RemoveDiagramCommand Class Reference
The RemoveDiagramCommand class Undo/redo support for removing a folio (diagram) from a project. redo() detaches the diagram from the project (and, reactively, its ProjectView tab) without destroying it; undo() reinserts it at its original position. The diagram is only actually destroyed when this command itself is destroyed while the diagram is detached (i.e. while the removal is still in effect). More...
#include <removediagramcommand.h>
Inherits QUndoCommand.
Collaboration diagram for RemoveDiagramCommand:
 RemoveDiagramCommand (QETProject *project, Diagram *diagram, QUndoCommand *parent=nullptr)
 RemoveDiagramCommand::RemoveDiagramCommand.
 ~RemoveDiagramCommand () override
 RemoveDiagramCommand::~RemoveDiagramCommand Destroy the diagram only if it is currently detached from the project (i.e. the removal is currently in effect) – otherwise the project owns it and will destroy it itself.
void undo () override
void redo () override
QPointer< QETProject > m_project
Diagram * m_diagram
int m_position
bool m_owns_diagram = false
 true while the diagram is detached from the project (i.e. the removal is in effect)
◆ RemoveDiagramCommand()
RemoveDiagramCommand::RemoveDiagramCommand ( QETProject * project,
Diagram * diagram,
project: project the diagram is removed from
diagram: the diagram to remove, currently part of project
parent
◆ ~RemoveDiagramCommand()
RemoveDiagramCommand::~RemoveDiagramCommand ( )
◆ redo()
void RemoveDiagramCommand::redo ( )
◆ undo()
void RemoveDiagramCommand::undo ( )
◆ m_diagram
Diagram* RemoveDiagramCommand::m_diagram
◆ m_owns_diagram
bool RemoveDiagramCommand::m_owns_diagram = false
◆ m_position
int RemoveDiagramCommand::m_position
◆ m_project
QPointer<QETProject> RemoveDiagramCommand::m_project
