Bcj2.h File Reference
#include "7zTypes.h"
Include dependency graph for Bcj2.h:
struct  CBcj2Dec
struct  CBcj2Enc
Macros
#define BCJ2_NUM_STREAMS   4
#define BCJ2_IS_32BIT_STREAM(s)
#define Bcj2Dec_IsMaybeFinished_state_MAIN(_p_)
#define Bcj2Dec_IsMaybeFinished_code(_p_)
#define Bcj2Dec_IsMaybeFinished(_p_)
#define BCJ2_ENC_FileSize_MAX   ((CBcj2Enc_ip_unsigned)0 - 2)
#define BCJ2_ENC_FileSizeField_UNLIMITED   ((CBcj2Enc_ip_unsigned)0 - 1)
#define BCJ2_ENC_GET_FileSizeField_VAL_FROM_FileSize(fileSize)
#define Bcj2Enc_SET_FileSize(p, fileSize)
#define Bcj2Enc_Get_AvailInputSize_in_Temp(p)
#define Bcj2Enc_IsFinished(p)
#define BCJ2_ENC_RELAT_LIMIT_DEFAULT   ((UInt32)0x0f << 24)
#define BCJ2_ENC_RELAT_LIMIT_MAX   ((UInt32)1 << 31)
Typedefs
typedef UInt16 CBcj2Prob
typedef UInt64 CBcj2Enc_ip_unsigned
typedef Int64 CBcj2Enc_ip_signed
Enumerations
enum  { BCJ2_STREAM_MAIN , BCJ2_STREAM_CALL , BCJ2_STREAM_JUMP , BCJ2_STREAM_RC }
enum  {
  BCJ2_DEC_STATE_ORIG_0 = BCJ2_NUM_STREAMS , BCJ2_DEC_STATE_ORIG_1 , BCJ2_DEC_STATE_ORIG_2 , BCJ2_DEC_STATE_ORIG_3 ,
  BCJ2_DEC_STATE_ORIG , BCJ2_DEC_STATE_ERROR
enum  { BCJ2_ENC_STATE_ORIG = BCJ2_NUM_STREAMS , BCJ2_ENC_STATE_FINISHED }
enum  EBcj2Enc_FinishMode { BCJ2_ENC_FINISH_MODE_CONTINUE , BCJ2_ENC_FINISH_MODE_END_BLOCK , BCJ2_ENC_FINISH_MODE_END_STREAM }
Functions
void Bcj2Dec_Init (CBcj2Dec *p)
SRes Bcj2Dec_Decode (CBcj2Dec *p)
void Bcj2Enc_Init (CBcj2Enc *p)
void Bcj2Enc_Encode (CBcj2Enc *p)
Macro Definition Documentation
◆ BCJ2_ENC_FileSize_MAX
◆ BCJ2_ENC_FileSizeField_UNLIMITED
◆ BCJ2_ENC_GET_FileSizeField_VAL_FROM_FileSize
#define BCJ2_ENC_GET_FileSizeField_VAL_FROM_FileSize ( fileSize)
Value:
((CBcj2Enc_ip_unsigned)(fileSize) - 1)
Definition Bcj2.h:235
◆ BCJ2_ENC_RELAT_LIMIT_DEFAULT
◆ BCJ2_ENC_RELAT_LIMIT_MAX
◆ BCJ2_IS_32BIT_STREAM
#define BCJ2_IS_32BIT_STREAM ( s)
Value:
((unsigned)((unsigned)(s) - (unsigned)BCJ2_STREAM_CALL) < 2)
@ BCJ2_STREAM_CALL
Definition Bcj2.h:16
◆ BCJ2_NUM_STREAMS
◆ Bcj2Dec_IsMaybeFinished
#define Bcj2Dec_IsMaybeFinished ( _p_)
Value:
Bcj2Dec_IsMaybeFinished_state_MAIN(_p_) && \
Bcj2Dec_IsMaybeFinished_code(_p_))
◆ Bcj2Dec_IsMaybeFinished_code
#define Bcj2Dec_IsMaybeFinished_code ( _p_)
Value:
((_p_)->code == 0)
◆ Bcj2Dec_IsMaybeFinished_state_MAIN
#define Bcj2Dec_IsMaybeFinished_state_MAIN ( _p_)
Value:
((_p_)->state == BCJ2_STREAM_MAIN)
@ BCJ2_STREAM_MAIN
Definition Bcj2.h:15
◆ Bcj2Enc_Get_AvailInputSize_in_Temp
#define Bcj2Enc_Get_AvailInputSize_in_Temp ( p)
Value:
((p)->tempPos)
◆ Bcj2Enc_IsFinished
#define Bcj2Enc_IsFinished ( p)
Value:
((p)->flushRem == 0)
◆ Bcj2Enc_SET_FileSize
#define Bcj2Enc_SET_FileSize ( p,
fileSize )
Value:
(p)->fileSize64_minus1 = BCJ2_ENC_GET_FileSizeField_VAL_FROM_FileSize(fileSize);
Definition Bcj2.h:246
Typedef Documentation
◆ CBcj2Enc_ip_signed
◆ CBcj2Enc_ip_unsigned
◆ CBcj2Prob
Enumeration Type Documentation
◆ anonymous enum
anonymous enum
Enumerator
BCJ2_DEC_STATE_ORIG
◆ anonymous enum
anonymous enum
Enumerator
BCJ2_STREAM_MAIN
BCJ2_STREAM_CALL
BCJ2_STREAM_JUMP
BCJ2_STREAM_RC
◆ anonymous enum
anonymous enum
Enumerator
BCJ2_ENC_STATE_ORIG
◆ EBcj2Enc_FinishMode
Enumerator
Function Documentation
◆ Bcj2Dec_Decode()
SRes Bcj2Dec_Decode ( CBcj2Dec * p)
◆ Bcj2Dec_Init()
void Bcj2Dec_Init ( CBcj2Dec * p)
◆ Bcj2Enc_Encode()
void Bcj2Enc_Encode ( CBcj2Enc * p)
◆ Bcj2Enc_Init()
void Bcj2Enc_Init ( CBcj2Enc * p)
