Bcj2.h
1/* Bcj2.h -- BCJ2 converter for x86 code (Branch CALL/JUMP variant2)
22023-03-02 : Igor Pavlov : Public domain */
4#ifndef ZIP7_INC_BCJ2_H
5#define ZIP7_INC_BCJ2_H
7#include "7zTypes.h"
8
10
11#define BCJ2_NUM_STREAMS 4
12
13enum
14{
19};
20
21enum
22{
27
29 BCJ2_DEC_STATE_ERROR /* after detected data error */
30};
31
32enum
33{
35 BCJ2_ENC_STATE_FINISHED /* it's state after fully encoded stream */
36};
37
38
39/* #define BCJ2_IS_32BIT_STREAM(s) ((s) == BCJ2_STREAM_CALL || (s) == BCJ2_STREAM_JUMP) */
40#define BCJ2_IS_32BIT_STREAM(s) ((unsigned)((unsigned)(s) - (unsigned)BCJ2_STREAM_CALL) < 2)
41
42/*
43CBcj2Dec / CBcj2Enc
44bufs sizes:
45 BUF_SIZE(n) = lims[n] - bufs[n]
46bufs sizes for BCJ2_STREAM_CALL and BCJ2_STREAM_JUMP must be multiply of 4:
47 (BUF_SIZE(BCJ2_STREAM_CALL) & 3) == 0
48 (BUF_SIZE(BCJ2_STREAM_JUMP) & 3) == 0
49*/
50
51// typedef UInt32 CBcj2Prob;
53
54/*
55BCJ2 encoder / decoder internal requirements:
56 - If last bytes of stream contain marker (e8/e8/0f8x), then
57 there is also encoded symbol (0 : no conversion) in RC stream.
58 - One case of overlapped instructions is supported,
59 if last byte of converted instruction is (0f) and next byte is (8x):
60 marker [xx xx xx 0f] 8x
61 then the pair (0f 8x) is treated as marker.
62*/
63
64/* ---------- BCJ2 Decoder ---------- */
65
66/*
67CBcj2Dec:
68(dest) is allowed to overlap with bufs[BCJ2_STREAM_MAIN], with the following conditions:
69 bufs[BCJ2_STREAM_MAIN] >= dest &&
70 bufs[BCJ2_STREAM_MAIN] - dest >=
71 BUF_SIZE(BCJ2_STREAM_CALL) +
72 BUF_SIZE(BCJ2_STREAM_JUMP)
73 reserve = bufs[BCJ2_STREAM_MAIN] - dest -
74 ( BUF_SIZE(BCJ2_STREAM_CALL) +
75 BUF_SIZE(BCJ2_STREAM_JUMP) )
76 and additional conditions:
77 if (it's first call of Bcj2Dec_Decode() after Bcj2Dec_Init())
78 {
79 (reserve != 1) : if (ver < v23.00)
80 }
81 else // if there are more than one calls of Bcj2Dec_Decode() after Bcj2Dec_Init())
82 {
83 (reserve >= 6) : if (ver < v23.00)
84 (reserve >= 4) : if (ver >= v23.00)
85 We need that (reserve) because after first call of Bcj2Dec_Decode(),
86 CBcj2Dec::temp can contain up to 4 bytes for writing to (dest).
87 }
88 (reserve == 0) is allowed, if we decode full stream via single call of Bcj2Dec_Decode().
89 (reserve == 0) also is allowed in case of multi-call, if we use fixed buffers,
90 and (reserve) is calculated from full (final) sizes of all streams before first call.
91*/
92
93typedef struct
94{
98 const Byte *destLim;
99
100 unsigned state; /* BCJ2_STREAM_MAIN has more priority than BCJ2_STATE_ORIG */
101
102 UInt32 ip; /* property of starting base for decoding */
103 UInt32 temp; /* Byte temp[4]; */
106 CBcj2Prob probs[2 + 256];
107} CBcj2Dec;
108
109
110/* Note:
111 Bcj2Dec_Init() sets (CBcj2Dec::ip = 0)
112 if (ip != 0) property is required, the caller must set CBcj2Dec::ip after Bcj2Dec_Init()
113*/
115
116
117/* Bcj2Dec_Decode():
118 returns:
119 SZ_OK
120 SZ_ERROR_DATA : if data in 5 starting bytes of BCJ2_STREAM_RC stream are not correct
121*/
123
124/* To check that decoding was finished you can compare
125 sizes of processed streams with sizes known from another sources.
126 You must do at least one mandatory check from the two following options:
127 - the check for size of processed output (ORIG) stream.
128 - the check for size of processed input (MAIN) stream.
129 additional optional checks:
130 - the checks for processed sizes of all input streams (MAIN, CALL, JUMP, RC)
131 - the checks Bcj2Dec_IsMaybeFinished*()
132 also before actual decoding you can check that the
133 following condition is met for stream sizes:
134 ( size(ORIG) == size(MAIN) + size(CALL) + size(JUMP) )
135*/
136
137/* (state == BCJ2_STREAM_MAIN) means that decoder is ready for
138 additional input data in BCJ2_STREAM_MAIN stream.
139 Note that (state == BCJ2_STREAM_MAIN) is allowed for non-finished decoding.
140*/
141#define Bcj2Dec_IsMaybeFinished_state_MAIN(_p_) ((_p_)->state == BCJ2_STREAM_MAIN)
142
143/* if the stream decoding was finished correctly, then range decoder
144 part of CBcj2Dec also was finished, and then (CBcj2Dec::code == 0).
145 Note that (CBcj2Dec::code == 0) is allowed for non-finished decoding.
146*/
147#define Bcj2Dec_IsMaybeFinished_code(_p_) ((_p_)->code == 0)
148
149/* use Bcj2Dec_IsMaybeFinished() only as additional check
150 after at least one mandatory check from the two following options:
151 - the check for size of processed output (ORIG) stream.
152 - the check for size of processed input (MAIN) stream.
153*/
154#define Bcj2Dec_IsMaybeFinished(_p_) ( \
155 Bcj2Dec_IsMaybeFinished_state_MAIN(_p_) && \
156 Bcj2Dec_IsMaybeFinished_code(_p_))
157
158
159
160/* ---------- BCJ2 Encoder ---------- */
161
168
169/*
170 BCJ2_ENC_FINISH_MODE_CONTINUE:
171 process non finished encoding.
172 It notifies the encoder that additional further calls
173 can provide more input data (src) than provided by current call.
174 In that case the CBcj2Enc encoder still can move (src) pointer
175 up to (srcLim), but CBcj2Enc encoder can store some of the last
176 processed bytes (up to 4 bytes) from src to internal CBcj2Enc::temp[] buffer.
177 at return:
178 (CBcj2Enc::src will point to position that includes
179 processed data and data copied to (temp[]) buffer)
180 That data from (temp[]) buffer will be used in further calls.
181
182 BCJ2_ENC_FINISH_MODE_END_BLOCK:
183 finish encoding of current block (ended at srcLim) without RC flushing.
184 at return: if (CBcj2Enc::state == BCJ2_ENC_STATE_ORIG) &&
185 CBcj2Enc::src == CBcj2Enc::srcLim)
186 : it shows that block encoding was finished. And the encoder is
187 ready for new (src) data or for stream finish operation.
188 finished block means
189 {
190 CBcj2Enc has completed block encoding up to (srcLim).
191 (1 + 4 bytes) or (2 + 4 bytes) CALL/JUMP cortages will
192 not cross block boundary at (srcLim).
193 temporary CBcj2Enc buffer for (ORIG) src data is empty.
194 3 output uncompressed streams (MAIN, CALL, JUMP) were flushed.
195 RC stream was not flushed. And RC stream will cross block boundary.
196 }
197 Note: some possible implementation of BCJ2 encoder could
198 write branch marker (e8/e8/0f8x) in one call of Bcj2Enc_Encode(),
199 and it could calculate symbol for RC in another call of Bcj2Enc_Encode().
200 BCJ2 encoder uses ip/fileIp/fileSize/relatLimit values to calculate RC symbol.
201 And these CBcj2Enc variables can have different values in different Bcj2Enc_Encode() calls.
202 So caller must finish each block with BCJ2_ENC_FINISH_MODE_END_BLOCK
203 to ensure that RC symbol is calculated and written in proper block.
204
205 BCJ2_ENC_FINISH_MODE_END_STREAM
206 finish encoding of stream (ended at srcLim) fully including RC flushing.
207 at return: if (CBcj2Enc::state == BCJ2_ENC_STATE_FINISHED)
208 : it shows that stream encoding was finished fully,
209 and all output streams were flushed fully.
210 also Bcj2Enc_IsFinished() can be called.
211*/
212
213
214/*
215 32-bit relative offset in JUMP/CALL commands is
216 - (mod 4 GiB) for 32-bit x86 code
217 - signed Int32 for 64-bit x86-64 code
218 BCJ2 encoder also does internal relative to absolute address conversions.
219 And there are 2 possible ways to do it:
220 before v23: we used 32-bit variables and (mod 4 GiB) conversion
221 since v23: we use 64-bit variables and (signed Int32 offset) conversion.
222 The absolute address condition for conversion in v23:
223 ((UInt64)((Int64)ip64 - (Int64)fileIp64 + 5 + (Int32)offset) < (UInt64)fileSize64)
224 note that if (fileSize64 > 2 GiB). there is difference between
225 old (mod 4 GiB) way (v22) and new (signed Int32 offset) way (v23).
226 And new (v23) way is more suitable to encode 64-bit x86-64 code for (fileSize64 > 2 GiB) cases.
227*/
228
229/*
230// for old (v22) way for conversion:
231typedef UInt32 CBcj2Enc_ip_unsigned;
232typedef Int32 CBcj2Enc_ip_signed;
233#define BCJ2_ENC_FileSize_MAX ((UInt32)1 << 31)
234*/
237
238/* maximum size of file that can be used for conversion condition */
239#define BCJ2_ENC_FileSize_MAX ((CBcj2Enc_ip_unsigned)0 - 2)
240
241/* default value of fileSize64_minus1 variable that means
242 that absolute address limitation will not be used */
243#define BCJ2_ENC_FileSizeField_UNLIMITED ((CBcj2Enc_ip_unsigned)0 - 1)
244
245/* calculate value that later can be set to CBcj2Enc::fileSize64_minus1 */
246#define BCJ2_ENC_GET_FileSizeField_VAL_FROM_FileSize(fileSize) \
247 ((CBcj2Enc_ip_unsigned)(fileSize) - 1)
248
249/* set CBcj2Enc::fileSize64_minus1 variable from size of file */
250#define Bcj2Enc_SET_FileSize(p, fileSize) \
251 (p)->fileSize64_minus1 = BCJ2_ENC_GET_FileSizeField_VAL_FROM_FileSize(fileSize);
252
253
254typedef struct
255{
258 const Byte *src;
259 const Byte *srcLim;
260
261 unsigned state;
263
267
272
273 // UInt32 context; // for marker version, it can include marker flag.
274
275 /* (ip64) and (fileIp64) correspond to virtual source stream position
276 that doesn't include data in temp[] */
277 CBcj2Enc_ip_unsigned ip64; /* current (ip) position */
278 CBcj2Enc_ip_unsigned fileIp64; /* start (ip) position of current file */
279 CBcj2Enc_ip_unsigned fileSize64_minus1; /* size of current file (for conversion limitation) */
280 UInt32 relatLimit; /* (relatLimit <= ((UInt32)1 << 31)) : 0 means disable_conversion */
281 // UInt32 relatExcludeBits;
282
284 unsigned tempPos; /* the number of bytes that were copied to temp[] buffer
285 (tempPos <= 4) outside of Bcj2Enc_Encode() */
286 // Byte temp[4]; // for marker version
288 CBcj2Prob probs[2 + 256];
289} CBcj2Enc;
290
292
293
294/*
295Bcj2Enc_Encode(): at exit:
296 p->State < BCJ2_NUM_STREAMS : we need more buffer space for output stream
297 (bufs[p->State] == lims[p->State])
298 p->State == BCJ2_ENC_STATE_ORIG : we need more data in input src stream
299 (src == srcLim)
300 p->State == BCJ2_ENC_STATE_FINISHED : after fully encoded stream
301*/
303
304/* Bcj2Enc encoder can look ahead for up 4 bytes of source stream.
305 CBcj2Enc::tempPos : is the number of bytes that were copied from input stream to temp[] buffer.
306 (CBcj2Enc::src) after Bcj2Enc_Encode() is starting position after
307 fully processed data and after data copied to temp buffer.
308 So if the caller needs to get real number of fully processed input
309 bytes (without look ahead data in temp buffer),
310 the caller must subtruct (CBcj2Enc::tempPos) value from processed size
311 value that is calculated based on current (CBcj2Enc::src):
312 cur_processed_pos = Calc_Big_Processed_Pos(enc.src)) -
313 Bcj2Enc_Get_AvailInputSize_in_Temp(&enc);
314*/
315/* get the size of input data that was stored in temp[] buffer: */
316#define Bcj2Enc_Get_AvailInputSize_in_Temp(p) ((p)->tempPos)
317
318#define Bcj2Enc_IsFinished(p) ((p)->flushRem == 0)
319
320/* Note : the decoder supports overlapping of marker (0f 80).
321 But we can eliminate such overlapping cases by setting
322 the limit for relative offset conversion as
323 CBcj2Enc::relatLimit <= (0x0f << 24) == (240 MiB)
324*/
325/* default value for CBcj2Enc::relatLimit */
326#define BCJ2_ENC_RELAT_LIMIT_DEFAULT ((UInt32)0x0f << 24)
327#define BCJ2_ENC_RELAT_LIMIT_MAX ((UInt32)1 << 31)
328// #define BCJ2_RELAT_EXCLUDE_NUM_BITS 5
329
331
332#endif
unsigned int UInt32
Definition 7zTypes.h:180
#define EXTERN_C_BEGIN
Definition 7zTypes.h:20
unsigned long long int UInt64
Definition 7zTypes.h:234
int SRes
Definition 7zTypes.h:45
unsigned short UInt16
Definition 7zTypes.h:173
#define EXTERN_C_END
Definition 7zTypes.h:21
long long int Int64
Definition 7zTypes.h:233
unsigned char Byte
Definition 7zTypes.h:171
SRes Bcj2Dec_Decode(CBcj2Dec *p)
@ BCJ2_ENC_STATE_FINISHED
Definition Bcj2.h:35
@ BCJ2_ENC_STATE_ORIG
Definition Bcj2.h:34
Int64 CBcj2Enc_ip_signed
Definition Bcj2.h:236
@ BCJ2_DEC_STATE_ORIG_2
Definition Bcj2.h:25
@ BCJ2_DEC_STATE_ORIG_3
Definition Bcj2.h:26
Definition Bcj2.h:28
@ BCJ2_DEC_STATE_ERROR
Definition Bcj2.h:29
@ BCJ2_DEC_STATE_ORIG_0
@ BCJ2_DEC_STATE_ORIG_1
Definition Bcj2.h:24
EBcj2Enc_FinishMode
Definition Bcj2.h:163
@ BCJ2_ENC_FINISH_MODE_END_BLOCK
Definition Bcj2.h:165
@ BCJ2_ENC_FINISH_MODE_CONTINUE
Definition Bcj2.h:164
@ BCJ2_ENC_FINISH_MODE_END_STREAM
Definition Bcj2.h:166
void Bcj2Enc_Init(CBcj2Enc *p)
void Bcj2Enc_Encode(CBcj2Enc *p)
UInt16 CBcj2Prob
Definition Bcj2.h:52
@ BCJ2_STREAM_MAIN
Definition Bcj2.h:15
@ BCJ2_STREAM_RC
Definition Bcj2.h:18
@ BCJ2_STREAM_JUMP
Definition Bcj2.h:17
@ BCJ2_STREAM_CALL
UInt64 CBcj2Enc_ip_unsigned
Definition Bcj2.h:235
Definition Bcj2.h:11
void Bcj2Dec_Init(CBcj2Dec *p)
Definition Bcj2.h:94
unsigned state
Definition Bcj2.h:100
CBcj2Prob probs[2+256]
Definition Bcj2.h:106
const Byte * bufs[BCJ2_NUM_STREAMS]
Definition Bcj2.h:95
UInt32 ip
Definition Bcj2.h:102
UInt32 range
Definition Bcj2.h:104
UInt32 temp
Definition Bcj2.h:103
UInt32 code
Definition Bcj2.h:105
Byte * dest
Definition Bcj2.h:97
const Byte * destLim
Definition Bcj2.h:98
const Byte * lims[BCJ2_NUM_STREAMS]
Definition Bcj2.h:96
Definition Bcj2.h:255
Definition Bcj2.h:278
Definition Bcj2.h:288
UInt32 range
Definition Bcj2.h:269
Byte cache
Definition Bcj2.h:268
UInt32 tempTarget
Definition Bcj2.h:283
UInt64 low
Definition Bcj2.h:270
unsigned state
Definition Bcj2.h:261
Byte context
Definition Bcj2.h:264
Definition Bcj2.h:279
Definition Bcj2.h:277
Definition Bcj2.h:256
const Byte * src
Definition Bcj2.h:258
unsigned tempPos
Definition Bcj2.h:284
Byte flushRem
Definition Bcj2.h:265
Byte isFlushState
Definition Bcj2.h:266
const Byte * srcLim
Definition Bcj2.h:259
Byte temp[8]
Definition Bcj2.h:287
UInt32 relatLimit
Definition Bcj2.h:280
Definition Bcj2.h:257
UInt64 cacheSize
Definition Bcj2.h:271
EBcj2Enc_FinishMode finishMode
Definition Bcj2.h:262
