TitleBlockProperties Class Reference
#include <titleblockproperties.h>
Collaboration diagram for TitleBlockProperties:
Public Types
enum  DateManagement { UseDateValue , CurrentDate }
 Lists the various ways to handle the date. More...
 TitleBlockProperties ()
virtual ~TitleBlockProperties ()
bool operator== (const TitleBlockProperties &)
bool operator!= (const TitleBlockProperties &)
void toXml (QDomElement &) const
void fromXml (const QDomElement &)
void toSettings (QSettings &, const QString &=QString()) const
 TitleBlockProperties::toSettings Export the TitleBlockProperties into a QSettings.
void fromSettings (QSettings &, const QString &=QString())
void setAutoPageNum (QString autonum)
QDate finalDate () const
static TitleBlockProperties defaultProperties ()
 TitleBlockProperties::defaultProperties Return the default properties stored in the setting file.
Public Attributes
QString title
 Folio title (displayed by the default template).
QString author
 Author of the diagram/folio (displayed by the default template).
QDate date
 Date (displayed by the default template).
QString filename
 Filename (displayed by the default template).
QString plant
 Plant (displayed by the default template).
QString locmach
 Location(displayed by the default template).
QString indexrev
 Revision Index (displayed by the default template).
QString version
 Version (displayed by the default template).
QString folio
 Folio information (displayed by the default template).
QString auto_page_num
DateManagement useDate
 Wheter to use the date attribute.
QString template_name
 Name of the template used to render the title block - an empty string means "the default template provided by the application".
DiagramContext context
 Container for the additional, user-defined fields.
Qt::Edge display_at
 Edge to display the titleblock.
QET::QetCollection collection
 Specify the location of the title block.
QString exportDate () const
void setDateFromString (const QString &)
This class provides a container for the properties of a particular title block, i.e. title, author, date, filename, folio, template, custom properties, ...
◆ DateManagement
Enumerator
UseDateValue
CurrentDate
use the current date
◆ TitleBlockProperties()
TitleBlockProperties::TitleBlockProperties ( )
Constructeur. Initialise un objet TitleBlockProperties avec tous les champs vides (date vide + useDate a UseDateValue).
◆ ~TitleBlockProperties()
TitleBlockProperties::~TitleBlockProperties ( )
virtual
Destructeur
◆ defaultProperties()
TitleBlockProperties TitleBlockProperties::defaultProperties ( )
static
◆ exportDate()
QString TitleBlockProperties::exportDate ( ) const
une chaine de caracteres decrivant comment gerer la date dans le cartouche : la chaine peut valoir : null pour ne pas afficher de date now pour afficher la date courante (a la creation du schema) une date au format yyyyMMdd pour utiliser une date fixe
◆ finalDate()
QDate TitleBlockProperties::finalDate ( ) const
La date a utiliser
◆ fromSettings()
void TitleBlockProperties::fromSettings ( QSettings & settings,
const QString & prefix = QString() )
Importe le cartouche depuis une configuration.
settingsParametres a lire
prefixprefixe a ajouter devant les noms des parametres
◆ fromXml()
void TitleBlockProperties::fromXml ( const QDomElement & e)
Importe le cartouche a partir des attributs XML de l'element e
eElement XML dont les attributs seront lus
◆ operator!=()
bool TitleBlockProperties::operator!= ( const TitleBlockProperties & ip)
ipautre conteneur TitleBlockProperties
false si ip et ce conteneur sont identiques, true sinon
◆ operator==()
bool TitleBlockProperties::operator== ( const TitleBlockProperties & ip)
true si ip et ce conteneur sont identiques, false sinon
◆ setAutoPageNum()
void TitleBlockProperties::setAutoPageNum ( QString autonum)
inline
◆ setDateFromString()
void TitleBlockProperties::setDateFromString ( const QString & date_string)
Charge les attributs date et useDate a partir d'une chaine de caracteres.
date_stringChaine de caracteres a analyser
See also
exportDate
◆ toSettings()
void TitleBlockProperties::toSettings ( QSettings & settings,
const QString & prefix = QString() ) const
settings: setting to use
prefix: name to use as prefix for this property
◆ toXml()
void TitleBlockProperties::toXml ( QDomElement & e) const
Exporte le cartouche sous formes d'attributs XML ajoutes a l'element e.
eElement XML auquel seront ajoutes des attributs
◆ author
QString TitleBlockProperties::author
◆ auto_page_num
QString TitleBlockProperties::auto_page_num
◆ collection
QET::QetCollection TitleBlockProperties::collection
◆ context
DiagramContext TitleBlockProperties::context
◆ date
QDate TitleBlockProperties::date
◆ display_at
Qt::Edge TitleBlockProperties::display_at
◆ filename
QString TitleBlockProperties::filename
◆ folio
QString TitleBlockProperties::folio
◆ indexrev
QString TitleBlockProperties::indexrev
◆ locmach
QString TitleBlockProperties::locmach
◆ plant
QString TitleBlockProperties::plant
◆ template_name
QString TitleBlockProperties::template_name
◆ title
QString TitleBlockProperties::title
◆ useDate
DateManagement TitleBlockProperties::useDate
◆ version
QString TitleBlockProperties::version
