QElectroTech 0.200.1-dev
The MachineInfo class This class hold information from your PC. More...
#include <machine_info.h>
Classes | |
| struct | Pc |
Public Member Functions | |
| int32_t | i_max_screen_width () |
| MachineInfo::i_max_screen_width. | |
| int32_t | i_max_screen_height () |
| MachineInfo::i_max_screen_height. | |
| int32_t | i_max_available_width () |
| MachineInfo::i_max_available_width. | |
| int32_t | i_max_available_height () |
| MachineInfo::i_max_available_height. | |
| QString | compilation_info () |
| MachineInfo::compilation_info. | |
| void | send_info_to_debug () |
| MachineInfo::send_info_to_debug. | |
Static Public Member Functions | |
| static MachineInfo * | instance () |
| static void | dropInstance () |
Private Member Functions | |
| MachineInfo () | |
| MachineInfo::MachineInfo. | |
| void | init_get_Screen_info () |
| MachineInfo::init_get_Screen_info Finds the largest screen and saves the values. | |
| void | init_get_cpu_info () |
| MachineInfo::init_get_cpu_info. | |
| void | init_get_cpu_info_linux () |
| MachineInfo::init_get_cpu_info_linux. | |
| void | init_get_cpu_info_winnt () |
| MachineInfo::init_get_cpu_info_winnt. | |
| void | init_get_cpu_info_macos () |
| MachineInfo::init_get_cpu_info_macos. | |
Private Attributes | |
| struct MachineInfo::Pc | pc |
Static Private Attributes | |
| static MachineInfo * | m_instance = nullptr |
private |
| parent |
| QString MachineInfo::compilation_info | ( | ) |
inlinestatic |
| int32_t MachineInfo::i_max_available_height | ( | ) |
| int32_t MachineInfo::i_max_available_width | ( | ) |
| int32_t MachineInfo::i_max_screen_height | ( | ) |
| int32_t MachineInfo::i_max_screen_width | ( | ) |
private |
private |
private |
private |
private |
inlinestatic |
| void MachineInfo::send_info_to_debug | ( | ) |
staticprivate |
private |
