ElementInfoWidget Class Reference
The ElementInfoWidget class this class is a widget to edit an element informations. More...
#include <elementinfowidget.h>
Inheritance diagram for ElementInfoWidget:
Collaboration diagram for ElementInfoWidget:
 ElementInfoWidget (Element *elmt, QWidget *parent=nullptr)
 ElementInfoWidget::ElementInfoWidget Constructor.
 ~ElementInfoWidget () override
 ElementInfoWidget::~ElementInfoWidget Destructor.
void setElement (Element *element) override
 ElementInfoWidget::setElement Set element to be the edited element.
void apply () override
 ElementInfoWidget::apply Apply the new information with a new undo command (got with method associatedUndo) pushed to the stack of element project.
QUndoCommand * associatedUndo () const override
 ElementInfoWidget::associatedUndo If the edited info is different of the actual element info, return a QUndoCommand with the change. If no change return nullptr;.
bool setLiveEdit (bool live_edit) override
 ElementInfoWidget::setLiveEdit.
void updateUi () override
 ElementInfoWidget::updateUi fill information fetch in m_element_info to the corresponding line edit.
DiagramContext currentInfo () const
 ElementInfoWidget::currentInfo.
Public Member Functions inherited from AbstractElementPropertiesEditorWidget
 AbstractElementPropertiesEditorWidget (QWidget *parent=nullptr)
Public Member Functions inherited from PropertiesEditorWidget
 PropertiesEditorWidget::PropertiesEditorWidget Constructor.
virtual void reset ()
bool isLiveEdit () const
 PropertiesEditorWidget::isLiveEdit.
Protected Member Functions
bool event (QEvent *event) override
 ElementInfoWidget::event Reimplemented from QWidget::event Only give focus to the first line edit at first activation. After send the event to QWidget.
void enableLiveEdit () override
 ElementInfoWidget::enableLiveEdit Enable the live edit mode.
void disableLiveEdit () override
 ElementInfoWidget::disableLiveEdit disable the live edit mode.
Private Slots
void firstActivated ()
 ElementInfoWidget::firstActivated Slot activated when this widget is show. Set the focus to the first line edit provided by this widget.
void elementInfoChange ()
 ElementInfoWidget::elementInfoChange This slot is called when m_element::elementInformation change.
void addCustomProperty (const QString &key=QString(), const QString &value=QString())
 ElementInfoWidget::addCustomProperty Append a new user-defined key/value row to the widget.
void removeCustomProperty (CustomElementInfoPartWidget *widget)
 ElementInfoWidget::removeCustomProperty Remove a user-defined key/value row.
void buildInterface ()
 ElementInfoWidget::buildInterface Build the widget.
ElementInfoPartWidget * infoPartWidgetForKey (const QString &key) const
 ElementInfoWidget::infoPartWidgetForKey.
QStringList predefinedKeys () const
 ElementInfoWidget::predefinedKeys.
Ui::ElementInfoWidget * ui
QList< ElementInfoPartWidget * > m_eipw_list
QList< CustomElementInfoPartWidget * > m_custom_eipw_list
QPushButton * m_add_custom_property_btn = nullptr
QCheckBox * m_potential_isolating_cb = nullptr
QCheckBox * m_exclude_from_bom_cb = nullptr
bool m_first_activation
bool m_ui_builded = false
Additional Inherited Members
Protected Attributes inherited from AbstractElementPropertiesEditorWidget
QPointer< Element > m_element
Protected Attributes inherited from PropertiesEditorWidget
bool m_live_edit
◆ ElementInfoWidget()
ElementInfoWidget::ElementInfoWidget ( Element * elmt,
QWidget * parent = nullptr )
explicit
elmtelement to edit information
parentparent widget
◆ ~ElementInfoWidget()
ElementInfoWidget::~ElementInfoWidget ( )
◆ addCustomProperty
void ElementInfoWidget::addCustomProperty ( const QString & key = QString(),
const QString & value = QString() )
privateslot
keyinitial key, left empty for a freshly added row
valueinitial value
◆ apply()
void ElementInfoWidget::apply ( )
overridevirtual
◆ associatedUndo()
QUndoCommand * ElementInfoWidget::associatedUndo ( ) const
overridevirtual
◆ buildInterface()
void ElementInfoWidget::buildInterface ( )
◆ currentInfo()
DiagramContext ElementInfoWidget::currentInfo ( ) const
the info currently edited
◆ disableLiveEdit()
void ElementInfoWidget::disableLiveEdit ( )
overrideprotectedvirtual
◆ elementInfoChange
void ElementInfoWidget::elementInfoChange ( )
privateslot
◆ enableLiveEdit()
void ElementInfoWidget::enableLiveEdit ( )
◆ event()
bool ElementInfoWidget::event ( QEvent * event)
overrideprotected
event
◆ firstActivated
void ElementInfoWidget::firstActivated ( )
privateslot
◆ infoPartWidgetForKey()
ElementInfoPartWidget * ElementInfoWidget::infoPartWidgetForKey ( const QString & key) const
key
the ElementInfoPartWidget with key key, if not found return nullptr;
◆ predefinedKeys()
QStringList ElementInfoWidget::predefinedKeys ( ) const
every key this widget already exposes a dedicated row for, whether through ElementInfoPartWidget (the ~40 ELMT_* keys) or one of the standalone checkboxes. Anything present in the element's informations but absent from this list is a user-defined custom property.
◆ removeCustomProperty
void ElementInfoWidget::removeCustomProperty ( CustomElementInfoPartWidget * widget)
privateslot
widgetthe row to remove
◆ setElement()
void ElementInfoWidget::setElement ( Element * element)
overridevirtual
element
Implements AbstractElementPropertiesEditorWidget.
◆ setLiveEdit()
bool ElementInfoWidget::setLiveEdit ( bool live_edit)
overridevirtual
live_edittrue : enable the live edit mode, false disable
always true;
◆ title()
QString ElementInfoWidget::title ( ) const
inlineoverridevirtual
the title of this editor
◆ updateUi()
void ElementInfoWidget::updateUi ( )
overridevirtual
◆ m_add_custom_property_btn
QPushButton* ElementInfoWidget::m_add_custom_property_btn = nullptr
◆ m_custom_eipw_list
QList<CustomElementInfoPartWidget *> ElementInfoWidget::m_custom_eipw_list
◆ m_eipw_list
QList<ElementInfoPartWidget *> ElementInfoWidget::m_eipw_list
◆ m_exclude_from_bom_cb
QCheckBox* ElementInfoWidget::m_exclude_from_bom_cb = nullptr
◆ m_first_activation
bool ElementInfoWidget::m_first_activation
◆ m_potential_isolating_cb
QCheckBox* ElementInfoWidget::m_potential_isolating_cb = nullptr
◆ m_ui_builded
bool ElementInfoWidget::m_ui_builded = false
◆ ui
Ui::ElementInfoWidget* ElementInfoWidget::ui
