TitleBlockTemplatesProjectCollection Class Reference
#include <templatescollection.h>
Inheritance diagram for TitleBlockTemplatesProjectCollection:
Collaboration diagram for TitleBlockTemplatesProjectCollection:
 TitleBlockTemplatesProjectCollection (QETProject *, QObject *parent=nullptr)
 ~TitleBlockTemplatesProjectCollection () override
QString protocol () const override
QETProject * parentProject () override
QStringList templates () override
TitleBlockTemplate * getTemplate (const QString &) override
QDomElement getTemplateXmlDescription (const QString &) override
bool setTemplateXmlDescription (const QString &, const QDomElement &) override
void removeTemplate (const QString &) override
TitleBlockTemplateLocation location (const QString &=QString()) override
bool hasFilePath () override
QString filePath () override
bool isReadOnly (const QString &=QString()) const override
virtual void fromXml (const QDomElement &)
virtual void deleteUnusedTitleBlocKTemplates ()
Public Member Functions inherited from TitleBlockTemplatesCollection
 TitleBlockTemplatesCollection (QObject *parent)
 ~TitleBlockTemplatesCollection () override
virtual void setTitle (const QString &)
 TitleBlockTemplatesCollection::setTitle.
virtual void setProtocol (const QString &)
virtual QET::QetCollection collection () const
 TitleBlockTemplatesCollection::collection.
virtual void setCollection (QET::QetCollection)
 TitleBlockTemplatesCollection::setCollection Set the storage of this collection.
virtual QList< TitleBlockTemplateLocation > templatesLocations ()
 TitleBlockTemplatesProjectCollection (const TitleBlockTemplatesProjectCollection &)
QETProject * project_
 Parent project.
QDomDocument xml_document_
 Parent QDomDocument for stored QDomElements.
QHash< QString, QDomElement > titleblock_templates_xml_
 XML descriptions of embedded titleblock templates.
Additional Inherited Members
Signals inherited from TitleBlockTemplatesCollection
void changed (TitleBlockTemplatesCollection *, const QString &=QString())
void aboutToRemove (TitleBlockTemplatesCollection *, const QString &)
Protected Attributes inherited from TitleBlockTemplatesCollection
QString title_
 Human-readable title for this collection.
QString protocol_
 Protocol used to designate this collection.
QET::QetCollection m_collection
QHash< QString, TitleBlockTemplate * > titleblock_templates_
 Already parsed embedded titleblock templates.
This class represents a simple abastraction layer for a collection of title block templates embedded within a project.
◆ TitleBlockTemplatesProjectCollection() [1/2]
TitleBlockTemplatesProjectCollection::TitleBlockTemplatesProjectCollection ( QETProject * project,
QObject * parent = nullptr )
Constructor
projectParent project
parentParent QObject
◆ ~TitleBlockTemplatesProjectCollection()
TitleBlockTemplatesProjectCollection::~TitleBlockTemplatesProjectCollection ( )
Destructor
◆ TitleBlockTemplatesProjectCollection() [2/2]
TitleBlockTemplatesProjectCollection::TitleBlockTemplatesProjectCollection ( const TitleBlockTemplatesProjectCollection & )
◆ deleteUnusedTitleBlocKTemplates()
void TitleBlockTemplatesProjectCollection::deleteUnusedTitleBlocKTemplates ( )
virtual
Delete all title block templates not used within the parent project
◆ filePath()
QString TitleBlockTemplatesProjectCollection::filePath ( )
overridevirtual
always an empty string since a project collection is not stored on any filesystem.
Implements TitleBlockTemplatesCollection.
◆ fromXml()
void TitleBlockTemplatesProjectCollection::fromXml ( const QDomElement & xml_element)
virtual
xml_elementXML element to be parsed to load title block templates
◆ getTemplate()
TitleBlockTemplate * TitleBlockTemplatesProjectCollection::getTemplate ( const QString & template_name)
overridevirtual
template_nameName of the requested template
the requested template, or 0 if there is no valid template of this name within the project
◆ getTemplateXmlDescription()
QDomElement TitleBlockTemplatesProjectCollection::getTemplateXmlDescription ( const QString & template_name)
overridevirtual
the XML description of the requested template, or a null QDomElement if the project does not have such an titleblock template
◆ hasFilePath()
bool TitleBlockTemplatesProjectCollection::hasFilePath ( )
overridevirtual
always false since a project collection is not stored on any filesystem.
◆ isReadOnly()
bool TitleBlockTemplatesProjectCollection::isReadOnly ( const QString & template_name = QString()) const
overridevirtual
template_nameEither an empty QString to know whether the collection itself is read only, or a specific template name.
true if the specified template is read only, false otherwise
◆ location()
TitleBlockTemplateLocation TitleBlockTemplatesProjectCollection::location ( const QString & template_name = QString())
overridevirtual
the location object for the requested template
◆ parentProject()
QETProject * TitleBlockTemplatesProjectCollection::parentProject ( )
overridevirtual
the parent project of this project collection
Reimplemented from TitleBlockTemplatesCollection.
◆ protocol()
QString TitleBlockTemplatesProjectCollection::protocol ( ) const
overridevirtual
the protocol used to mention this collection
◆ removeTemplate()
void TitleBlockTemplatesProjectCollection::removeTemplate ( const QString & template_name)
overridevirtual
This methods allows removing a template embedded within the project. This method emits the signal changed() if necessary.
template_nameName of the template to be removed
◆ setTemplateXmlDescription()
bool TitleBlockTemplatesProjectCollection::setTemplateXmlDescription ( const QString & template_name,
const QDomElement & xml_elmt )
overridevirtual
This methods allows adding or modifying a template embedded within the project. This method emits the signal changed() if necessary.
template_nameName / Identifier of the template - will be used to determine whether the given description will be added or will replace an existing one.
xml_elmtAn <titleblocktemplate> XML element describing the template. Its "name" attribute must equal to template_name.
false if a problem occurred, true otherwise
◆ templates()
QStringList TitleBlockTemplatesProjectCollection::templates ( )
overridevirtual
the list of title block templates embedded within the project.
◆ title()
QString TitleBlockTemplatesProjectCollection::title ( ) const
overridevirtual
a human readable title for this collection
◆ project_
QETProject* TitleBlockTemplatesProjectCollection::project_
Parent project.
◆ titleblock_templates_xml_
QHash<QString, QDomElement> TitleBlockTemplatesProjectCollection::titleblock_templates_xml_
◆ xml_document_
QDomDocument TitleBlockTemplatesProjectCollection::xml_document_
