QETArguments Class Reference
#include <qetarguments.h>
Inherits QObject.
Collaboration diagram for QETArguments:
 QETArguments (QObject *=nullptr)
 QETArguments (const QList< QString > &, QObject *=nullptr)
 QETArguments (const QETArguments &)
QETArguments & operator= (const QETArguments &)
 ~QETArguments () override
virtual void setArguments (const QList< QString > &)
virtual QList< QString > arguments () const
virtual QList< QString > files () const
virtual QList< QString > projectFiles () const
virtual QList< QString > elementFiles () const
virtual QList< QString > titleBlockTemplateFiles () const
virtual bool langDirSpecified () const
virtual QString langDir () const
virtual bool printHelpRequested () const
virtual bool printLicenseRequested () const
virtual bool printVersionRequested () const
virtual QList< QString > options () const
virtual QList< QString > unknownOptions () const
void clear ()
void parseArguments (const QList< QString > &)
void handleFileArgument (const QString &)
void handleOptionArgument (const QString &)
QList< QString > project_files_
QList< QString > element_files_
QList< QString > tbt_files_
QList< QString > options_
QList< QString > unknown_options_
QString lang_dir_
bool print_help_
bool print_license_
bool print_version_
This class represents a set of arguments the application has received as parameters. Initialized from a list of strings, an instance of this class provides access to the differents options and files given on the command line.
◆ QETArguments() [1/3]
QETArguments::QETArguments ( QObject * parent = nullptr)
Constructeur par defaut Cree un objet sans argument.
◆ QETArguments() [2/3]
QETArguments::QETArguments ( const QList< QString > & args,
QObject * parent = nullptr )
Constructeur
argsArguments a analyser et memoriser
parentQObject parent
◆ QETArguments() [3/3]
QETArguments::QETArguments ( const QETArguments & qet_arguments)
Constructeur de copie - la copie reprend le parent de l'original
qet_argumentsObjet a copier
◆ ~QETArguments()
QETArguments::~QETArguments ( )
Destructeur
◆ arguments()
QList< QString > QETArguments::arguments ( ) const
virtual
tous les arguments (projets et elements) passes en parametres dans l'ordre suivant : options connues puis inconnues, fichiers de types projet puis element.
◆ clear()
void QETArguments::clear ( )
Oublie tous les arguments de cet objet
◆ elementFiles()
QList< QString > QETArguments::elementFiles ( ) const
virtual
les fichiers de type element
◆ files()
QList< QString > QETArguments::files ( ) const
virtual
tous les fichiers (projets et elements) passes en parametres. Les fichiers de type projet viennent avant les fichiers de type element.
◆ handleFileArgument()
void QETArguments::handleFileArgument ( const QString & file)
Gere les arguments correspondant a un fichier existant.
◆ handleOptionArgument()
void QETArguments::handleOptionArgument ( const QString & option)
Gere les arguments correspondant potentiellement a une option. Les options reconnues sont : –common-elements-dir= –common-tbt-dir –config-dir= –data-dir= –lang-dir= –help –version -v –license
◆ langDir()
QString QETArguments::langDir ( ) const
virtual
le dossier de langue specifie par l'utilisateur. Si l'utilisateur n'en a pas specifie, une chaine vide est retournee.
◆ langDirSpecified()
bool QETArguments::langDirSpecified ( ) const
virtual
true si l'utilisateur a specifie un dossier pour les fichiers de langue
◆ operator=()
QETArguments & QETArguments::operator= ( const QETArguments & qet_arguments)
Operateur d'affectation - la copie ne reprend pas le parent de l'original
◆ options()
QList< QString > QETArguments::options ( ) const
virtual
les options reconnues
◆ parseArguments()
void QETArguments::parseArguments ( const QList< QString > & arguments)
Analyse des arguments et les retient dans cet objet. Si cet objet contenait deja des arguments, ceux-ci sont oublies.
argumentsArguments a analyser
◆ printHelpRequested()
bool QETArguments::printHelpRequested ( ) const
virtual
true si les arguments comportent une demande d'affichage de l'aide, false sinon
◆ printLicenseRequested()
bool QETArguments::printLicenseRequested ( ) const
virtual
true si les arguments comportent une demande d'affichage de la licence, false sinon
◆ printVersionRequested()
bool QETArguments::printVersionRequested ( ) const
virtual
true si les arguments comportent une demande d'affichage de la version, false sinon
◆ projectFiles()
QList< QString > QETArguments::projectFiles ( ) const
virtual
les fichiers de type projet
◆ setArguments()
void QETArguments::setArguments ( const QList< QString > & args)
virtual
Definit les arguments de cet objet. Si cet objet contenait deja des arguments, ceux-ci sont oublies.
◆ titleBlockTemplateFiles()
QList< QString > QETArguments::titleBlockTemplateFiles ( ) const
virtual
title block template files
◆ unknownOptions()
QList< QString > QETArguments::unknownOptions ( ) const
virtual
les options non reconnues
◆ element_files_
QList<QString> QETArguments::element_files_
◆ lang_dir_
QString QETArguments::lang_dir_
◆ options_
QList<QString> QETArguments::options_
◆ print_help_
bool QETArguments::print_help_
◆ print_license_
bool QETArguments::print_license_
◆ print_version_
bool QETArguments::print_version_
◆ project_files_
QList<QString> QETArguments::project_files_
◆ tbt_files_
QList<QString> QETArguments::tbt_files_
◆ unknown_options_
QList<QString> QETArguments::unknown_options_
