ElementPropertiesEditorWidget Class Reference
The ElementPropertiesEditorWidget class This class provide a dialog for edit various property of element, like the type (master, slave, report etc....) and kind info. More...
#include <elementpropertieseditorwidget.h>
Inherits QDialog.
Collaboration diagram for ElementPropertiesEditorWidget:
 ElementPropertiesEditorWidget (ElementData data, QWidget *parent=nullptr)
 ElementPropertiesEditorWidget::ElementPropertiesEditorWidget.
 ~ElementPropertiesEditorWidget () override
 ElementPropertiesEditorWidget::~ElementPropertiesEditorWidget Default destructor.
ElementData editedData ()
Private Slots
void on_m_buttonBox_accepted ()
 ElementPropertiesEditorWidget::on_m_buttonBox_accepted Action on button accepted : the new information is set.
void on_m_base_type_cb_currentIndexChanged (int index)
 ElementPropertiesEditorWidget::on_m_base_type_cb_currentIndexChanged.
void on_m_slave_groups_checkbox_toggled (bool checked)
 ElementPropertiesEditorWidget::on_m_slave_groups_checkbox_toggled When slave groups checkbox is toggled, enable/disable the table Also ensure max_slaves checkbox is checked when enabling groups.
void on_max_slaves_checkbox_toggled (bool checked)
 ElementPropertiesEditorWidget::on_max_slaves_checkbox_toggled When max_slaves checkbox is unchecked, also uncheck slave groups checkbox.
void plcAddRow ()
 ElementPropertiesEditorWidget::plcAddRow Add a new empty row to the PLC IO table.
void plcRemoveRow ()
 ElementPropertiesEditorWidget::plcRemoveRow Remove selected rows from the PLC IO table.
void plcPasteFromClipboard ()
 ElementPropertiesEditorWidget::plcPasteFromClipboard Paste IO data from clipboard (tab-separated, e.g. from Excel).
void plcTerminalCountChanged (int row, int count)
 ElementPropertiesEditorWidget::plcTerminalCountChanged Enable/disable T1-T4 cells and grow columns based on terminal count spinner for a row.
void plcSelectHeaderFont ()
 ElementPropertiesEditorWidget::plcSelectHeaderFont Open font dialog to select column header font.
void plcSelectCellFont ()
 ElementPropertiesEditorWidget::plcSelectCellFont Open font dialog to select cell text font.
void plcSetCellFromValue (int row, int col, const QString &val)
 ElementPropertiesEditorWidget::plcSetCellFromValue Set a single table cell value, respecting the column widget type.
void upDateInterface ()
 ElementPropertiesEditorWidget::upDateInterface Update the interface with the current value.
void setUpInterface ()
 ElementPropertiesEditorWidget::setUpInterface.
void updateTree ()
void populateTree ()
 ElementPropertiesEditorWidget::populateTree Create QTreeWidgetItem of the tree widget and populate it.
void populateSlaveGroupsTable ()
 ElementPropertiesEditorWidget::populateSlaveGroupsTable Fill the slave contact groups table from m_data.
void readSlaveGroupsFromTable ()
 ElementPropertiesEditorWidget::readSlaveGroupsFromTable Read the slave contact groups from the table back into m_data.
void createPlcConfigWidgets ()
 ElementPropertiesEditorWidget::createPlcConfigWidgets Create the PLC configuration widgets programmatically and add them to m_master_gb.
void populatePlcTable ()
 ElementPropertiesEditorWidget::populatePlcTable Fill the PLC table from m_data.
void readPlcTable ()
 ElementPropertiesEditorWidget::readPlcTable Read the PLC data from the table back into m_data.
Ui::ElementPropertiesEditorWidget * ui
ElementData m_data
QGroupBox * m_plc_gb = nullptr
QTableWidget * m_plc_table = nullptr
QTableWidget * m_plc_terminal_table = nullptr
QCheckBox * m_plc_break_checkboxes [4] = {nullptr, nullptr, nullptr, nullptr}
QSpinBox * m_plc_break_spinboxes [4] = {nullptr, nullptr, nullptr, nullptr}
QSpinBox * m_plc_row_height_spinbox = nullptr
QPushButton * m_plc_header_font_btn = nullptr
QPushButton * m_plc_cell_font_btn = nullptr
QCheckBox * m_plc_show_headers_cb = nullptr
QFont m_plc_header_font
QFont m_plc_cell_font
QList< QCheckBox * > m_plc_col_visibility_checkboxes
QList< QSpinBox * > m_plc_col_width_spinboxes
QList< QLineEdit * > m_plc_col_name_edits
QScrollBar * m_plc_shared_scrollbar = nullptr
bool m_plc_scroll_sync = false
◆ ElementPropertiesEditorWidget()
ElementPropertiesEditorWidget::ElementPropertiesEditorWidget ( ElementData data,
QWidget * parent = nullptr )
explicit
data
parent
◆ ~ElementPropertiesEditorWidget()
ElementPropertiesEditorWidget::~ElementPropertiesEditorWidget ( )
◆ createPlcConfigWidgets()
void ElementPropertiesEditorWidget::createPlcConfigWidgets ( )
◆ editedData()
ElementData ElementPropertiesEditorWidget::editedData ( )
inline
◆ on_m_base_type_cb_currentIndexChanged
void ElementPropertiesEditorWidget::on_m_base_type_cb_currentIndexChanged ( int index)
privateslot
index: Action when combo-box base type index change
◆ on_m_buttonBox_accepted
void ElementPropertiesEditorWidget::on_m_buttonBox_accepted ( )
privateslot
◆ on_m_slave_groups_checkbox_toggled
void ElementPropertiesEditorWidget::on_m_slave_groups_checkbox_toggled ( bool checked)
privateslot
◆ on_max_slaves_checkbox_toggled
void ElementPropertiesEditorWidget::on_max_slaves_checkbox_toggled ( bool checked)
privateslot
◆ plcAddRow
void ElementPropertiesEditorWidget::plcAddRow ( )
privateslot
◆ plcPasteFromClipboard
void ElementPropertiesEditorWidget::plcPasteFromClipboard ( )
privateslot
◆ plcRemoveRow
void ElementPropertiesEditorWidget::plcRemoveRow ( )
privateslot
◆ plcSelectCellFont
void ElementPropertiesEditorWidget::plcSelectCellFont ( )
privateslot
◆ plcSelectHeaderFont
void ElementPropertiesEditorWidget::plcSelectHeaderFont ( )
privateslot
◆ plcSetCellFromValue
void ElementPropertiesEditorWidget::plcSetCellFromValue ( int row,
int col,
const QString & val )
privateslot
◆ plcTerminalCountChanged
void ElementPropertiesEditorWidget::plcTerminalCountChanged ( int row,
int count )
privateslot
◆ populatePlcTable()
void ElementPropertiesEditorWidget::populatePlcTable ( )
◆ populateSlaveGroupsTable()
void ElementPropertiesEditorWidget::populateSlaveGroupsTable ( )
◆ populateTree()
void ElementPropertiesEditorWidget::populateTree ( )
◆ readPlcTable()
void ElementPropertiesEditorWidget::readPlcTable ( )
◆ readSlaveGroupsFromTable()
void ElementPropertiesEditorWidget::readSlaveGroupsFromTable ( )
◆ setUpInterface()
void ElementPropertiesEditorWidget::setUpInterface ( )
◆ upDateInterface()
void ElementPropertiesEditorWidget::upDateInterface ( )
◆ updateTree()
void ElementPropertiesEditorWidget::updateTree ( )
◆ m_data
ElementData ElementPropertiesEditorWidget::m_data
◆ m_plc_break_checkboxes
QCheckBox* ElementPropertiesEditorWidget::m_plc_break_checkboxes[4] = {nullptr, nullptr, nullptr, nullptr}
◆ m_plc_break_spinboxes
QSpinBox* ElementPropertiesEditorWidget::m_plc_break_spinboxes[4] = {nullptr, nullptr, nullptr, nullptr}
◆ m_plc_cell_font
QFont ElementPropertiesEditorWidget::m_plc_cell_font
◆ m_plc_cell_font_btn
QPushButton* ElementPropertiesEditorWidget::m_plc_cell_font_btn = nullptr
◆ m_plc_col_name_edits
QList<QLineEdit *> ElementPropertiesEditorWidget::m_plc_col_name_edits
◆ m_plc_col_visibility_checkboxes
QList<QCheckBox *> ElementPropertiesEditorWidget::m_plc_col_visibility_checkboxes
◆ m_plc_col_width_spinboxes
QList<QSpinBox *> ElementPropertiesEditorWidget::m_plc_col_width_spinboxes
◆ m_plc_gb
QGroupBox* ElementPropertiesEditorWidget::m_plc_gb = nullptr
◆ m_plc_header_font
QFont ElementPropertiesEditorWidget::m_plc_header_font
◆ m_plc_header_font_btn
QPushButton* ElementPropertiesEditorWidget::m_plc_header_font_btn = nullptr
◆ m_plc_row_height_spinbox
QSpinBox* ElementPropertiesEditorWidget::m_plc_row_height_spinbox = nullptr
◆ m_plc_scroll_sync
bool ElementPropertiesEditorWidget::m_plc_scroll_sync = false
◆ m_plc_shared_scrollbar
QScrollBar* ElementPropertiesEditorWidget::m_plc_shared_scrollbar = nullptr
◆ m_plc_show_headers_cb
QCheckBox* ElementPropertiesEditorWidget::m_plc_show_headers_cb = nullptr
◆ m_plc_table
QTableWidget* ElementPropertiesEditorWidget::m_plc_table = nullptr
◆ m_plc_terminal_table
QTableWidget* ElementPropertiesEditorWidget::m_plc_terminal_table = nullptr
◆ ui
Ui::ElementPropertiesEditorWidget* ElementPropertiesEditorWidget::ui
