#include <titleblockpropertieswidget.h>
Inherits QWidget.
| | TitleBlockPropertiesWidget (const TitleBlockProperties &titleblock=TitleBlockProperties(), bool current_date=false, QETProject *project=nullptr, QWidget *parent=nullptr) |
| | TitleBlockPropertiesWidget::TitleBlockPropertiesWidget default constructor.
| | TitleBlockPropertiesWidget (TitleBlockTemplatesCollection *tbt_collection, const TitleBlockProperties &titleblock=TitleBlockProperties(), bool current_date=false, QETProject *project=nullptr, QWidget *parent=nullptr) |
| | TitleBlockPropertiesWidget::TitleBlockPropertiesWidget default constructor with template list.
| | TitleBlockPropertiesWidget (QList< TitleBlockTemplatesCollection * > tbt_collection, const TitleBlockProperties &titleblock=TitleBlockProperties(), bool current_date=false, QETProject *project=nullptr, QWidget *parent=nullptr) |
| | TitleBlockPropertiesWidget::TitleBlockPropertiesWidget Default constructor with several template collection.
| | ~TitleBlockPropertiesWidget () override |
| | TitleBlockPropertiesWidget::~TitleBlockPropertiesWidget destructor.
| void | setProperties (const TitleBlockProperties &properties) |
| | TitleBlockPropertiesWidget::setProperties.
| TitleBlockProperties | properties () const |
| | TitleBlockPropertiesWidget::properties.
| TitleBlockProperties | propertiesAutoNum (QString autoNum) const |
| TitleBlockTemplateLocation | currentTitleBlockLocation () const |
| void | setPropertiesWithAutoNum (const TitleBlockProperties &properties, QString autoNum) |
| void | setTitleBlockTemplatesVisible (const bool &visible) |
| | TitleBlockPropertiesWidget::setTitleBlockTemplatesVisible if true, title block template combo box and menu button is visible.
| void | setReadOnly (const bool &ro) |
| | TitleBlockPropertiesWidget::setReadOnly if true, this widget is disable.
◆ TitleBlockPropertiesWidget() [1/3]
◆ TitleBlockPropertiesWidget() [2/3]
◆ TitleBlockPropertiesWidget() [3/3]
◆ ~TitleBlockPropertiesWidget()
| TitleBlockPropertiesWidget::~TitleBlockPropertiesWidget |
override |
◆ addCollection()
◆ addTemplateVariables()
| void TitleBlockPropertiesWidget::addTemplateVariables |
DiagramContext & | context, |
int | index ) const |
private |
TitleBlockPropertiesWidget::addTemplateVariables Add to context every CUSTOM variable used by the currently selected template that is not already present, with an empty value — so the user only has to fill in the values instead of declaring the variables (#271). The standard fields (title, author, date, …) are handled by their own widgets and are skipped. Existing values in context are preserved.
◆ changeCurrentTitleBlockTemplate
| void TitleBlockPropertiesWidget::changeCurrentTitleBlockTemplate |
int | index | ) |
privateslot |
◆ currentTitleBlockLocation()
◆ currentTitleBlockTemplateName()
| QString TitleBlockPropertiesWidget::currentTitleBlockTemplateName |
const |
private |
◆ duplicateCurrentTitleBlockTemplate
| void TitleBlockPropertiesWidget::duplicateCurrentTitleBlockTemplate |
privateslot |
◆ editCurrentTitleBlockTemplate
| void TitleBlockPropertiesWidget::editCurrentTitleBlockTemplate |
privateslot |
◆ getIndexFor()
| int TitleBlockPropertiesWidget::getIndexFor |
const QString & | tbt_name, |
const QET::QetCollection | collection ) const |
private |
TitleBlockPropertiesWidget::getIndexFor Find the index of the combo box for the title block tbt_name available on the collection collection.
- Parameters
| tbt_name | : title block name |
| collection | : title block collection |
- Returns
- the index of the title block or -1 if no match
◆ initDialog()
| void TitleBlockPropertiesWidget::initDialog |
const bool & | current_date, |
QETProject * | project ) |
private |
◆ on_m_date_now_pb_clicked
| void TitleBlockPropertiesWidget::on_m_date_now_pb_clicked |
privateslot |
◆ on_m_edit_autofolionum_pb_clicked
| void TitleBlockPropertiesWidget::on_m_edit_autofolionum_pb_clicked |
privateslot |
◆ openAutoNumFolioEditor
| void TitleBlockPropertiesWidget::openAutoNumFolioEditor |
QString | | ) |
signal |
◆ properties()
◆ propertiesAutoNum()
◆ set_auto_page_num
| void TitleBlockPropertiesWidget::set_auto_page_num |
const |
signal |
◆ setProperties()
◆ setPropertiesWithAutoNum()
| void TitleBlockPropertiesWidget::setPropertiesWithAutoNum |
const TitleBlockProperties & | properties, |
QString | autoNum ) |
◆ setReadOnly()
| void TitleBlockPropertiesWidget::setReadOnly |
const bool & | ro | ) |
◆ setTitleBlockTemplatesVisible()
| void TitleBlockPropertiesWidget::setTitleBlockTemplatesVisible |
const bool & | visible | ) |
◆ templateForIndex()
◆ updateTemplateList
| void TitleBlockPropertiesWidget::updateTemplateList |
privateslot |
◆ keys_2
| QList<QString> TitleBlockPropertiesWidget::keys_2 |
private |
◆ m_dcw
◆ m_map_index_to_collection_type
◆ m_tbt_collection_list
◆ m_tbt_duplicate
| QAction * TitleBlockPropertiesWidget::m_tbt_duplicate |
private |
◆ m_tbt_edit
| QAction* TitleBlockPropertiesWidget::m_tbt_edit |
private |
◆ m_tbt_menu
| QMenu* TitleBlockPropertiesWidget::m_tbt_menu |
private |
◆ ui
| Ui::TitleBlockPropertiesWidget* TitleBlockPropertiesWidget::ui |
private |
