The ProjectDBModel class This model is intended to be use with the class projectDataBase and is designed to be displayed by the class QetGraphicsTableItem (but can be use by other view class since it inherit from QAbstractTableModel). This class should be sufficient to display the content of the project data base from a query set by the method void ProjectDBModel::setQuery(const QString &query). The indentifier method is used by widget editor to retrieve the good widget for edit the query. By default identifer returns the string 'unknow'. You should use setIdentfier method to set your custom identifier. At the time this sentence is written, there is two identifier : nomenclature summary.
More...
#include <projectdbmodel.h>
Inherits QAbstractTableModel.
| | ProjectDBModel (QETProject *project, QObject *parent=nullptr) |
| | ProjectDBModel::ProjectDBModel.
| | ProjectDBModel (const ProjectDBModel &other_model) |
| int | rowCount (const QModelIndex &parent=QModelIndex()) const override |
| | ProjectDBModel::rowCount Reimplemented for QAbstractTableModel.
| int | columnCount (const QModelIndex &parent=QModelIndex()) const override |
| | ProjectDBModel::columnCount Reimplemented for QAbstractTableModel.
| bool | setHeaderData (int section, Qt::Orientation orientation, const QVariant &value, int role=Qt::EditRole) override |
| | ProjectDBModel::setHeaderData Reimplemented from QAbstractTableModel. Only horizontal orientation is accepted.
| QVariant | headerData (int section, Qt::Orientation orientation, int role=Qt::DisplayRole) const override |
| | ProjectDBModel::headerData Reimplemented from QAbstractTableModel.
| bool | setData (const QModelIndex &index, const QVariant &value, int role=Qt::EditRole) override |
| | ProjectDBModel::setData Only store the data for the index 0.0.
| QVariant | data (const QModelIndex &index, int role=Qt::DisplayRole) const override |
| | ProjectDBModel::data Reimplemented for QAbstractTableModel.
| void | setQuery (const QString &setQuery) |
| | ProjectDBModel::setQuery Query the internal bd with query.
| QString | queryString () const |
| | ProjectDBModel::queryString.
| QETProject * | project () const |
| QDomElement | toXml (QDomDocument &document) const |
| | ProjectDBModel::toXml Save the model to xml,since model can have unlimited data we only save few data (only these used by qelectrotech). The query, all header data. and some data of index::(0,0). All other data are not saved.
| void | fromXml (const QDomElement &element) |
| | ProjectDBModel::fromXml Restore the model from xml.
| void | setIdentifier (const QString &identifier) |
| | ProjectDBModel::setIdentifier Set the identifier of this model to identifier.
| QString | identifier () const |
◆ ProjectDBModel() [1/2]
| ProjectDBModel::ProjectDBModel |
QETProject * | project, |
QObject * | parent = nullptr ) |
explicit |
◆ ProjectDBModel() [2/2]
◆ columnCount()
| int ProjectDBModel::columnCount |
const QModelIndex & | parent = QModelIndex() | ) |
const |
override |
◆ data()
| QVariant ProjectDBModel::data |
const QModelIndex & | index, |
int | role = Qt::DisplayRole ) const |
override |
◆ dataBaseUpdated()
| void ProjectDBModel::dataBaseUpdated |
private |
◆ fillValue()
| void ProjectDBModel::fillValue |
private |
◆ fromXml()
| void ProjectDBModel::fromXml |
const QDomElement & | element | ) |
◆ headerData()
| QVariant ProjectDBModel::headerData |
int | section, |
Qt::Orientation | orientation, |
override |
◆ identifier()
| QString ProjectDBModel::identifier |
const |
inline |
◆ project()
◆ queryString()
| QString ProjectDBModel::queryString |
const |
◆ rowCount()
| int ProjectDBModel::rowCount |
const |
override |
◆ setData()
| bool ProjectDBModel::setData |
const QVariant & | value, |
int | role = Qt::EditRole ) |
override |
◆ setHeaderData()
| bool ProjectDBModel::setHeaderData |
int | section, |
override |
- Parameters
| section | |
| orientation | |
| value | |
| role | |
- Returns
◆ setHeaderString()
| void ProjectDBModel::setHeaderString |
private |
◆ setIdentifier()
| void ProjectDBModel::setIdentifier |
const QString & | identifier | ) |
◆ setQuery()
| void ProjectDBModel::setQuery |
const QString & | query | ) |
◆ toXml()
| QDomElement ProjectDBModel::toXml |
QDomDocument & | document | ) |
const |
- Parameters
- Returns
◆ xmlTagName()
| QString ProjectDBModel::xmlTagName |
inlinestatic |
◆ m_header_data
| QHash<int, QHash<int, QVariant> > ProjectDBModel::m_header_data |
private |
◆ m_identifier
| QString ProjectDBModel::m_identifier = "unknow" |
private |
◆ m_index_0_0_data
| QHash<int, QVariant> ProjectDBModel::m_index_0_0_data |
private |
◆ m_project
◆ m_query
| QString ProjectDBModel::m_query |
private |
◆ m_record
| QVector<QStringList> ProjectDBModel::m_record |
private |
