23#include <QGraphicsObject>
25#include <QStyleOptionGraphicsItem>
63 enum {
Type = UserType + 1009 };
83 QPainterPath
shape()
const override;
86 const bool &add_prefix =
false)
const;
102 QStyleOptionGraphicsItem option;
103 paint(painter, &option,
nullptr);
108 void paint(QPainter *painter,
109 const QStyleOptionGraphicsItem *option,
110 QWidget *widget)
override;
112 QGraphicsSceneMouseEvent * event )
override;
void drawAsCross(QPainter &painter)
CrossRefItem::drawAsCross Draw this crossref with a cross.
Definition crossrefitem.cpp:705
void updateProperties()
CrossRefItem::updateProperties update the current properties.
Definition crossrefitem.cpp:201
bool m_update_map
Definition crossrefitem.h:137
void AddExtraInfo(QPainter &painter, const QString &)
CrossRefItem::AddExtraInfo Add the comment info of the parent item if needed.
Definition crossrefitem.cpp:1263
void hoverEnterEvent(QGraphicsSceneHoverEvent *event) override
CrossRefItem::hoverEnterEvent.
Definition crossrefitem.cpp:409
void hoverLeaveEvent(QGraphicsSceneHoverEvent *event) override
CrossRefItem::hoverLeaveEvent.
Definition crossrefitem.cpp:477
const QMultiMap< Element *, QRectF > & hoveredContactsMap() const
Definition crossrefitem.h:148
void init()
CrossRefItem::init init this Xref.
Definition crossrefitem.cpp:80
QList< QMetaObject::Connection > m_slave_connection
Definition crossrefitem.h:142
void autoPos()
CrossRefItem::autoPos Calculate and set position automatically.
Definition crossrefitem.cpp:283
QString elementPositionText(const Element *elmt, const bool &add_prefix=false) const
CrossRefItem::elementPositionText.
Definition crossrefitem.cpp:176
CONTACTS
The CONTACTS enum.
Definition crossrefitem.h:69
@ NC
Definition crossrefitem.h:71
@ DelayOn
Definition crossrefitem.h:75
@ DelayOnOff
Definition crossrefitem.h:77
@ NO
Definition crossrefitem.h:70
@ NOC
Definition crossrefitem.h:72
@ Power
Definition crossrefitem.h:74
@ Delay
Definition crossrefitem.h:78
@ DelayOff
Definition crossrefitem.h:76
@ Other
Definition crossrefitem.h:79
@ SW
Definition crossrefitem.h:73
CrossRefItem(Element *elmt)
CrossRefItem::CrossRefItem.
Definition crossrefitem.cpp:42
~CrossRefItem() override
CrossRefItem::~CrossRefItem Default destructor.
Definition crossrefitem.cpp:73
DynamicElementTextItem * m_text
Definition crossrefitem.h:140
Element * m_hovered_contact
Definition crossrefitem.h:139
Element * m_element
Definition crossrefitem.h:132
bool sceneEvent(QEvent *event) override
CrossRefItem::sceneEvent.
Definition crossrefitem.cpp:306
void buildHeaderContact(QPainter &painter, QPointF no_pos, QPointF nc_pos)
CrossRefItem::buildHeaderContact Draw NO and NC contact symbols directly onto painter....
Definition crossrefitem.cpp:518
QRectF drawContact(QPainter &painter, int flags, Element *elmt, int pole_index=0)
CrossRefItem::drawContact Draw one contact, the type of contact to draw is define in flags.
Definition crossrefitem.cpp:784
void paintForExport(QPainter *painter)
Definition crossrefitem.h:100
void fillCrossRef(QPainter &painter)
CrossRefItem::fillCrossRef Fill the content of the cross ref.
Definition crossrefitem.cpp:1091
QRectF boundingRect() const override
CrossRefItem::boundingRect.
Definition crossrefitem.cpp:155
QMultiMap< Element *, QRectF > m_hovered_contacts_map
Definition crossrefitem.h:138
void linkedChanged()
CrossRefItem::linkedChanged.
Definition crossrefitem.cpp:487
ElementTextItemGroup * m_group
Definition crossrefitem.h:141
XRefProperties m_properties
Definition crossrefitem.h:135
void mouseDoubleClickEvent(QGraphicsSceneMouseEvent *event) override
CrossRefItem::mouseDoubleClickEvent.
Definition crossrefitem.cpp:382
void drawAsContacts(QPainter &painter)
CrossRefItem::drawAsContacts Draw this crossref with symbolic contacts.
Definition crossrefitem.cpp:735
void updateLabel()
CrossRefItem::updateLabel Update the content of the item.
Definition crossrefitem.cpp:223
void setUpConnection()
CrossRefItem::setUpConnection Set up several connection to keep up to date the Xref.
Definition crossrefitem.cpp:103
void setUpCrossBoundingRect(QPainter &painter)
CrossRefItem::setUpCrossBoundingRect Get the numbers of slaves elements linked to this parent element...
Definition crossrefitem.cpp:559
QList< QMetaObject::Connection > m_update_connection
Definition crossrefitem.h:143
QRectF m_bounding_rect
Definition crossrefitem.h:133
QList< Element * > NOElements() const
CrossRefItem::NOElements.
Definition crossrefitem.cpp:1316
int type() const override
Definition crossrefitem.h:64
int m_drawed_contacts
Definition crossrefitem.h:136
QPainterPath m_shape_path
Definition crossrefitem.h:134
@ Type
Definition crossrefitem.h:63
QPainterPath shape() const override
CrossRefItem::shape.
Definition crossrefitem.cpp:164
void hoverMoveEvent(QGraphicsSceneHoverEvent *event) override
CrossRefItem::hoverMoveEvent.
Definition crossrefitem.cpp:419
QList< Element * > NCElements() const
CrossRefItem::NCElements.
Definition crossrefitem.cpp:1349
void drawAsPlcTable(QPainter &painter)
CrossRefItem::drawAsPlcTable Draw the PLC IO table for PLC master elements. The table shows columns: ...
Definition crossrefitem.cpp:1380
void paint(QPainter *painter, const QStyleOptionGraphicsItem *option, QWidget *widget) override
CrossRefItem::paint Paint this item.
Definition crossrefitem.cpp:342
The DynamicElementTextItem class This class provide a simple text field of element who can be added o...
Definition dynamicelementtextitem.h:40
The ElementTextItemGroup class This class represent a group of element text Texts in the group can be...
Definition elementtextitemgroup.h:36
The XRefProperties class this class store properties used by XrefItem.
Definition xrefproperties.h:31
