ModifyTemplateGridCommand Class Reference
#include <templatecommands.h>
Inheritance diagram for ModifyTemplateGridCommand:
Collaboration diagram for ModifyTemplateGridCommand:
 ModifyTemplateGridCommand (TitleBlockTemplate *=nullptr, QUndoCommand *=nullptr)
 ~ModifyTemplateGridCommand () override
int index () const
void setIndex (int)
QList< TitleBlockCell * > cells () const
void setCells (const QList< TitleBlockCell * > &)
TitleBlockDimension dimension () const
void setDimension (const TitleBlockDimension &)
int type () const
void setType (bool)
bool isInsertion () const
void setInsertion (bool)
void undo () override
void redo () override
Public Member Functions inherited from TitleBlockTemplateCommand
 TitleBlockTemplateCommand (TitleBlockTemplate *=nullptr, QUndoCommand *=nullptr)
 ~TitleBlockTemplateCommand () override
TitleBlockTemplate * titleBlockTemplate () const
void setTitleBlockTemplate (TitleBlockTemplate *)
TitleBlockTemplateView * view () const
void setView (TitleBlockTemplateView *)
void refreshView ()
void refreshLayout ()
static ModifyTemplateGridCommand * addRow (TitleBlockTemplate *, int=-1)
static ModifyTemplateGridCommand * addColumn (TitleBlockTemplate *, int=-1)
static ModifyTemplateGridCommand * deleteRow (TitleBlockTemplate *, int=-1)
static ModifyTemplateGridCommand * deleteColumn (TitleBlockTemplate *, int=-1)
 ModifyTemplateGridCommand (const ModifyTemplateGridCommand &)
void updateText ()
void apply (bool=false)
int index_
 Index of the inserted/deleted row/column.
QList< TitleBlockCell * > cells_
 Cells composing the inserted/deleted row/column.
bool type_
 true for a row, false for a column
TitleBlockDimension dimension_
 width/height of the column/row, which interpretation depends on type_
bool insertion_
Additional Inherited Members
Protected Attributes inherited from TitleBlockTemplateCommand
TitleBlockTemplate * tbtemplate_
 Modified TitleBlock Template.
TitleBlockTemplateView * view_
 This class may trigger a view update.
This class represents the action of adding or deleting a row or column within a title block template.
◆ ModifyTemplateGridCommand() [1/2]
ModifyTemplateGridCommand::ModifyTemplateGridCommand ( TitleBlockTemplate * tbtemplate = nullptr,
Construct a default ModifyTemplateGridCommand, i.e. a command adding a 25px row at the bottom of the template.
tbtemplateModified title block template
parentParent QUndoCommand
◆ ~ModifyTemplateGridCommand()
ModifyTemplateGridCommand::~ModifyTemplateGridCommand ( )
Destructor
◆ ModifyTemplateGridCommand() [2/2]
ModifyTemplateGridCommand::ModifyTemplateGridCommand ( const ModifyTemplateGridCommand & )
◆ addColumn()
ModifyTemplateGridCommand * ModifyTemplateGridCommand::addColumn ( TitleBlockTemplate * tbtemplate,
int index = -1 )
static
This static method is a convenience to create a ModifyTemplateGridCommand that adds a column to tbtemplate at index.
tbtemplateModified title block template.
indexIndex where the column should be inserted.
a ModifyTemplateGridCommand object, or 0 if something went wrong.
◆ addRow()
ModifyTemplateGridCommand * ModifyTemplateGridCommand::addRow ( TitleBlockTemplate * tbtemplate,
int index = -1 )
static
This static method is a convenience to create a ModifyTemplateGridCommand that adds a row to tbtemplate at index.
indexIndex where the row should be inserted.
◆ apply()
void ModifyTemplateGridCommand::apply ( bool undo = false)
◆ cells()
QList< TitleBlockCell * > ModifyTemplateGridCommand::cells ( ) const
a list of pointers to cells composing the inserted/deleted row/column.
◆ deleteColumn()
ModifyTemplateGridCommand * ModifyTemplateGridCommand::deleteColumn ( TitleBlockTemplate * tbtemplate,
int index = -1 )
static
This static method is a convenience to create a ModifyTemplateGridCommand that removes the column at index from tbtemplate.
indexIndex of the removed column.
◆ deleteRow()
ModifyTemplateGridCommand * ModifyTemplateGridCommand::deleteRow ( TitleBlockTemplate * tbtemplate,
int index = -1 )
static
This static method is a convenience to create a ModifyTemplateGridCommand that removes the row at index from tbtemplate.
indexIndex of the removed row.
◆ dimension()
TitleBlockDimension ModifyTemplateGridCommand::dimension ( ) const
the dimension of the inserted/deleted row/column.
◆ index()
int ModifyTemplateGridCommand::index ( ) const
the index of the inserted/deleted row/column
◆ isInsertion()
bool ModifyTemplateGridCommand::isInsertion ( ) const
true if the row/column is inserted, false if it is deleted
◆ redo()
void ModifyTemplateGridCommand::redo ( )
Redo the change.
◆ setCells()
void ModifyTemplateGridCommand::setCells ( const QList< TitleBlockCell * > & cells)
Set the cells composing the inserted/deleted row/column.
cellsList of pointers to cells composing the inserted/deleted row/column.
◆ setDimension()
void ModifyTemplateGridCommand::setDimension ( const TitleBlockDimension & dimension)
Set the dimension of the inserted/deleted row/column
dimensionDimension of the inserted/deleted row/column
◆ setIndex()
void ModifyTemplateGridCommand::setIndex ( int index)
Set the index of the inserted/deleted row/column.
indexIndex of the inserted/deleted row/column.
◆ setInsertion()
void ModifyTemplateGridCommand::setInsertion ( bool insertion)
insertiontrue if the row/column is inserted, false if it is deleted
◆ setType()
void ModifyTemplateGridCommand::setType ( bool type)
Indicates whether this object inserts/deletes a row or a column.
typetrue if this object is about inserting/deleting a row, false for a column.
◆ type()
int ModifyTemplateGridCommand::type ( ) const
◆ undo()
void ModifyTemplateGridCommand::undo ( )
Undo the change.
◆ updateText()
void ModifyTemplateGridCommand::updateText ( )
Update the text describing what the command does.
◆ cells_
QList<TitleBlockCell *> ModifyTemplateGridCommand::cells_
◆ dimension_
TitleBlockDimension ModifyTemplateGridCommand::dimension_
◆ index_
int ModifyTemplateGridCommand::index_
◆ insertion_
bool ModifyTemplateGridCommand::insertion_
◆ type_
bool ModifyTemplateGridCommand::type_
