anonymous_namespace{diagram.cpp} Namespace Reference
Functions
QString elementSortKey (Element *elmt)
QString terminalSortKey (Terminal *terminal)
QString conductorSortKey (Conductor *cond)
QString positionKey (const QPointF &pos)
Function Documentation
◆ conductorSortKey()
QString anonymous_namespace{diagram.cpp}::conductorSortKey ( Conductor * cond)
Sort key for Diagram::toXml()'s <conductors> block. Built from both endpoints' terminalSortKey(), not Conductor::uuid(): in every example project checked, conductors have no persisted uuid attribute at all, so uuid() is a freshly-minted random value on every load – exactly as unusable for cross-run determinism as the element case above, just with no persisted fallback to reach for instead. Canonicalised (smaller key first) since a conductor's two ends are unordered for this purpose.
◆ elementSortKey()
QString anonymous_namespace{diagram.cpp}::elementSortKey ( Element * elmt)
Sort key for Diagram::toXml()'s <elements> block: the element's own diagram-local position, exactly what it's already saved as (x/y), never invented or regenerated. uuid() is deliberately NOT used here: for an element with no persisted uuid attribute, fromXml() invents a fresh random one on every load, so sorting by uuid would still be non-deterministic across process runs for any legacy file.
◆ positionKey()
QString DiagramSortKeys::positionKey ( const QPointF & pos)
inline
◆ terminalSortKey()
QString anonymous_namespace{diagram.cpp}::terminalSortKey ( Terminal * terminal)
Sort key for a terminal: its parent element's position, then the terminal's own position local to that element (from the .elmt definition, fixed regardless of where the element is placed).
