ElementsPanelWidget Class Reference
The ElementsPanelWidget class This class embeds an elements panel under a toolbar providing various actions to manage elements. More...
#include <elementspanelwidget.h>
Inherits QWidget.
Collaboration diagram for ElementsPanelWidget:
Public Slots
void openDirectoryForSelectedItem ()
void copyPathForSelectedItem ()
void reloadAndFilter ()
void activateProject ()
void closeProject ()
void editProjectProperties ()
void editDiagramProperties ()
void newDiagram ()
void insertDiagramAbove ()
 ElementsPanelWidget::insertDiagramAbove Emit requestForNewDiagramAt with the position of the currently selected diagram, inserting the new folio right before it.
void insertDiagramBelow ()
 ElementsPanelWidget::insertDiagramBelow Emit requestForNewDiagramAt with the position right after the currently selected diagram, inserting the new folio right after it.
void deleteDiagram ()
void duplicateDiagram ()
void moveDiagramUp ()
void moveDiagramDown ()
void moveDiagramUpTop ()
void moveDiagramUpx10 ()
void moveDiagramUpx100 ()
void moveDiagramDownx10 ()
void moveDiagramDownx100 ()
void addTitleBlockTemplate ()
void editTitleBlockTemplate ()
void removeTitleBlockTemplate ()
void updateButtons ()
void handleContextMenu (const QPoint &)
void filterEdited (const QString &)
Signals
void requestForProject (QETProject *)
void requestForNewDiagram (QETProject *)
void requestForNewDiagramAt (QETProject *, int)
void requestForProjectClosing (QETProject *)
void requestForProjectPropertiesEdition (QETProject *)
void requestForDiagramPropertiesEdition (Diagram *)
void requestForDiagramDeletion (Diagram *)
void requestForDiagramsDeletion (const QList< Diagram * > &diagrams)
void requestForDiagramMoveUp (const QList< Diagram * > &diagrams)
void requestForDiagramMoveDown (const QList< Diagram * > &diagrams)
void requestForDiagramMoveUpTop (const QList< Diagram * > &diagrams)
void requestForDiagramMoveUpx10 (const QList< Diagram * > &diagrams)
void requestForDiagramMoveUpx100 (const QList< Diagram * > &diagrams)
void requestForDiagramMoveDownx10 (const QList< Diagram * > &diagrams)
void requestForDiagramMoveDownx100 (const QList< Diagram * > &diagrams)
 ElementsPanelWidget (QWidget *=nullptr)
 ~ElementsPanelWidget () override
ElementsPanel & elementsPanel () const
 ElementsPanelWidget::elementsPanel.
Protected Member Functions
void keyPressEvent (QKeyEvent *e) override
 ElementsPanelWidget (const ElementsPanelWidget &)
ElementsPanel * elements_panel
QAction * open_directory
QAction * copy_path
QAction * prj_activate
QAction * prj_close
QAction * prj_edit_prop
QAction * prj_prop_diagram
QAction * prj_add_diagram
QAction * prj_insert_diagram_above
QAction * prj_insert_diagram_below
QAction * prj_del_diagram
QAction * prj_duplicate_diagram
QAction * prj_move_diagram_up
QAction * prj_move_diagram_top
QAction * prj_move_diagram_down
QAction * prj_move_diagram_upx10
QAction * prj_move_diagram_upx100
QAction * prj_move_diagram_downx10
QAction * prj_move_diagram_downx100
QAction * tbt_add
QAction * tbt_edit
QAction * tbt_remove
QMenu * context_menu
QLineEdit * filter_textfield
QString previous_filter_
See also
ElementsPanel
◆ ElementsPanelWidget() [1/2]
ElementsPanelWidget::ElementsPanelWidget ( QWidget * parent = nullptr)
Constructeur
parentLe QWidget parent de ce widget
◆ ~ElementsPanelWidget()
ElementsPanelWidget::~ElementsPanelWidget ( )
Destructeur
◆ ElementsPanelWidget() [2/2]
ElementsPanelWidget::ElementsPanelWidget ( const ElementsPanelWidget & )
◆ activateProject
void ElementsPanelWidget::activateProject ( )
slot
Emit the requestForProject signal with the selected project
◆ addTitleBlockTemplate
void ElementsPanelWidget::addTitleBlockTemplate ( )
slot
Opens a template editor to create a new title block template.
◆ closeProject
void ElementsPanelWidget::closeProject ( )
slot
Emet le signal requestForProjectClosing avec le projet selectionne
◆ copyPathForSelectedItem
void ElementsPanelWidget::copyPathForSelectedItem ( )
slot
Copy the full path to the file represented by the selected item to the clipboard.
◆ deleteDiagram
void ElementsPanelWidget::deleteDiagram ( )
slot
Emet le signal requestForDiagramsDeletion avec les schemas selectionnes
◆ duplicateDiagram
void ElementsPanelWidget::duplicateDiagram ( )
slot
Duplicates the selected folios (pages) along with their content and properties, and cleanly resolves cross-references.
◆ editDiagramProperties
void ElementsPanelWidget::editDiagramProperties ( )
slot
Emet le signal requestForDiagramPropertiesEdition avec le schema selectionne
◆ editProjectProperties
void ElementsPanelWidget::editProjectProperties ( )
slot
Emet le signal requestForProjectPropertiesEdition avec le projet selectionne
◆ editTitleBlockTemplate
void ElementsPanelWidget::editTitleBlockTemplate ( )
slot
Opens an editor to edit the currently selected title block template, if any.
◆ elementsPanel()
ElementsPanel & ElementsPanelWidget::elementsPanel ( ) const
inline
The elements panel embedded within this widget.
◆ filterEdited
void ElementsPanelWidget::filterEdited ( const QString & next_text)
slot
◆ handleContextMenu
void ElementsPanelWidget::handleContextMenu ( const QPoint & pos)
slot
Gere le menu contextuel du panel d'elements
posPosition ou le menu contextuel a ete demande
◆ insertDiagramAbove
void ElementsPanelWidget::insertDiagramAbove ( )
slot
◆ insertDiagramBelow
void ElementsPanelWidget::insertDiagramBelow ( )
slot
◆ keyPressEvent()
void ElementsPanelWidget::keyPressEvent ( QKeyEvent * e)
overrideprotected
Treat key press event inside elements panel widget Treat key press event inside elements panel widget. Respects the enabled/disabled state of the corresponding QActions.
◆ moveDiagramDown
void ElementsPanelWidget::moveDiagramDown ( )
slot
Emits the requestForDiagramMoveDown signal with all selected diagrams.
◆ moveDiagramDownx10
void ElementsPanelWidget::moveDiagramDownx10 ( )
slot
Emits the requestForDiagramMoveDownx10 signal with all selected diagrams.
◆ moveDiagramDownx100
void ElementsPanelWidget::moveDiagramDownx100 ( )
slot
Emits the requestForDiagramMoveDownx100 signal with all selected diagrams.
◆ moveDiagramUp
void ElementsPanelWidget::moveDiagramUp ( )
slot
Emits the requestForDiagramMoveUp signal with all selected diagrams.
◆ moveDiagramUpTop
void ElementsPanelWidget::moveDiagramUpTop ( )
slot
Emits the requestForDiagramMoveUpTop signal with all selected diagrams.
◆ moveDiagramUpx10
void ElementsPanelWidget::moveDiagramUpx10 ( )
slot
Emits the requestForDiagramMoveUpx10 signal with all selected diagrams.
◆ moveDiagramUpx100
void ElementsPanelWidget::moveDiagramUpx100 ( )
slot
Emits the requestForDiagramMoveUpx100 signal with all selected diagrams.
◆ newDiagram
void ElementsPanelWidget::newDiagram ( )
slot
Emet le signal requestForNewDiagram avec le projet selectionne
◆ openDirectoryForSelectedItem
void ElementsPanelWidget::openDirectoryForSelectedItem ( )
slot
Require the desktop environment to open the directory containing the file represented by the selected item, if any.
◆ reloadAndFilter
void ElementsPanelWidget::reloadAndFilter ( )
slot
Recharge le panel d'elements
◆ removeTitleBlockTemplate
void ElementsPanelWidget::removeTitleBlockTemplate ( )
slot
Delete the currently selected title block template, if any.
◆ requestForDiagramDeletion
void ElementsPanelWidget::requestForDiagramDeletion ( Diagram * )
signal
◆ requestForDiagramMoveDown
void ElementsPanelWidget::requestForDiagramMoveDown ( const QList< Diagram * > & diagrams)
signal
◆ requestForDiagramMoveDownx10
void ElementsPanelWidget::requestForDiagramMoveDownx10 ( const QList< Diagram * > & diagrams)
signal
◆ requestForDiagramMoveDownx100
void ElementsPanelWidget::requestForDiagramMoveDownx100 ( const QList< Diagram * > & diagrams)
signal
◆ requestForDiagramMoveUp
void ElementsPanelWidget::requestForDiagramMoveUp ( const QList< Diagram * > & diagrams)
signal
◆ requestForDiagramMoveUpTop
void ElementsPanelWidget::requestForDiagramMoveUpTop ( const QList< Diagram * > & diagrams)
signal
◆ requestForDiagramMoveUpx10
void ElementsPanelWidget::requestForDiagramMoveUpx10 ( const QList< Diagram * > & diagrams)
signal
◆ requestForDiagramMoveUpx100
void ElementsPanelWidget::requestForDiagramMoveUpx100 ( const QList< Diagram * > & diagrams)
signal
◆ requestForDiagramPropertiesEdition
void ElementsPanelWidget::requestForDiagramPropertiesEdition ( Diagram * )
signal
◆ requestForDiagramsDeletion
void ElementsPanelWidget::requestForDiagramsDeletion ( const QList< Diagram * > & diagrams)
signal
◆ requestForNewDiagram
void ElementsPanelWidget::requestForNewDiagram ( QETProject * )
signal
◆ requestForNewDiagramAt
void ElementsPanelWidget::requestForNewDiagramAt ( QETProject * ,
int  )
signal
◆ requestForProject
void ElementsPanelWidget::requestForProject ( QETProject * )
signal
◆ requestForProjectClosing
void ElementsPanelWidget::requestForProjectClosing ( QETProject * )
signal
◆ requestForProjectPropertiesEdition
void ElementsPanelWidget::requestForProjectPropertiesEdition ( QETProject * )
signal
◆ updateButtons
void ElementsPanelWidget::updateButtons ( )
slot
Met a jour les boutons afin d'assurer la coherence de l'interface
◆ context_menu
QMenu* ElementsPanelWidget::context_menu
◆ copy_path
QAction * ElementsPanelWidget::copy_path
◆ elements_panel
ElementsPanel* ElementsPanelWidget::elements_panel
◆ filter_textfield
QLineEdit* ElementsPanelWidget::filter_textfield
◆ open_directory
QAction* ElementsPanelWidget::open_directory
◆ previous_filter_
QString ElementsPanelWidget::previous_filter_
◆ prj_activate
QAction* ElementsPanelWidget::prj_activate
◆ prj_add_diagram
QAction * ElementsPanelWidget::prj_add_diagram
◆ prj_close
QAction * ElementsPanelWidget::prj_close
◆ prj_del_diagram
QAction * ElementsPanelWidget::prj_del_diagram
◆ prj_duplicate_diagram
QAction * ElementsPanelWidget::prj_duplicate_diagram
◆ prj_edit_prop
QAction * ElementsPanelWidget::prj_edit_prop
◆ prj_insert_diagram_above
QAction * ElementsPanelWidget::prj_insert_diagram_above
◆ prj_insert_diagram_below
QAction * ElementsPanelWidget::prj_insert_diagram_below
◆ prj_move_diagram_down
QAction * ElementsPanelWidget::prj_move_diagram_down
◆ prj_move_diagram_downx10
QAction * ElementsPanelWidget::prj_move_diagram_downx10
◆ prj_move_diagram_downx100
QAction * ElementsPanelWidget::prj_move_diagram_downx100
◆ prj_move_diagram_top
QAction * ElementsPanelWidget::prj_move_diagram_top
◆ prj_move_diagram_up
QAction * ElementsPanelWidget::prj_move_diagram_up
◆ prj_move_diagram_upx10
QAction * ElementsPanelWidget::prj_move_diagram_upx10
◆ prj_move_diagram_upx100
QAction * ElementsPanelWidget::prj_move_diagram_upx100
◆ prj_prop_diagram
QAction * ElementsPanelWidget::prj_prop_diagram
◆ tbt_add
QAction* ElementsPanelWidget::tbt_add
◆ tbt_edit
QAction * ElementsPanelWidget::tbt_edit
◆ tbt_remove
QAction * ElementsPanelWidget::tbt_remove
