LinkElementCommand Class Reference
The LinkElementCommand class This undo class manage link between elements. In the same instance of this class, we can link and unlink elements from an edited element This undo class support the merge. More...
#include <linkelementcommand.h>
Inherits QUndoCommand.
Collaboration diagram for LinkElementCommand:
 LinkElementCommand (Element *element_, QUndoCommand *parent=nullptr)
 LinkElementCommand::LinkElementCommand Constructor.
int id () const override
bool mergeWith (const QUndoCommand *other) override
 LinkElementCommand::mergeWith.
void setLink (const QList< Element * > &element_list)
 LinkElementCommand::setLink Replace all linked elements of edited element by elements stored in element_list This method do several check to know if element can be linked or not.
void setLink (Element *element_)
 LinkElementCommand::setLink This is an overloaded function.
void unlink (QList< Element * > element_list)
 LinkElementCommand::unlink Unlink all elements of element_list from the edited element.
void unlinkAll ()
 LinkElementCommand::unlinkAll Unlink all element of the edited element.
void setGroupIndex (int index)
void setGroupIndices (const QMap< Element *, int > &indices)
void undo () override
 LinkElementCommand::undo Undo this command.
void redo () override
 LinkElementCommand::redo Redo this command.
static bool isLinkable (Element *element_a, Element *element_b, bool already_linked=false)
 LinkElementCommand::isLinkable.
void setUpNewLink (const QList< Element * > &element_list, bool already_link)
 LinkElementCommand::setUpNewLink Update the content of m_link_after with the content of element_list. Each linkable element (know via the static method isLinkable) is added to m_linked_after already_link is used for the static method isLinkable.
void makeLink (const QList< Element * > &element_list)
 LinkElementCommand::makeLink Make the link between m_element and element_list; This method unlinks elements if needed.
Element * m_element
bool m_first_redo
int m_group_index = -1
QMap< Element *, int > m_group_indices
QList< Element * > m_linked_before
QList< Element * > m_linked_after
◆ LinkElementCommand()
LinkElementCommand::LinkElementCommand ( Element * element_,
element_: element where we work the link / unlink
parent: parent undo
◆ id()
int LinkElementCommand::id ( ) const
inlineoverride
◆ isLinkable()
bool LinkElementCommand::isLinkable ( Element * element_a,
Element * element_b,
bool already_linked = false )
static
element_a
element_b
already_linked
true if element_a and element_b can be linked between them. There is few condition to be linked : 1- element_a and element_b must be linkable type. (Ex : A is master and B is slave 'OK', A and B is master 'KO') 2- For element type slave and report (no matter if element is 'A' or 'B'), the element must be free (not connected to an element) 3- we can override the section 2 by set already_linked to true. In this case, if slave or report is already linked to the other element ('A' or 'B') return true, but if linked to another element (not 'A' or 'B') return false
◆ makeLink()
void LinkElementCommand::makeLink ( const QList< Element * > & element_list)
element_list
◆ mergeWith()
bool LinkElementCommand::mergeWith ( const QUndoCommand * other)
othertry to merge this command with other
true if merge with success else false
◆ redo()
void LinkElementCommand::redo ( )
◆ setGroupIndex()
void LinkElementCommand::setGroupIndex ( int index)
inline
◆ setGroupIndices()
void LinkElementCommand::setGroupIndices ( const QMap< Element *, int > & indices)
inline
◆ setLink() [1/2]
void LinkElementCommand::setLink ( const QList< Element * > & element_list)
element_list
◆ setLink() [2/2]
void LinkElementCommand::setLink ( Element * element_)
element_
◆ setUpNewLink()
void LinkElementCommand::setUpNewLink ( const QList< Element * > & element_list,
bool already_link )
element_list
already_link
◆ undo()
void LinkElementCommand::undo ( )
◆ unlink()
void LinkElementCommand::unlink ( QList< Element * > element_list)
element_list
◆ unlinkAll()
void LinkElementCommand::unlinkAll ( )
◆ m_element
Element* LinkElementCommand::m_element
◆ m_first_redo
bool LinkElementCommand::m_first_redo
◆ m_group_index
int LinkElementCommand::m_group_index = -1
◆ m_group_indices
QMap<Element*, int> LinkElementCommand::m_group_indices
◆ m_linked_after
QList<Element *> LinkElementCommand::m_linked_after
◆ m_linked_before
QList<Element *> LinkElementCommand::m_linked_before
