IndependentTextItem Class Reference
#include <independenttextitem.h>
Inheritance diagram for IndependentTextItem:
Collaboration diagram for IndependentTextItem:
Public Types
enum  { Type = UserType + 1005 }
Public Types inherited from DiagramTextItem
enum  { Type = UserType + 1004 }
 IndependentTextItem ()
 IndependentTextItem (const QString &)
 IndependentTextItem::IndependentTextItem Constructeur.
 ~IndependentTextItem () override
 Destructeur.
int type () const override
void fromXml (const QDomElement &) override
QDomElement toXml (QDomDocument &) const override
Public Member Functions inherited from DiagramTextItem
 DiagramTextItem (QGraphicsItem *=nullptr)
 DiagramTextItem::DiagramTextItem.
 DiagramTextItem (const QString &, QGraphicsItem *=nullptr)
Diagram * diagram () const
 DiagramTextItem::diagram.
void edit ()
 Edit the text with HtmlEditor.
QPointF mapMovementToScene (const QPointF &) const
QPointF mapMovementFromScene (const QPointF &) const
QPointF mapMovementToParent (const QPointF &) const
QPointF mapMovementFromParent (const QPointF &) const
void setFont (const QFont &font)
void setColor (const QColor &color)
QColor color () const
void setNoEditable (bool e=true)
void setAlignment (const Qt::Alignment &alignment)
Qt::Alignment alignment () const
QRectF frameRect () const
 DiagramTextItem::frameRect.
void setHtml (const QString &text)
void setPlainText (const QString &text)
bool isHtml () const
Protected Member Functions
void focusOutEvent (QFocusEvent *event) override
Protected Member Functions inherited from DiagramTextItem
void paint (QPainter *, const QStyleOptionGraphicsItem *, QWidget *) override
 DiagramTextItem::paint Draw this text field. This method draws the text by calling QGraphicsTextItem::paint. If text is hovered, this method draws the bounding rect in grey.
void focusInEvent (QFocusEvent *) override
 DiagramTextItem::focusInEvent.
void focusOutEvent (QFocusEvent *) override
 DiagramTextItem::focusOutEvent.
 DiagramTextItem::mousePressEvent.
 DiagramTextItem::mouseMoveEvent.
 DiagramTextItem::mouseReleaseEvent.
void hoverEnterEvent (QGraphicsSceneHoverEvent *) override
void hoverLeaveEvent (QGraphicsSceneHoverEvent *) override
void hoverMoveEvent (QGraphicsSceneHoverEvent *) override
virtual void applyRotation (const qreal &)
void prepareAlignment ()
 DiagramTextItem::prepareAlignment Call this function before changing the bounding rect of this text.
void finishAlignment ()
 DiagramTextItem::finishAlignment Call this function after changing the bounding rect of this text to set the position of this text according to the alignment property.
Additional Inherited Members
Signals inherited from DiagramTextItem
void colorChanged (QColor color)
void alignmentChanged (Qt::Alignment alignment)
void textEdited (const QString &old_str, const QString &new_str)
void fontChanged (QFont font)
Public Attributes inherited from DiagramTextItem
bool m_block_alignment = false
Protected Attributes inherited from DiagramTextItem
bool m_mouse_hover = false
bool m_first_move = true
bool m_no_editable
bool m_is_html = false
bool m_non_left_alignment = false
QString m_previous_html_text
QString m_previous_text
QPointF m_mouse_to_origin_movement
Properties inherited from DiagramTextItem
QColor color
QString plainText
QFont font
This class represents an independent text field on a particular diagram. It may be moved, edited, and rotated.
◆ anonymous enum
anonymous enum
Enumerator
Type
◆ IndependentTextItem() [1/2]
IndependentTextItem::IndependentTextItem ( )
Constructeur
parent_diagramLe schema auquel est rattache le champ de texte
◆ IndependentTextItem() [2/2]
IndependentTextItem::IndependentTextItem ( const QString & text)
textLe texte affiche par le champ de texte
◆ ~IndependentTextItem()
IndependentTextItem::~IndependentTextItem ( )
Destructeur.
◆ focusOutEvent()
void IndependentTextItem::focusOutEvent ( QFocusEvent * event)
overrideprotected
◆ fromXml()
void IndependentTextItem::fromXml ( const QDomElement & e)
overridevirtual
Permet de lire le texte a mettre dans le champ a partir d'un element XML. Cette methode se base sur la position du champ pour assigner ou non la valeur a ce champ.
eL'element XML representant le champ de texte
Implements DiagramTextItem.
◆ toXml()
QDomElement IndependentTextItem::toXml ( QDomDocument & document) const
overridevirtual
documentLe document XML a utiliser
L'element XML representant ce champ de texte
Reimplemented from DiagramTextItem.
◆ type()
int IndependentTextItem::type ( ) const
inlineoverride
