ProjectView Class Reference
The ProjectView class This class provides a widget displaying the diagrams of a particular project using tabs. More...
#include <projectview.h>
Inherits QWidget.
Collaboration diagram for ProjectView:
Public Slots
void removeDiagram (DiagramView *diagram_view, bool silent=false)
 ProjectView::removeDiagram Remove a diagram (folio) of the project.
void removeDiagram (Diagram *diagram, bool silent=false)
void showDiagram (DiagramView *)
void showDiagram (Diagram *)
void editProjectProperties ()
void editCurrentDiagramProperties ()
void editDiagramProperties (DiagramView *)
void editDiagramProperties (Diagram *)
void moveDiagramUp (DiagramView *)
void moveDiagramUp (Diagram *)
void moveDiagramDown (DiagramView *)
void moveDiagramDown (Diagram *)
void moveDiagramUpTop (DiagramView *)
void moveDiagramUpTop (Diagram *)
void moveDiagramUpx10 (DiagramView *)
void moveDiagramUpx10 (Diagram *)
void moveDiagramDownx10 (DiagramView *)
void moveDiagramDownx10 (Diagram *)
void moveDiagramUpx100 (DiagramView *)
 ProjectView::moveDiagramUpx100 Moves the diagram_view up / left x100.
void moveDiagramUpx100 (Diagram *)
 ProjectView::moveDiagramUpx100 Moves the diagram up / left x100.
void moveDiagramDownx100 (DiagramView *)
 ProjectView::moveDiagramDownx100 Moves the diagram_view down / right x100.
void moveDiagramDownx100 (Diagram *)
 ProjectView::moveDiagramDownx100 Moves the diagram down / right x100.
void exportProject ()
QETResult save ()
QETResult saveAs ()
QETResult doSave ()
int cleanProject ()
void updateWindowTitle ()
 ProjectView::updateWindowTitle Update the project view title.
void updateTabTitle (DiagramView *)
 ProjectView::updateTabTitle Update the title of the tab which display the diagram view.
void updateAllTabsTitle ()
 ProjectView::updateAllTabsTitle Update all tabs title.
void tabMoved (int, int)
Signals
void diagramAdded (DiagramView *)
void diagramRemoved (DiagramView *)
void diagramActivated (DiagramView *)
void projectClosed (ProjectView *)
void errorEncountered (const QString &)
void findElementRequired (const ElementsLocation &)
 ProjectView (QETProject *, QWidget *=nullptr)
 ~ProjectView () override
QETProject * project ()
QList< DiagramView * > diagram_views () const
DiagramView * currentDiagram () const
 ProjectView::currentDiagram.
void closeEvent (QCloseEvent *) override
void changeTabUp ()
 change current diagramview to previous tab
void changeTabDown ()
 change current diagramview to next folio
void changeFirstTab ()
 change current diagramview to first tab
void changeLastTab ()
 change current diagramview to last tab
void setDiagramPosition (Diagram *diagram, int new_position)
 ProjectView::setDiagramPosition Move diagram's tab to new_position (out-of-range values are clamped by the underlying tab bar, same as a direct QTabBar::moveTab() call). Used by MoveDiagramCommand for both redo and undo.
Private Slots
void tabChanged (int)
 ProjectView::tabChanged Manage the tab change. If tab_id == -1 (there is no diagram opened), we display the fallback widget.
void tabDoubleClicked (int)
void setDisplayFallbackWidget (bool)
void adjustReadOnlyState ()
void diagramAdded (Diagram *diagram)
 ProjectView::diagramAdded Slot called when qetproject emit diagramAdded.
void diagramRemoved (Diagram *diagram)
 ProjectView::diagramRemoved Slot called when the project emits diagramRemoved (either from a direct, non-undoable QETProject::removeDiagram() call, or – the normal UI path – from a RemoveDiagramCommand's redo()/undo()). Tears down the tab and DiagramView for the given diagram; the diagram itself is left untouched, since by this point it has already been detached (and possibly parked for undo) by the caller.
 ProjectView (const ProjectView &)
void setProject (QETProject *project)
 ProjectView::setProject Set the project display by the project view.
void initActions ()
void initWidgets ()
void initLayout ()
void loadDiagrams ()
 ProjectView::loadDiagrams Load diagrams of project. We create a diagram view for each diagram, and add it to the project view.
DiagramView * findDiagram (Diagram *)
DiagramView * nextDiagram ()
DiagramView * previousDiagram ()
DiagramView * firstDiagram ()
DiagramView * lastDiagram ()
void rebuildDiagramsMap ()
bool tryClosing ()
bool tryClosingElementEditors ()
int tryClosingDiagrams ()
 ProjectView::tryClosingDiagrams try to close this project, if diagram or project option are changed a dialog ask if user want to save the modification.
QString askUserForFilePath (bool=true)
QETResult noProjectResult () const
QAction * m_add_new_diagram
QAction * m_first_view
QAction * m_end_view
QAction * m_next_view_left
QAction * m_next_view_right
QETProject * m_project
QVBoxLayout * layout_
QWidget * fallback_widget_
QLabel * fallback_label_
QTabWidget * m_tab
QMap< int, DiagramView * > m_diagram_ids
int m_previous_tab_index = -1
QList< DiagramView * > m_diagram_view_list
◆ ProjectView() [1/2]
ProjectView::ProjectView ( QETProject * project,
QWidget * parent = nullptr )
Constructeur
projectprojet a visualiser
parentWidget parent
◆ ~ProjectView()
ProjectView::~ProjectView ( )
Destructeur Supprime les DiagramView embarquees
◆ ProjectView() [2/2]
ProjectView::ProjectView ( const ProjectView & )
◆ adjustReadOnlyState
void ProjectView::adjustReadOnlyState ( )
privateslot
Effectue les actions necessaires lorsque le projet visualise entre ou sort du mode lecture seule.
◆ askUserForFilePath()
QString ProjectView::askUserForFilePath ( bool assign = true)
Ask the user to provide a file path in which the currently edited project will be saved.
assignWhen true, assign the provided filepath to the project through setFilePath(). Defaults to true.
the file path, or an empty string if none were provided
◆ changeFirstTab()
void ProjectView::changeFirstTab ( )
◆ changeLastTab()
void ProjectView::changeLastTab ( )
◆ changeTabDown()
void ProjectView::changeTabDown ( )
◆ changeTabUp()
void ProjectView::changeTabUp ( )
◆ cleanProject
int ProjectView::cleanProject ( )
slot
Allow the user to clean the project, which includes: deleting unused title block templates deleting unused elements deleting empty categories
an integer value above zero if elements and/or categories were cleaned.
◆ closeEvent()
void ProjectView::closeEvent ( QCloseEvent * qce)
Gere la fermeture du schema.
qceLe QCloseEvent decrivant l'evenement
◆ currentDiagram()
DiagramView * ProjectView::currentDiagram ( ) const
The current active diagram view or nullptr if there isn't diagramView in this project view.
◆ diagram_views()
QList< DiagramView * > ProjectView::diagram_views ( ) const
la liste des schemas ouverts dans le projet
◆ diagramActivated
void ProjectView::diagramActivated ( DiagramView * )
signal
◆ diagramAdded [1/2]
void ProjectView::diagramAdded ( Diagram * diagram)
privateslot
diagram
◆ diagramAdded [2/2]
void ProjectView::diagramAdded ( DiagramView * )
signal
◆ diagramRemoved [1/2]
void ProjectView::diagramRemoved ( Diagram * diagram)
privateslot
diagram
◆ diagramRemoved [2/2]
void ProjectView::diagramRemoved ( DiagramView * )
signal
◆ doSave
QETResult ProjectView::doSave ( )
slot
Save project content, then write the project file. May call saveAs if no filepath was provided before.
a QETResult object reflecting the situation; note that a valid QETResult object is returned if the operation was cancelled.
◆ editCurrentDiagramProperties
void ProjectView::editCurrentDiagramProperties ( )
slot
Edite les proprietes du schema courant
◆ editDiagramProperties [1/2]
void ProjectView::editDiagramProperties ( Diagram * diagram)
slot
Edite les proprietes du schema diagram
◆ editDiagramProperties [2/2]
void ProjectView::editDiagramProperties ( DiagramView * diagram_view)
slot
Edite les proprietes du schema diagram_view
◆ editProjectProperties
void ProjectView::editProjectProperties ( )
slot
Enable the user to edit properties of the current project through a configuration dialog.
◆ errorEncountered
void ProjectView::errorEncountered ( const QString & )
signal
◆ exportProject
void ProjectView::exportProject ( )
slot
Exporte le schema.
◆ findDiagram()
DiagramView * ProjectView::findDiagram ( Diagram * diagram)
diagramSchema a trouver
le DiagramView correspondant au schema passe en parametre, ou 0 si le schema n'est pas trouve
◆ findElementRequired
void ProjectView::findElementRequired ( const ElementsLocation & )
signal
◆ firstDiagram()
DiagramView * ProjectView::firstDiagram ( )
first folio of current project, or nullptr if the project has no diagram.
◆ initActions()
void ProjectView::initActions ( )
Initialize actions for this widget.
◆ initLayout()
void ProjectView::initLayout ( )
Initialize layout for this widget.
◆ initWidgets()
void ProjectView::initWidgets ( )
Initialize child widgets for this widget.
◆ lastDiagram()
DiagramView * ProjectView::lastDiagram ( )
last folio of current project
◆ loadDiagrams()
void ProjectView::loadDiagrams ( )
◆ moveDiagramDown [1/2]
void ProjectView::moveDiagramDown ( Diagram * diagram)
slot
Deplace le schema diagram vers le bas / la droite
◆ moveDiagramDown [2/2]
void ProjectView::moveDiagramDown ( DiagramView * diagram_view)
slot
Deplace le schema diagram_view vers le bas / la droite
◆ moveDiagramDownx10 [1/2]
void ProjectView::moveDiagramDownx10 ( Diagram * diagram)
slot
Deplace le schema diagram vers le bas / la droite x10
◆ moveDiagramDownx10 [2/2]
void ProjectView::moveDiagramDownx10 ( DiagramView * diagram_view)
slot
Deplace le schema diagram_view vers le bas / la droite x10
◆ moveDiagramDownx100 [1/2]
void ProjectView::moveDiagramDownx100 ( Diagram * diagram)
slot
diagramDiagram to move
◆ moveDiagramDownx100 [2/2]
void ProjectView::moveDiagramDownx100 ( DiagramView * diagram_view)
slot
diagram_viewView to move
◆ moveDiagramUp [1/2]
void ProjectView::moveDiagramUp ( Diagram * diagram)
slot
Deplace le schema diagram vers le haut / la gauche
◆ moveDiagramUp [2/2]
void ProjectView::moveDiagramUp ( DiagramView * diagram_view)
slot
Deplace le schema diagram_view vers le haut / la gauche
◆ moveDiagramUpTop [1/2]
void ProjectView::moveDiagramUpTop ( Diagram * diagram)
slot
◆ moveDiagramUpTop [2/2]
void ProjectView::moveDiagramUpTop ( DiagramView * diagram_view)
slot
◆ moveDiagramUpx10 [1/2]
void ProjectView::moveDiagramUpx10 ( Diagram * diagram)
slot
Deplace le schema diagram vers le haut / la gauche x10
◆ moveDiagramUpx10 [2/2]
void ProjectView::moveDiagramUpx10 ( DiagramView * diagram_view)
slot
Deplace le schema diagram_view vers le haut / la gauche x10
◆ moveDiagramUpx100 [1/2]
void ProjectView::moveDiagramUpx100 ( Diagram * diagram)
slot
◆ moveDiagramUpx100 [2/2]
void ProjectView::moveDiagramUpx100 ( DiagramView * diagram_view)
slot
◆ nextDiagram()
DiagramView * ProjectView::nextDiagram ( )
next folio of current diagramview
◆ noProjectResult()
QETResult ProjectView::noProjectResult ( ) const
the QETResult object to be returned when it appears this project view is not associated to any project.
◆ previousDiagram()
DiagramView * ProjectView::previousDiagram ( )
previous folio of current diagramview
◆ project()
QETProject * ProjectView::project ( )
le projet actuellement visualise par le ProjectView
◆ projectClosed
void ProjectView::projectClosed ( ProjectView * )
signal
◆ rebuildDiagramsMap()
void ProjectView::rebuildDiagramsMap ( )
Reconstruit la map associant les index des onglets avec les DiagramView
◆ removeDiagram [1/2]
void ProjectView::removeDiagram ( Diagram * diagram,
bool silent = false )
slot
Enleve un schema du ProjectView
diagramSchema a enlever
silentSi vrai, supprime sans demander confirmation
◆ removeDiagram [2/2]
void ProjectView::removeDiagram ( DiagramView * diagram_view,
slot
diagram_view: diagram view to remove
silent: if true, bypasses the confirmation message box
◆ save
QETResult ProjectView::save ( )
slot
Save project properties along with all modified diagrams.
See also
filePath()
setFilePath()
◆ saveAs
QETResult ProjectView::saveAs ( )
slot
Ask users for a filepath in order to save the project.
optionsMay be used to specify what should be saved; defaults to all modified diagrams.
◆ setDiagramPosition()
void ProjectView::setDiagramPosition ( Diagram * diagram,
int new_position )
tabMoved() – the slot that normally keeps the project's diagram list in sync with the tab bar – is connected with Qt::QueuedConnection (needed so interactive drag-and-drop reordering settles before the model updates). That queued call would run a second, redundant diagramOrderChanged() after this method already performed it synchronously, so that one connection is temporarily dropped around the move (blocking all of the tab bar's signals instead would also suppress QTabWidget's own internal tabMoved connection, which is what keeps its page stack in the same order as the tab bar – breaking the move visually).
diagram
new_position
◆ setDisplayFallbackWidget
void ProjectView::setDisplayFallbackWidget ( bool fallback)
privateslot
fallbacktrue pour afficher le widget de fallback, false pour afficher les onglets. Le widget de Fallback est le widget affiche lorsque le projet ne comporte aucun schema.
◆ setProject()
void ProjectView::setProject ( QETProject * project)
project
◆ showDiagram [1/2]
void ProjectView::showDiagram ( Diagram * diagram)
slot
Active l'onglet adequat pour afficher le schema passe en parametre
diagramSchema a afficher
◆ showDiagram [2/2]
void ProjectView::showDiagram ( DiagramView * diagram)
slot
◆ tabChanged
void ProjectView::tabChanged ( int tab_id)
privateslot
tab_id
◆ tabDoubleClicked
void ProjectView::tabDoubleClicked ( int tab_id)
privateslot
Gere le double-clic sur un onglet : edite les proprietes du schema
tab_idIndex de l'onglet concerne
◆ tabMoved
void ProjectView::tabMoved ( int from,
int to )
slot
fromIndex de l'onglet avant le deplacement
toIndex de l'onglet apres le deplacement
◆ tryClosing()
bool ProjectView::tryClosing ( )
Cette methode essaye de fermer successivement les editeurs d'element puis les schemas du projet. L'utilisateur peut refuser de fermer un schema ou un editeur.
true si tout a pu etre ferme, false sinon
See also
tryClosingElementEditors()
tryClosingDiagrams()
◆ tryClosingDiagrams()
int ProjectView::tryClosingDiagrams ( )
the answer of dialog or discard if no change.
◆ tryClosingElementEditors()
bool ProjectView::tryClosingElementEditors ( )
Un projet comporte des elements integres. Cette methode ferme les editeurs d'elements associes a ce projet. L'utilisateur peut refuser la fermeture d'un editeur d'element.
true si tous les editeurs d'element ont pu etre fermes, false sinon
◆ updateAllTabsTitle
void ProjectView::updateAllTabsTitle ( )
slot
◆ updateTabTitle
void ProjectView::updateTabTitle ( DiagramView * diagram_view)
slot
diagram_view: The diagram view.
◆ updateWindowTitle
void ProjectView::updateWindowTitle ( )
slot
◆ fallback_label_
QLabel* ProjectView::fallback_label_
◆ fallback_widget_
QWidget* ProjectView::fallback_widget_
◆ layout_
QVBoxLayout* ProjectView::layout_
◆ m_add_new_diagram
QAction* ProjectView::m_add_new_diagram
◆ m_diagram_ids
QMap<int, DiagramView *> ProjectView::m_diagram_ids
◆ m_diagram_view_list
QList<DiagramView *> ProjectView::m_diagram_view_list
◆ m_end_view
QAction * ProjectView::m_end_view
◆ m_first_view
QAction * ProjectView::m_first_view
◆ m_next_view_left
QAction * ProjectView::m_next_view_left
◆ m_next_view_right
QAction * ProjectView::m_next_view_right
◆ m_previous_tab_index
int ProjectView::m_previous_tab_index = -1
◆ m_project
QETProject* ProjectView::m_project
◆ m_tab
QTabWidget* ProjectView::m_tab
