ElementPropertiesWidget Class Reference
#include <elementpropertieswidget.h>
Inheritance diagram for ElementPropertiesWidget:
Collaboration diagram for ElementPropertiesWidget:
Public Slots
void findInPanel ()
 ElementPropertiesWidget::findInPanel If m_element is a custom element, emit findElementRequired.
void editElement ()
 ElementPropertiesWidget::editElement If m_element is a custom element, emit findElementRequired and editElementRequired.
Signals
void findEditClicked ()
 ElementPropertiesWidget (Element *elmt, QWidget *parent=nullptr)
 ElementPropertiesWidget::ElementPropertiesWidget Default constructor.
 ElementPropertiesWidget (DynamicElementTextItem *text, QWidget *parent=nullptr)
 ElementPropertiesWidget::ElementPropertiesWidget Same as default constructor, the edited element, is the parent element of text. The only difference with default constructor, is that the current tab is the tab for dynamic texts, and the item in the tree that represent text is expanded and selected.
 ElementPropertiesWidget (ElementTextItemGroup *group, QWidget *parent=nullptr)
 ElementPropertiesWidget::ElementPropertiesWidget Same as default constructor, the edited element, is the parent element of group. The only difference with default constructor, is that the current tab is the tab for dynamic texts, and the item in the tree that represent group is expanded and selected.
void setElement (Element *element) override
 ElementPropertiesWidget::setElement Set element to be the edited element.
void setDynamicText (DynamicElementTextItem *text)
 ElementPropertiesWidget::setDynamicText convenience function: same as call : ElementPropertiesWidget::setElement, with parameter the parent element of text. Set the dynamics text tab as current tab, expand and select the item that represent text.
void setTextsGroup (ElementTextItemGroup *group)
 ElementPropertiesWidget::setTextsGroup Convenience function : same as call : ElementPropertiesWidget::setElement, with parameter the parent element of group. Set the dynamics text tab as current tab, expand and select the item that represent group.
void apply () override
 ElementPropertiesWidget::apply Apply the new properties by pushing an undo command to the parent project's undo stack of element.
void reset () override
 ElementPropertiesWidget::reset Reset the edited properties.
bool setLiveEdit (bool live_edit) override
 PropertiesEditorWidget::setLiveEdit Set the editor in live edit mode. When an editor is in live edit mode, every change is applied immediately (no need to call apply). If live edit can be enabled, return true, or else false. By default this method does nothing and returns false (live edit is disabled). Inherited class of PropertiesEditorWidget must reimplement this method to manage the live edit mode.
Public Member Functions inherited from AbstractElementPropertiesEditorWidget
 AbstractElementPropertiesEditorWidget (QWidget *parent=nullptr)
Public Member Functions inherited from PropertiesEditorWidget
 PropertiesEditorWidget::PropertiesEditorWidget Constructor.
virtual QUndoCommand * associatedUndo () const
 PropertiesEditorWidget::associatedUndo By default, return a nullptr.
virtual QString title () const
bool isLiveEdit () const
 PropertiesEditorWidget::isLiveEdit.
void buildGui ()
 ElementPropertiesWidget::build Build the content of this widget.
void updateUi () override
 ElementPropertiesWidget::updateUi Update the content of this widget.
void addGeneralWidget ()
 ElementPropertiesWidget::addGeneralWidget Add or update the general widget on this tab widget.
QWidget * generalWidget ()
 ElementPropertiesWidget::generalWidget.
Diagram * m_diagram
QTabWidget * m_tab
QList< AbstractElementPropertiesEditorWidget * > m_list_editor
QWidget * m_general_widget
Additional Inherited Members
Protected Member Functions inherited from PropertiesEditorWidget
virtual void enableLiveEdit ()
virtual void disableLiveEdit ()
Protected Attributes inherited from AbstractElementPropertiesEditorWidget
QPointer< Element > m_element
Protected Attributes inherited from PropertiesEditorWidget
bool m_live_edit
◆ ElementPropertiesWidget() [1/3]
ElementPropertiesWidget::ElementPropertiesWidget ( Element * elmt,
QWidget * parent = nullptr )
explicit
elmt
parent
◆ ElementPropertiesWidget() [2/3]
ElementPropertiesWidget::ElementPropertiesWidget ( DynamicElementTextItem * text,
explicit
text
parent
◆ ElementPropertiesWidget() [3/3]
ElementPropertiesWidget::ElementPropertiesWidget ( ElementTextItemGroup * group,
explicit
group
parent
◆ addGeneralWidget()
void ElementPropertiesWidget::addGeneralWidget ( )
◆ apply()
void ElementPropertiesWidget::apply ( )
overridevirtual
◆ buildGui()
void ElementPropertiesWidget::buildGui ( )
◆ editElement
void ElementPropertiesWidget::editElement ( )
slot
◆ findEditClicked
void ElementPropertiesWidget::findEditClicked ( )
signal
◆ findInPanel
void ElementPropertiesWidget::findInPanel ( )
slot
◆ generalWidget()
QWidget * ElementPropertiesWidget::generalWidget ( )
build and return the "general" widget
◆ reset()
void ElementPropertiesWidget::reset ( )
overridevirtual
◆ setDynamicText()
void ElementPropertiesWidget::setDynamicText ( DynamicElementTextItem * text)
text
◆ setElement()
void ElementPropertiesWidget::setElement ( Element * element)
overridevirtual
element
Implements AbstractElementPropertiesEditorWidget.
◆ setLiveEdit()
bool ElementPropertiesWidget::setLiveEdit ( bool live_edit)
overridevirtual
live_edittrue to enable live edit
true if live edit is enabled, else false.
◆ setTextsGroup()
void ElementPropertiesWidget::setTextsGroup ( ElementTextItemGroup * group)
group
◆ updateUi()
void ElementPropertiesWidget::updateUi ( )
overrideprivatevirtual
◆ m_diagram
Diagram* ElementPropertiesWidget::m_diagram
◆ m_general_widget
QWidget* ElementPropertiesWidget::m_general_widget
◆ m_list_editor
QList<AbstractElementPropertiesEditorWidget *> ElementPropertiesWidget::m_list_editor
◆ m_tab
QTabWidget* ElementPropertiesWidget::m_tab
