PropertiesEditorDockWidget Class Reference
#include <propertieseditordockwidget.h>
Inheritance diagram for PropertiesEditorDockWidget:
Collaboration diagram for PropertiesEditorDockWidget:
 PropertiesEditorDockWidget (QWidget *parent=nullptr)
 PropertiesEditorDockWidget::PropertiesEditorDockWidget Constructor.
 ~PropertiesEditorDockWidget () override
 PropertiesEditorDockWidget::~PropertiesEditorDockWidget Destructor.
virtual void clear ()
 PropertiesEditorDockWidget::clear Remove all editor present in this dock and delete it. They also disabled the button box at the bottom of this dock.
virtual void apply ()
 PropertiesEditorDockWidget::apply Call the apply method for each editor present in this dock.
virtual void reset ()
 PropertiesEditorDockWidget::reset Call the reset method for each editor present in this widget.
bool addEditor (PropertiesEditorWidget *editor, int index=0)
 PropertiesEditorDockWidget::addEditor Add an editor in this dock at index in the main vertical layout (note the button box are displayed at bottom of this layout by default) When an editor is added, we enable the button box.
QList< PropertiesEditorWidget * > editors () const
 PropertiesEditorDockWidget::editors.
bool removeEditor (PropertiesEditorWidget *editor)
 PropertiesEditorDockWidget::removeEditor Remove editor from this dock. The editor wasn't delete a the end of this method If the editor was the last on this widget, we disabled the button box.
Protected Attributes
QList< PropertiesEditorWidget * > m_editor_list
Ui::PropertiesEditorDockWidget * ui
◆ PropertiesEditorDockWidget()
PropertiesEditorDockWidget::PropertiesEditorDockWidget ( QWidget * parent = nullptr)
explicit
parent: parent widget
◆ ~PropertiesEditorDockWidget()
PropertiesEditorDockWidget::~PropertiesEditorDockWidget ( )
◆ addEditor()
bool PropertiesEditorDockWidget::addEditor ( PropertiesEditorWidget * editor,
int index = 0 )
editor: editor to add;
index: index of editor in the layout
true if was added (or already add) or false if can't be add (editor = nullptr)
◆ apply()
void PropertiesEditorDockWidget::apply ( )
virtual
◆ clear()
void PropertiesEditorDockWidget::clear ( )
virtual
◆ editors()
QList< PropertiesEditorWidget * > PropertiesEditorDockWidget::editors ( ) const
all editor used in this dock
◆ removeEditor()
bool PropertiesEditorDockWidget::removeEditor ( PropertiesEditorWidget * editor)
editor: editor to remove
true on success, else false
◆ reset()
void PropertiesEditorDockWidget::reset ( )
virtual
◆ m_editor_list
QList<PropertiesEditorWidget *> PropertiesEditorDockWidget::m_editor_list
protected
◆ ui
Ui::PropertiesEditorDockWidget* PropertiesEditorDockWidget::ui
