEditor::on_m_y_sb_editingFinished ( )
privateslot
◆ setPart()
bool DynamicTextFieldEditor::setPart ( CustomElementPart * part)
overridevirtual
part
true if part can be edited by this widget
◆ setParts()
bool DynamicTextFieldEditor::setParts ( QList< CustomElementPart * > parts)
overridevirtual
Reimplemented from ElementItemEditor.
◆ setUpConnections()
void DynamicTextFieldEditor::setUpConnections ( )
◆ setupWidget()
void DynamicTextFieldEditor::setupWidget ( )
◆ updateForm()
void DynamicTextFieldEditor::updateForm ( )
overridevirtual
◆ updateTextFromWidgetsEnabled()
void DynamicTextFieldEditor::updateTextFromWidgetsEnabled ( int index)
◆ m_color_kpb
KColorButton* DynamicTextFieldEditor::m_color_kpb = nullptr
◆ m_connection_list
QList<QMetaObject::Connection> DynamicTextFieldEditor::m_connection_list
◆ m_parts
QList<PartDynamicTextField*> DynamicTextFieldEditor::m_parts
◆ m_text_field
QPointer<PartDynamicTextField> DynamicTextFieldEditor::m_text_field
◆ ui
Ui::DynamicTextFieldEditor* DynamicTextFieldEditor::ui
