AutoNumberingDockWidget Class Reference
#include <autonumberingdockwidget.h>
Inherits QDockWidget.
Collaboration diagram for AutoNumberingDockWidget:
struct  Row
Public Slots
void setActive ()
 AutoNumberingDockWidget::setActive Set current used autonumberings.
void setConductorActive (DiagramView *)
 AutoNumberingDockWidget::setConductorActive.
 AutoNumberingDockWidget (QWidget *parent=nullptr)
 AutoNumberingDockWidget::AutoNumberingDockWidget Constructor.
 ~AutoNumberingDockWidget () override
 AutoNumberingDockWidget::~AutoNumberingDockWidget Destructor.
void setContext ()
 AutoNumberingDockWidget::setContext Add all itens to comboboxes.
void setProject (QETProject *, ProjectView *)
 AutoNumberingDockWidget::setProject.
Private Types
enum class  AutoNumCategory { Conductor , Element , Folio }
Private Slots
void on_m_conductor_cb_activated (int)
 AutoNumberingDockWidget::on_m_conductor_cb_activated Set new conductor AutoNum.
void on_m_element_cb_activated (int)
 AutoNumberingDockWidget::on_m_element_cb_activated Set new element AutoNum.
void on_m_folio_cb_activated (int)
 AutoNumberingDockWidget::on_m_folio_cb_activated Set new folio AutoNum.
void conductorAutoNumChanged ()
 AutoNumberingDockWidget::conductorAutoNumChanged Add new or remove conductor auto num from combobox.
void elementAutoNumChanged ()
 AutoNumberingDockWidget::elementAutoNumChanged Add new or remove element auto num from combobox.
void folioAutoNumChanged ()
 AutoNumberingDockWidget::folioAutoNumChanged Add new or remove folio auto num from combobox.
void clear ()
 AutoNumberingDockWidget::clear Remove all combo box values.
void projectClosed ()
void refreshValueFields ()
 AutoNumberingDockWidget::refreshValueFields Re-read all three value fields from the project. Called whenever a numerotation context's values change, which includes every element or conductor that consumes the next number – without this the field only caught up when the user re-picked a rule from the combo box, because the combo's activated() signal fires on user interaction alone.
void on_m_configure_pb_clicked ()
void on_m_conductor_reset_start_pb_clicked ()
void on_m_element_reset_start_pb_clicked ()
void on_m_folio_reset_start_pb_clicked ()
void on_m_conductor_value_le_editingFinished ()
void on_m_element_value_le_editingFinished ()
void on_m_folio_value_le_editingFinished ()
void on_m_conductor_increase_sb_valueChanged (int)
void on_m_element_increase_sb_valueChanged (int)
void on_m_folio_increase_sb_valueChanged (int)
Row rowFor (AutoNumCategory category) const
 AutoNumberingDockWidget::rowFor.
void resetAutoNum (QComboBox *combo_box, AutoNumCategory category)
 resetAutoNum Reset the numerotation context currently selected in combo_box (for the given category) to a per-type starting value. Does nothing if no context is selected.
NumerotationContext contextFor (QComboBox *combo_box, AutoNumCategory category) const
 Read/write the numerotation context named in combo_box.
void storeContext (QComboBox *combo_box, AutoNumCategory category, const NumerotationContext &context)
 AutoNumberingDockWidget::storeContext Write context back under the name selected in combo_box and flag the project as modified – without that last step the change is not saved and the user is never asked to save it on close.
void refreshValueField (QComboBox *combo_box, QLineEdit *line_edit, AutoNumCategory category)
 Refresh a value field from its context, and apply a typed value.
void applyValueField (QComboBox *combo_box, QLineEdit *line_edit, AutoNumCategory category)
 AutoNumberingDockWidget::applyValueField Write the value typed in line_edit to the counter it displays. An empty field is treated as "no change" rather than as an empty value, so clearing the box by accident cannot wipe the counter.
void refreshIncreaseField (QComboBox *combo_box, QSpinBox *increase_sb, AutoNumCategory category)
 Refresh/apply the increment spin box the same way.
void applyIncreaseField (QComboBox *combo_box, QSpinBox *increase_sb, AutoNumCategory category)
 AutoNumberingDockWidget::applyIncreaseField Write the spin box's step size to the counter it displays (bug #331).
void refreshNextField (QComboBox *combo_box, QLineEdit *next_edit, AutoNumCategory category)
 AutoNumberingDockWidget::refreshNextField Show what this counter will read after one more step (bug #331: "visualiser la prochaine numérotation qui sera appliquée"). Advances a copy of the whole context through NumerotationContextCommands – the same engine the Suivant button in the full configuration dialog uses to step a context – so wrap-and-carry into this part from a following part, or out of it into a preceding one, comes out identical to what will actually happen when the number is next consumed.
void refreshRow (AutoNumCategory category)
 AutoNumberingDockWidget::refreshRow Refresh a category's value, increment and next-value preview together – every call site that used to refresh just the value field needs the other two kept in step with it as well.
static int counterIndex (const NumerotationContext &context)
 AutoNumberingDockWidget::counterIndex.
Ui::AutoNumberingDockWidget * ui
QETProject * m_project = nullptr
ProjectView * m_project_view = nullptr
◆ AutoNumCategory
enum class AutoNumberingDockWidget::AutoNumCategory
strongprivate
Enumerator
Conductor
Element
Folio
◆ AutoNumberingDockWidget()
AutoNumberingDockWidget::AutoNumberingDockWidget ( QWidget * parent = nullptr)
explicit
parent: parent widget
◆ ~AutoNumberingDockWidget()
AutoNumberingDockWidget::~AutoNumberingDockWidget ( )
◆ applyIncreaseField()
void AutoNumberingDockWidget::applyIncreaseField ( QComboBox * combo_box,
QSpinBox * increase_sb,
AutoNumCategory category )
◆ applyValueField()
void AutoNumberingDockWidget::applyValueField ( QComboBox * combo_box,
QLineEdit * line_edit,
◆ clear
void AutoNumberingDockWidget::clear ( )
privateslot
◆ conductorAutoNumChanged
void AutoNumberingDockWidget::conductorAutoNumChanged ( )
privateslot
◆ contextFor()
NumerotationContext AutoNumberingDockWidget::contextFor ( QComboBox * combo_box,
AutoNumCategory category ) const
AutoNumberingDockWidget::contextFor.
the numerotation context named by combo_box, for category
◆ counterIndex()
int AutoNumberingDockWidget::counterIndex ( const NumerotationContext & context)
staticprivate
Index of the counter the value field shows and edits: the last part that actually progresses. Returns -1 when the context has no such part (e.g. it is only fixed text).
the index of the part the value field shows: the last one that actually progresses, i.e. the least significant digit of the number. -1 when the context has no progressing part at all.
◆ elementAutoNumChanged
void AutoNumberingDockWidget::elementAutoNumChanged ( )
privateslot
◆ folioAutoNumChanged
void AutoNumberingDockWidget::folioAutoNumChanged ( )
privateslot
◆ on_m_conductor_cb_activated
void AutoNumberingDockWidget::on_m_conductor_cb_activated ( int )
privateslot
◆ on_m_conductor_increase_sb_valueChanged
void AutoNumberingDockWidget::on_m_conductor_increase_sb_valueChanged ( int )
privateslot
◆ on_m_conductor_reset_start_pb_clicked
void AutoNumberingDockWidget::on_m_conductor_reset_start_pb_clicked ( )
privateslot
◆ on_m_conductor_value_le_editingFinished
void AutoNumberingDockWidget::on_m_conductor_value_le_editingFinished ( )
privateslot
◆ on_m_configure_pb_clicked
void AutoNumberingDockWidget::on_m_configure_pb_clicked ( )
privateslot
◆ on_m_element_cb_activated
void AutoNumberingDockWidget::on_m_element_cb_activated ( int )
privateslot
◆ on_m_element_increase_sb_valueChanged
void AutoNumberingDockWidget::on_m_element_increase_sb_valueChanged ( int )
privateslot
◆ on_m_element_reset_start_pb_clicked
void AutoNumberingDockWidget::on_m_element_reset_start_pb_clicked ( )
privateslot
◆ on_m_element_value_le_editingFinished
void AutoNumberingDockWidget::on_m_element_value_le_editingFinished ( )
privateslot
◆ on_m_folio_cb_activated
void AutoNumberingDockWidget::on_m_folio_cb_activated ( int )
privateslot
◆ on_m_folio_increase_sb_valueChanged
void AutoNumberingDockWidget::on_m_folio_increase_sb_valueChanged ( int )
privateslot
◆ on_m_folio_reset_start_pb_clicked
void AutoNumberingDockWidget::on_m_folio_reset_start_pb_clicked ( )
privateslot
◆ on_m_folio_value_le_editingFinished
void AutoNumberingDockWidget::on_m_folio_value_le_editingFinished ( )
privateslot
◆ projectClosed
void AutoNumberingDockWidget::projectClosed ( )
privateslot
◆ refreshIncreaseField()
void AutoNumberingDockWidget::refreshIncreaseField ( QComboBox * combo_box,
AutoNumberingDockWidget::refreshIncreaseField Show the counter's current step size (bug #331: previously only reachable from the full configuration dialog, via "Configurer").
◆ refreshNextField()
void AutoNumberingDockWidget::refreshNextField ( QComboBox * combo_box,
QLineEdit * next_edit,
Show what the counter will read after one more step, using the same NumerotationContextCommands engine the Suivant button in the full configuration dialog already advances the whole context with – so the preview can never disagree with what actually happens when the number is next consumed.
◆ refreshRow()
void AutoNumberingDockWidget::refreshRow ( AutoNumCategory category)
Refresh a whole row – value, increment and next-value preview – in one call. Every refresh call site needs the increment and preview kept in step with the value now, so this replaces refreshValueField() at each of them.
◆ refreshValueField()
void AutoNumberingDockWidget::refreshValueField ( QComboBox * combo_box,
AutoNumberingDockWidget::refreshValueField Show the current value of the selected context's counter, so the field always reflects where the numbering has actually got to.
◆ refreshValueFields
void AutoNumberingDockWidget::refreshValueFields ( )
privateslot
◆ resetAutoNum()
void AutoNumberingDockWidget::resetAutoNum ( QComboBox * combo_box,
AutoNumberingDockWidget::resetAutoNum Reset the numerotation context currently selected in combo_box back to a per-type starting value, then write it back. Does nothing if no context is selected.
Only parts that actually progress are touched: folio-anchored numeric types go back to their own stored initialvalue, plain numeric types go back to "1", a wrap part goes back to "0" because a modulo counter cycles over [0, modulus) – a PLC card addressed IX0.0..IX0.31 starts at 0, not 1 – and alpha goes back to "a". Non-incrementing types (string, plant, locmach, idfolio, folio, elementline, elementcolumn, elementprefix) are left alone: there is no "start" for them distinct from the fixed or contextual value the user configured.
◆ rowFor()
AutoNumberingDockWidget::Row AutoNumberingDockWidget::rowFor ( AutoNumCategory category) const
the combo/value/increase/next widgets that make up category's row.
◆ setActive
void AutoNumberingDockWidget::setActive ( )
slot
◆ setConductorActive
void AutoNumberingDockWidget::setConductorActive ( DiagramView * dv)
slot
dvactivated diagramview
◆ setContext()
void AutoNumberingDockWidget::setContext ( )
◆ setProject()
void AutoNumberingDockWidget::setProject ( QETProject * project,
ProjectView * projectview )
projectproject to be setted
projectviewprojectview to be setted assign Project and ProjectView, connect all signals and setContext
◆ storeContext()
void AutoNumberingDockWidget::storeContext ( QComboBox * combo_box,
const NumerotationContext & context )
◆ m_project
QETProject* AutoNumberingDockWidget::m_project = nullptr
◆ m_project_view
ProjectView* AutoNumberingDockWidget::m_project_view = nullptr
◆ ui
Ui::AutoNumberingDockWidget* AutoNumberingDockWidget::ui
