ElementsCollectionWidget Class Reference
The ElementsCollectionWidget class This widget embedd a tree view that display the element collection (common, custom, embedded) and all action needed to use this widget. This is the element collection widget used in the diagram editor. More...
#include <elementscollectionwidget.h>
Inherits QWidget.
Collaboration diagram for ElementsCollectionWidget:
Public Slots
void reload ()
 ElementsCollectionWidget::reload, the displayed collections.
void loadingFinished ()
 ElementsCollectionWidget::loadingFinished Process when collection finished to be loaded.
 ElementsCollectionWidget (QWidget *parent=nullptr)
 ElementsCollectionWidget::ElementsCollectionWidget Default constructor.
void expandFirstItems ()
 ElementsCollectionWidget::expandFirstItems Expand each first item in the tree view.
void addProject (QETProject *project)
 ElementsCollectionWidget::addProject Add project to be displayed.
void removeProject (QETProject *project)
void highlightUnusedElement ()
 ElementsCollectionWidget::highlightUnusedElement highlight the unused element.
void setCurrentLocation (const ElementsLocation &location)
 ElementsCollectionWidget::setCurrentLocation Set the current item to be the item for location.
Protected Member Functions
void leaveEvent (QEvent *event) override
void setUpAction ()
void setUpWidget ()
 ElementsCollectionWidget::setUpWidget Setup this widget.
void setUpConnection ()
 ElementsCollectionWidget::setUpConnection Setup the connection used in this widget.
void customContextMenu (const QPoint &point)
 ElementsCollectionWidget::customContextMenu Display the context menu of this widget at point.
void openDir ()
 ElementsCollectionWidget::openDir Open the directory represented by the current selected item.
void editElement ()
 ElementsCollectionWidget::editElement Edit the element represented by the current selected item.
void deleteElement ()
 ElementsCollectionWidget::deleteElement Delete the element represented by the current selected item.
void deleteDirectory ()
 ElementsCollectionWidget::deleteDirectory Delete directory represented by the current selected item.
void editDirectory ()
 ElementsCollectionWidget::editDirectory Edit the directory represented by the current selected item.
void newDirectory ()
 ElementsCollectionWidget::newDirectory Create a new directory.
void newElement ()
 ElementsCollectionWidget::newElement Create a new element.
bool confirmEdzImportTerms ()
 ElementsCollectionWidget::confirmEdzImportTerms Show the EPLAN (.edz) import warning dialog. The user must tick the acknowledgement checkbox before the Import button is enabled.
void importEdz ()
 ElementsCollectionWidget::importEdz Import an EPLAN Data Portal part (.edz) as a QET element into the directory pointed at by the context menu.
void showThisDir ()
 ElementsCollectionWidget::showThisDir Hide all directories except the pointed dir;.
void resetShowThisDir ()
 ElementsCollectionWidget::resetShowThisDir reset show this dir, all collection are show. If search field isn't empty, apply the search after show all collection.
void dirProperties ()
 ElementsCollectionWidget::dirProperties Open an informative dialog about the current index.
void search ()
 ElementsCollectionWidget::search Search every item (directory or element) that match the text of m_search_field and display it, other item who does not match text is hidden.
void hideCollection (bool hide=true)
 ElementsCollectionWidget::hideCollection Hide all collection displayed in this tree.
void hideItem (bool hide, const QModelIndex &index=QModelIndex(), bool recursive=true)
 ElementsCollectionWidget::hideItem Hide the item index. If recursive is true, hide all subchilds of index.
void showAndExpandItem (const QModelIndex &index, bool parent=true, bool child=false)
 ElementsCollectionWidget::showAndExpandItem Show the item index and expand it. If parent is true, ensure parents of index is show and expanded If child is true, ensure all childs of index is show and expended.
ElementCollectionItem * elementCollectionItemForIndex (const QModelIndex &index)
 ElementsCollectionWidget::elementCollectionItemForIndex.
void locationWasSaved (const ElementsLocation &location)
 ElementsCollectionWidget::locationWasSaved This method is connected with the signal savedToLocation of Element editor (see ElementsCollectionWidget::editElement()) Update or add the item represented by location to m_model.
ElementsCollectionModel * m_model = nullptr
ElementsCollectionModel * m_new_model = nullptr
ElementsCollectionModel * m_macros_model = nullptr
QLineEdit * m_search_field
QTimer m_search_timer
ElementsTreeView * m_tree_view
ElementsTreeView * m_macros_tree_view = nullptr
QTabWidget * m_tab_widget = nullptr
QVBoxLayout * m_main_vlayout
QMenu * m_context_menu
QModelIndex m_index_at_context_menu
QModelIndex m_showed_index
QProgressBar * m_progress_bar
QAction * m_open_dir
QAction * m_edit_element
QAction * m_delete_element
QAction * m_delete_dir
QAction * m_reload
QAction * m_edit_dir
QAction * m_new_directory
QAction * m_new_element
QAction * m_import_edz
QAction * m_show_this_dir
QAction * m_show_all_dir
QAction * m_dir_propertie
bool m_first_show = true
QList< QETProject * > m_waiting_project
QScopedPointer< QElapsedTimer > m_loading_timer
◆ ElementsCollectionWidget()
ElementsCollectionWidget::ElementsCollectionWidget ( QWidget * parent = nullptr)
parent: parent widget of this widget.
◆ addProject()
void ElementsCollectionWidget::addProject ( QETProject * project)
project
◆ confirmEdzImportTerms()
bool ElementsCollectionWidget::confirmEdzImportTerms ( )
true if the user accepted the terms, false otherwise.
◆ customContextMenu()
void ElementsCollectionWidget::customContextMenu ( const QPoint & point)
point
◆ deleteDirectory()
void ElementsCollectionWidget::deleteDirectory ( )
◆ deleteElement()
void ElementsCollectionWidget::deleteElement ( )
◆ dirProperties()
void ElementsCollectionWidget::dirProperties ( )
◆ editDirectory()
void ElementsCollectionWidget::editDirectory ( )
◆ editElement()
void ElementsCollectionWidget::editElement ( )
◆ elementCollectionItemForIndex()
ElementCollectionItem * ElementsCollectionWidget::elementCollectionItemForIndex ( const QModelIndex & index)
index
The internal pointer of index casted to ElementCollectionItem;
◆ expandFirstItems()
void ElementsCollectionWidget::expandFirstItems ( )
◆ hideCollection()
void ElementsCollectionWidget::hideCollection ( bool hide = true)
hide-true = hide , false = visible
◆ hideItem()
void ElementsCollectionWidget::hideItem ( bool hide,
const QModelIndex & index = QModelIndex(),
bool recursive = true )
hide: - true = hide , false = visible
index: - index to hide
recursive: - true = apply to child , false = only for index
◆ highlightUnusedElement()
void ElementsCollectionWidget::highlightUnusedElement ( )
◆ importEdz()
void ElementsCollectionWidget::importEdz ( )
◆ leaveEvent()
void ElementsCollectionWidget::leaveEvent ( QEvent * event)
overrideprotected
◆ loadingFinished
void ElementsCollectionWidget::loadingFinished ( )
slot
◆ locationWasSaved()
void ElementsCollectionWidget::locationWasSaved ( const ElementsLocation & location)
location
◆ newDirectory()
void ElementsCollectionWidget::newDirectory ( )
◆ newElement()
void ElementsCollectionWidget::newElement ( )
◆ openDir()
void ElementsCollectionWidget::openDir ( )
◆ reload
void ElementsCollectionWidget::reload ( )
slot
◆ removeProject()
void ElementsCollectionWidget::removeProject ( QETProject * project)
◆ resetShowThisDir()
void ElementsCollectionWidget::resetShowThisDir ( )
◆ search()
void ElementsCollectionWidget::search ( )
◆ setCurrentLocation()
void ElementsCollectionWidget::setCurrentLocation ( const ElementsLocation & location)
location
◆ setUpAction()
void ElementsCollectionWidget::setUpAction ( )
◆ setUpConnection()
void ElementsCollectionWidget::setUpConnection ( )
◆ setUpWidget()
void ElementsCollectionWidget::setUpWidget ( )
◆ showAndExpandItem()
void ElementsCollectionWidget::showAndExpandItem ( const QModelIndex & index,
bool parent = true,
bool child = false )
index-index to show
parent-Apply to parent
child-Apply to all childs
◆ showThisDir()
void ElementsCollectionWidget::showThisDir ( )
◆ m_context_menu
QMenu* ElementsCollectionWidget::m_context_menu
◆ m_delete_dir
QAction * ElementsCollectionWidget::m_delete_dir
◆ m_delete_element
QAction * ElementsCollectionWidget::m_delete_element
◆ m_dir_propertie
QAction * ElementsCollectionWidget::m_dir_propertie
◆ m_edit_dir
QAction * ElementsCollectionWidget::m_edit_dir
◆ m_edit_element
QAction * ElementsCollectionWidget::m_edit_element
◆ m_first_show
bool ElementsCollectionWidget::m_first_show = true
◆ m_import_edz
QAction * ElementsCollectionWidget::m_import_edz
◆ m_index_at_context_menu
QModelIndex ElementsCollectionWidget::m_index_at_context_menu
◆ m_loading_timer
QScopedPointer<QElapsedTimer> ElementsCollectionWidget::m_loading_timer
◆ m_macros_model
ElementsCollectionModel* ElementsCollectionWidget::m_macros_model = nullptr
◆ m_macros_tree_view
ElementsTreeView* ElementsCollectionWidget::m_macros_tree_view = nullptr
◆ m_main_vlayout
QVBoxLayout* ElementsCollectionWidget::m_main_vlayout
◆ m_model
ElementsCollectionModel* ElementsCollectionWidget::m_model = nullptr
◆ m_new_directory
QAction * ElementsCollectionWidget::m_new_directory
◆ m_new_element
QAction * ElementsCollectionWidget::m_new_element
◆ m_new_model
ElementsCollectionModel* ElementsCollectionWidget::m_new_model = nullptr
◆ m_open_dir
QAction* ElementsCollectionWidget::m_open_dir
◆ m_progress_bar
QProgressBar* ElementsCollectionWidget::m_progress_bar
◆ m_reload
QAction * ElementsCollectionWidget::m_reload
◆ m_search_field
QLineEdit* ElementsCollectionWidget::m_search_field
◆ m_search_timer
QTimer ElementsCollectionWidget::m_search_timer
◆ m_show_all_dir
QAction * ElementsCollectionWidget::m_show_all_dir
◆ m_show_this_dir
QAction * ElementsCollectionWidget::m_show_this_dir
◆ m_showed_index
QModelIndex ElementsCollectionWidget::m_showed_index
◆ m_tab_widget
QTabWidget* ElementsCollectionWidget::m_tab_widget = nullptr
◆ m_tree_view
ElementsTreeView* ElementsCollectionWidget::m_tree_view
◆ m_waiting_project
QList<QETProject *> ElementsCollectionWidget::m_waiting_project
