TerminalEditor Class Reference
The TerminalEditor class Provide a widget used to edit the properties of a PartTerminal. More...
#include <terminaleditor.h>
Inheritance diagram for TerminalEditor:
Collaboration diagram for TerminalEditor:
Public Slots
void refreshMasterLabelVisibility ()
 TerminalEditor (QETElementEditor *editor, QWidget *parent=nullptr)
 TerminalEditor::TerminalEditor Default constructor.
 ~TerminalEditor () override
 TerminalEditor::~TerminalEditor Destructor.
void updateForm () override
 TerminalEditor::updateForm Reimplemented from ElementItemEditor Update the content of this widget.
bool setPart (CustomElementPart *new_part) override
 TerminalEditor::setPart Set the part to edit. The part must be a PartTerminal, in other case return false.
CustomElementPart * currentPart () const override
 TerminalEditor::currentPart.
QList< CustomElementPart * > currentParts () const override
Public Member Functions inherited from ElementItemEditor
 ElementItemEditor (QETElementEditor *, QWidget *=nullptr)
 ~ElementItemEditor () override
virtual QString elementTypeName () const
virtual void setElementTypeName (const QString &)
virtual void detach ()
virtual bool setParts (QList< CustomElementPart * >)
void init ()
 TerminalEditor::init Some init about this class.
void posEdited ()
 TerminalEditor::posEdited.
void orientationEdited ()
 TerminalEditor::orientationEdited.
void nameEdited ()
 TerminalEditor::nameEdited.
void typeEdited ()
 TerminalEditor::typeEdited.
void showNameEdited ()
 TerminalEditor::activeConnections Active connection between the widgets used in this editor and method of this class.
void labelPosEdited ()
void labelFontClicked ()
void labelSizeEdited ()
void labelRotationEdited ()
void labelAlignClicked ()
void labelFrameEdited ()
void labelColorClicked ()
void activeConnections (bool active)
void activeChangeConnections (bool active)
void useMasterLabelEdited ()
void masterLabelIndexEdited ()
bool updateMasterLabelVisibility ()
Ui::TerminalEditor * ui
QVector< QMetaObject::Connection > m_editor_connections
QVector< QMetaObject::Connection > m_change_connections
PartTerminal * m_part = nullptr
bool m_locked = false
KColorButton * m_color_pb
◆ TerminalEditor()
TerminalEditor::TerminalEditor ( QETElementEditor * editor,
QWidget * parent = nullptr )
editor: element editor of which this terminal editor belong
parent: parent widget
◆ ~TerminalEditor()
TerminalEditor::~TerminalEditor ( )
◆ activeChangeConnections()
void TerminalEditor::activeChangeConnections ( bool active)
◆ activeConnections()
void TerminalEditor::activeConnections ( bool active)
◆ currentPart()
CustomElementPart * TerminalEditor::currentPart ( ) const
overridevirtual
the current edited part or nullptr if there is no part or several part
See also
QList<CustomElementPart *> TerminalEditor::currentParts() const
Implements ElementItemEditor.
◆ currentParts()
QList< CustomElementPart * > TerminalEditor::currentParts ( ) const
inlineoverridevirtual
◆ init()
void TerminalEditor::init ( )
◆ labelAlignClicked()
void TerminalEditor::labelAlignClicked ( )
◆ labelColorClicked()
void TerminalEditor::labelColorClicked ( )
◆ labelFontClicked()
void TerminalEditor::labelFontClicked ( )
◆ labelFrameEdited()
void TerminalEditor::labelFrameEdited ( )
◆ labelPosEdited()
void TerminalEditor::labelPosEdited ( )
◆ labelRotationEdited()
void TerminalEditor::labelRotationEdited ( )
◆ labelSizeEdited()
void TerminalEditor::labelSizeEdited ( )
◆ masterLabelIndexEdited()
void TerminalEditor::masterLabelIndexEdited ( )
◆ nameEdited()
void TerminalEditor::nameEdited ( )
◆ orientationEdited()
void TerminalEditor::orientationEdited ( )
◆ posEdited()
void TerminalEditor::posEdited ( )
◆ refreshMasterLabelVisibility
void TerminalEditor::refreshMasterLabelVisibility ( )
slot
◆ setPart()
bool TerminalEditor::setPart ( CustomElementPart * new_part)
overridevirtual
new_part: the part to edit
true if the part can be edited.
◆ showNameEdited()
void TerminalEditor::showNameEdited ( )
active
◆ typeEdited()
void TerminalEditor::typeEdited ( )
◆ updateForm()
void TerminalEditor::updateForm ( )
overridevirtual
◆ updateMasterLabelVisibility()
bool TerminalEditor::updateMasterLabelVisibility ( )
◆ useMasterLabelEdited()
void TerminalEditor::useMasterLabelEdited ( )
◆ m_change_connections
QVector<QMetaObject::Connection> TerminalEditor::m_change_connections
◆ m_color_pb
KColorButton* TerminalEditor::m_color_pb
◆ m_editor_connections
QVector<QMetaObject::Connection> TerminalEditor::m_editor_connections
◆ m_locked
bool TerminalEditor::m_locked = false
◆ m_part
PartTerminal* TerminalEditor::m_part = nullptr
◆ ui
Ui::TerminalEditor* TerminalEditor::ui
