PropertiesEditorWidget Class Reference
The PropertiesEditorWidget class This class extend QWidget method to have a common way to edit properties. More...
#include <propertieseditorwidget.h>
Inheritance diagram for PropertiesEditorWidget:
Collaboration diagram for PropertiesEditorWidget:
 PropertiesEditorWidget (QWidget *parent=nullptr)
 PropertiesEditorWidget::PropertiesEditorWidget Constructor.
virtual void apply ()
virtual void reset ()
virtual QUndoCommand * associatedUndo () const
 PropertiesEditorWidget::associatedUndo By default, return a nullptr.
virtual QString title () const
virtual void updateUi ()
virtual bool setLiveEdit (bool live_edit)
 PropertiesEditorWidget::setLiveEdit Set the editor in live edit mode. When an editor is in live edit mode, every change is applied immediately (no need to call apply). If live edit can be enabled, return true, or else false. By default this method does nothing and returns false (live edit is disabled). Inherited class of PropertiesEditorWidget must reimplement this method to manage the live edit mode.
bool isLiveEdit () const
 PropertiesEditorWidget::isLiveEdit.
Protected Member Functions
virtual void enableLiveEdit ()
virtual void disableLiveEdit ()
Protected Attributes
bool m_live_edit
◆ PropertiesEditorWidget()
PropertiesEditorWidget::PropertiesEditorWidget ( QWidget * parent = nullptr)
explicit
parent: parent widget
◆ apply()
virtual void PropertiesEditorWidget::apply ( )
inlinevirtual
◆ associatedUndo()
QUndoCommand * PropertiesEditorWidget::associatedUndo ( ) const
virtual
◆ disableLiveEdit()
virtual void PropertiesEditorWidget::disableLiveEdit ( )
inlineprotectedvirtual
Reimplemented in ElementInfoWidget.
◆ enableLiveEdit()
virtual void PropertiesEditorWidget::enableLiveEdit ( )
◆ isLiveEdit()
bool PropertiesEditorWidget::isLiveEdit ( ) const
true if this editor is in live edit mode else return false.
◆ reset()
virtual void PropertiesEditorWidget::reset ( )
inlinevirtual
Reimplemented in ElementPropertiesWidget, ImagePropertiesWidget, and MasterPropertiesWidget.
◆ setLiveEdit()
bool PropertiesEditorWidget::setLiveEdit ( bool live_edit)
virtual
live_edittrue to enable live edit
true if live edit is enabled, else false.
Reimplemented in DynamicElementTextItemEditor, ElementInfoWidget, ElementPropertiesWidget, GraphicsTablePropertiesEditor, ImagePropertiesWidget, IndiTextPropertiesWidget, LinkSingleElementWidget, MasterPropertiesWidget, and ShapeGraphicsItemPropertiesWidget.
◆ title()
QString PropertiesEditorWidget::title ( ) const
virtual
◆ updateUi()
virtual void PropertiesEditorWidget::updateUi ( )
inlinevirtual
◆ m_live_edit
bool PropertiesEditorWidget::m_live_edit
protected
