CropAreaWidget Class Reference
The CropAreaWidget class Displays the image scaled to fit a reasonable dialog size, with a draggable, resizable crop rectangle overlaid on top – the area outside it dimmed, the usual visual convention for "this part goes away" during a crop, so it's never ambiguous which region survives. All internal geometry (the crop rect, drag handling, hit-testing) works in display-space pixel coordinates; only cropRect() converts back to the original, full-resolution image's own coordinates for the caller, the same original-vs-display distinction already used for colour sampling in ImageTransparentColorDialog. More...
#include <imagecropdialog.h>
Inherits QWidget.
Collaboration diagram for CropAreaWidget:
Public Slots
void resetToFullImage ()
 CropAreaWidget::resetToFullImage.
Signals
void cropRectChanged ()
 CropAreaWidget (const QImage &sourceImage, const QRect &initialCropRect=QRect(), QWidget *parent=nullptr)
 CropAreaWidget::CropAreaWidget.
QRect cropRect () const
 CropAreaWidget::cropRect.
Protected Member Functions
void paintEvent (QPaintEvent *event) override
 CropAreaWidget::paintEvent Draws the image, dims everything outside the crop rect (four strips around it, rather than one overlay with a hole cut out of it, since that would need a more involved clip/composition setup for no real benefit here), then the rect's own dashed border and its eight handles.
void mousePressEvent (QMouseEvent *event) override
void mouseMoveEvent (QMouseEvent *event) override
void mouseReleaseEvent (QMouseEvent *event) override
Private Types
enum class  DragMode {
  None , Move , ResizeN , ResizeS ,
  ResizeE , ResizeW , ResizeNE , ResizeNW ,
  ResizeSE , ResizeSW
DragMode handleAt (const QPoint &pos) const
 CropAreaWidget::handleAt.
void applyDrag (const QPoint &pos)
 CropAreaWidget::applyDrag Recomputes m_cropRect from m_dragStartRect plus however far pos has moved from m_dragStartPos, according to m_dragMode – always clamped to stay within the displayed image and never smaller than MIN_CROP_SIZE, so the rect can never escape its bounds or collapse to nothing while being dragged.
QImage m_source
qreal m_displayScale = 1.0
QRect m_displayImageRect
QRect m_cropRect
DragMode m_dragMode = DragMode::None
QPoint m_dragStartPos
QRect m_dragStartRect
Static Private Attributes
static constexpr int HANDLE_SIZE = 8
static constexpr int MIN_CROP_SIZE = 16
◆ DragMode
enum class CropAreaWidget::DragMode
strongprivate
Enumerator
None
Move
ResizeN
ResizeS
ResizeE
ResizeW
ResizeNE
ResizeNW
ResizeSE
ResizeSW
◆ CropAreaWidget()
CropAreaWidget::CropAreaWidget ( const QImage & sourceImage,
const QRect & initialCropRect = QRect(),
QWidget * parent = nullptr )
explicit
sourceImagethe full, uncropped image to crop from
initialCropRecta previously-chosen crop rectangle, in sourceImage's own coordinates, to start from – an empty (default-constructed) QRect means "no previous crop", i.e. start covering the whole image.
sourceImagethe full-resolution image to crop
initialCropRecta previously-chosen crop rect (in sourceImage's own coordinates), or an empty QRect to start covering the whole image
parent
◆ applyDrag()
void CropAreaWidget::applyDrag ( const QPoint & pos)
poscurrent widget-space mouse position
◆ cropRect()
QRect CropAreaWidget::cropRect ( ) const
The current crop rectangle, in the original image's own coordinates (not display-space) – always clamped to the image's own bounds and never degenerate (zero width/height).
the crop rectangle in the original, full-resolution image's own coordinates – m_cropRect itself is display-space only.
◆ cropRectChanged
void CropAreaWidget::cropRectChanged ( )
signal
◆ handleAt()
CropAreaWidget::DragMode CropAreaWidget::handleAt ( const QPoint & pos) const
poswidget-space position to test
whichever handle (or the rect's own interior, for moving) pos is close enough to, or DragMode::None if it's not near anything
◆ mouseMoveEvent()
void CropAreaWidget::mouseMoveEvent ( QMouseEvent * event)
overrideprotected
◆ mousePressEvent()
void CropAreaWidget::mousePressEvent ( QMouseEvent * event)
overrideprotected
◆ mouseReleaseEvent()
void CropAreaWidget::mouseReleaseEvent ( QMouseEvent * event)
overrideprotected
◆ paintEvent()
void CropAreaWidget::paintEvent ( QPaintEvent * event)
overrideprotected
◆ resetToFullImage
void CropAreaWidget::resetToFullImage ( )
slot
Resets the crop rectangle back to covering the entire image – the direct answer to "I want to undo the crop, not just adjust it", since dragging every handle back out by hand to exactly the original extent is needlessly fiddly.
◆ HANDLE_SIZE
int CropAreaWidget::HANDLE_SIZE = 8
staticconstexprprivate
◆ m_cropRect
QRect CropAreaWidget::m_cropRect
◆ m_displayImageRect
QRect CropAreaWidget::m_displayImageRect
◆ m_displayScale
qreal CropAreaWidget::m_displayScale = 1.0
◆ m_dragMode
DragMode CropAreaWidget::m_dragMode = DragMode::None
◆ m_dragStartPos
QPoint CropAreaWidget::m_dragStartPos
◆ m_dragStartRect
QRect CropAreaWidget::m_dragStartRect
◆ m_source
QImage CropAreaWidget::m_source
◆ MIN_CROP_SIZE
int CropAreaWidget::MIN_CROP_SIZE = 16
