PotentialSelectorDialog Class Reference
The PotentialSelectorDialog class This dialog is used when user try to connect two existing potential together. The dialog ask to user to make a choice between the properties of the two existing potential, to apply it for the new potential. More...
#include <potentialselectordialog.h>
Inherits QDialog.
Collaboration diagram for PotentialSelectorDialog:
 PotentialSelectorDialog (Conductor *conductor, QUndoCommand *parent_undo=nullptr, QWidget *parent=nullptr)
 PotentialSelectorDialog::PotentialSelectorDialog Constructor when we link two potentiels together, with a conductor.
 PotentialSelectorDialog (Element *report, QUndoCommand *parent_undo=nullptr, QWidget *parent=nullptr)
 PotentialSelectorDialog::PotentialSelectorDialog Constructor when we link two potentiels together, with a folio report.
 ~PotentialSelectorDialog () override
static ConductorProperties chosenProperties (QList< ConductorProperties > list, QWidget *parent=nullptr, bool *cancelled=nullptr)
Private Slots
void on_buttonBox_accepted ()
 PotentialSelectorDialog::on_buttonBox_accepted Action when user click on OK button.
void buildWidget ()
 PotentialSelectorDialog::buildWidget Build the dialog.
Ui::PotentialSelectorDialog * ui
Conductor * m_conductor
Element * m_report
QUndoCommand * m_parent_undo
autonum::sequentialNumbers m_sequential_num
AbstractPotentialSelector * m_potential_selector
QList< ConductorProperties > m_properties_list
QList< Conductor * > m_conductors_to_change
int m_selected = 0
Each constructor have a QUndoCommand parent_undo for parameter If parent_undo isn't null, when user click on OK button, the dialog will use the parent-undo as parent of the undo command that describe the changes. If parent_undo is null, the created undo-command is push to the undo stack of the parent diagram of a conductor in potential. else we apply the change without a QUndoCommand.
the static function chosenProperties, open a dialog who ask user to make a choice between the given properties. If the dialog is cancelled (Cancel button, Escape, or the window's close button) and cancelled is non-null, *cancelled is set to true and an empty ConductorProperties() is returned; callers that care about a real cancellation (as opposed to "no properties to choose from") should check it rather than relying on the returned value alone.
◆ PotentialSelectorDialog() [1/2]
PotentialSelectorDialog::PotentialSelectorDialog ( Conductor * conductor,
QUndoCommand * parent_undo = nullptr,
QWidget * parent = nullptr )
explicit
conductor: the new conductor who connect to existing potential
parent_undo: undo parent to use.
parent: parent widget.
◆ PotentialSelectorDialog() [2/2]
PotentialSelectorDialog::PotentialSelectorDialog ( Element * report,
explicit
report: one of the report used to link the potentials (report must be linked to another report)
◆ ~PotentialSelectorDialog()
PotentialSelectorDialog::~PotentialSelectorDialog ( )
◆ buildWidget()
void PotentialSelectorDialog::buildWidget ( )
◆ chosenProperties()
ConductorProperties PotentialSelectorDialog::chosenProperties ( QList< ConductorProperties > list,
QWidget * parent = nullptr,
bool * cancelled = nullptr )
static
◆ on_buttonBox_accepted
void PotentialSelectorDialog::on_buttonBox_accepted ( )
privateslot
◆ m_conductor
Conductor* PotentialSelectorDialog::m_conductor
◆ m_conductors_to_change
QList<Conductor *> PotentialSelectorDialog::m_conductors_to_change
◆ m_parent_undo
QUndoCommand* PotentialSelectorDialog::m_parent_undo
◆ m_potential_selector
AbstractPotentialSelector* PotentialSelectorDialog::m_potential_selector
◆ m_properties_list
QList<ConductorProperties> PotentialSelectorDialog::m_properties_list
◆ m_report
Element* PotentialSelectorDialog::m_report
◆ m_selected
int PotentialSelectorDialog::m_selected = 0
◆ m_sequential_num
autonum::sequentialNumbers PotentialSelectorDialog::m_sequential_num
◆ ui
Ui::PotentialSelectorDialog* PotentialSelectorDialog::ui
