ElementsCollectionCache Class Reference
#include <elementscollectioncache.h>
Inherits QObject.
Collaboration diagram for ElementsCollectionCache:
 ElementsCollectionCache (const QString &database_path, QObject *=nullptr)
 ~ElementsCollectionCache () override
void setLocale (const QString &)
QString locale () const
bool setPixmapStorageFormat (const QString &)
QString pixmapStorageFormat () const
bool fetchElement (ElementsLocation &location)
 ElementsCollectionCache::fetchElement Retrieve the data for a given element, using the cache if available, filling it otherwise. Data are then available through pixmap() and name() methods.
QString name () const
QPixmap pixmap () const
bool fetchData (const ElementsLocation &)
bool fetchNameFromCache (const QString &path, const QUuid &uuid)
 ElementsCollectionCache::fetchNameFromCache Retrieve the name for an element, given its path and uuid The value is then available through the name() method.
bool fetchPixmapFromCache (const QString &path, const QUuid &uuid)
 ElementsCollectionCache::fetchPixmapFromCache Retrieve the pixmap for an element, given its path and uuid. It is then available through the pixmap() method.
bool cacheName (const QString &path, const QUuid &uuid=QUuid::createUuid())
 ElementsCollectionCache::cacheName Cache the current (i.e. last retrieved) name The cache entry will use the locale set via setLocale().
bool cachePixmap (const QString &path, const QUuid &uuid=QUuid::createUuid())
 ElementsCollectionCache::cachePixmap Cache the current (i.e. last retrieved) pixmap.
QSqlDatabase cache_db_
 Object providing access to the SQLite database this cache relies on.
QSqlQuery * select_name_
 Prepared statement to fetch names from the cache.
QSqlQuery * select_pixmap_
 Prepared statement to fetch pixmaps from the cache.
QSqlQuery * insert_name_
 Prepared statement to insert names into the cache.
QSqlQuery * insert_pixmap_
 Prepared statement to insert pixmaps into the cache.
QString locale_
 Locale to be used when dealing with names.
QString pixmap_storage_format_
 Storage format for cached pixmaps.
QString current_name_
 Last name fetched.
QPixmap current_pixmap_
 Last pixmap fetched.
This class implements a SQLite cache for data related to elements collections, mainly names and pixmaps. This avoids the cost of parsing XML definitions of elements and building full CustomElement objects when (re)loading the elements panel.
◆ ElementsCollectionCache()
ElementsCollectionCache::ElementsCollectionCache ( const QString & database_path,
QObject * parent = nullptr )
Construct a cache for elements collections.
database_pathPath of the SQLite database to open.
parentParent QObject
◆ ~ElementsCollectionCache()
ElementsCollectionCache::~ElementsCollectionCache ( )
Destructor
◆ cacheName()
bool ElementsCollectionCache::cacheName ( const QString & path,
const QUuid & uuid = QUuid::createUuid() )
path: Element path (as obtained using ElementsLocation::toString())
uuid:Element uuid
True if the caching succeeded, false otherwise.
See also
name()
◆ cachePixmap()
bool ElementsCollectionCache::cachePixmap ( const QString & path,
uuid: Element uuid
See also
pixmap()
◆ fetchData()
bool ElementsCollectionCache::fetchData ( const ElementsLocation & location)
Retrieve the data by building the full CustomElement object matching the given location, without using the cache. Data are then available through pixmap() and name() methods.
locationLocation of a given Element.
True if the retrieval succeeded, false otherwise.
◆ fetchElement()
bool ElementsCollectionCache::fetchElement ( ElementsLocation & location)
locationThe definition of an element.
See also
pixmap()
name()
◆ fetchNameFromCache()
bool ElementsCollectionCache::fetchNameFromCache ( const QString & path,
const QUuid & uuid )
uuid: Element uuid
◆ fetchPixmapFromCache()
bool ElementsCollectionCache::fetchPixmapFromCache ( const QString & path,
uuid: Element uuid
◆ locale()
QString ElementsCollectionCache::locale ( ) const
The locale to be used when dealing with names.
◆ name()
QString ElementsCollectionCache::name ( ) const
The last name fetched through fetchElement().
◆ pixmap()
QPixmap ElementsCollectionCache::pixmap ( ) const
The last pixmap fetched through fetchElement().
◆ pixmapStorageFormat()
QString ElementsCollectionCache::pixmapStorageFormat ( ) const
the pixmap storage format. Default is "PNG"
See also
setPixmapStorageFormat()
◆ setLocale()
void ElementsCollectionCache::setLocale ( const QString & locale)
Define the locale to be used when dealing with names.
localeNew locale to be used.
◆ setPixmapStorageFormat()
bool ElementsCollectionCache::setPixmapStorageFormat ( const QString & format)
Define the storage format for the pixmaps within the SQLite database. See Qt's QPixmap documentation for more information.
formatThe new pixmap storage format.
True if the format change was accepted, false otherwise.
◆ cache_db_
QSqlDatabase ElementsCollectionCache::cache_db_
◆ current_name_
QString ElementsCollectionCache::current_name_
Last name fetched.
◆ current_pixmap_
QPixmap ElementsCollectionCache::current_pixmap_
◆ insert_name_
QSqlQuery* ElementsCollectionCache::insert_name_
◆ insert_pixmap_
QSqlQuery* ElementsCollectionCache::insert_pixmap_
◆ locale_
QString ElementsCollectionCache::locale_
◆ pixmap_storage_format_
QString ElementsCollectionCache::pixmap_storage_format_
◆ select_name_
QSqlQuery* ElementsCollectionCache::select_name_
◆ select_pixmap_
QSqlQuery* ElementsCollectionCache::select_pixmap_
