ShortcutsConfigPage Class Reference
The ShortcutsConfigPage class Configuration page listing every shortcut registered with ShortcutManager, letting the user rebind, reset and search them. Bindings are only persisted (via ShortcutManager::setSequence()) when applyConf() runs, i.e. when the user validates the surrounding ConfigDialog. More...
#include <shortcutsconfigpage.h>
Inheritance diagram for ShortcutsConfigPage:
Collaboration diagram for ShortcutsConfigPage:
struct  Row
 ShortcutsConfigPage (QWidget *parent=nullptr)
 ShortcutsConfigPage::ShortcutsConfigPage.
 ~ShortcutsConfigPage () override
void applyConf () override
 ShortcutsConfigPage::applyConf Persist every row's shortcut edit through ShortcutManager, which also applies it immediately to every currently live QAction sharing that id.
QIcon icon () const override
Public Member Functions inherited from ConfigPage
 ConfigPage (QWidget *parent)
 ~ConfigPage () override
 Destructor.
Private Types
enum  QuickFilter { ShowAll = 0 , BoundOnly , UnboundOnly , ConflictsOnly }
Private Slots
void filterRows (const QString &filter_text)
 ShortcutsConfigPage::filterRows Re-run the combined text + quick filter whenever the search box changes.
void quickFilterChanged (int index)
 ShortcutsConfigPage::quickFilterChanged Re-run the combined text + quick filter whenever the quick filter changes.
void checkConflicts ()
 ShortcutsConfigPage::checkConflicts Highlight every row whose currently-edited sequence is shared, non-empty, with another row, and explain the conflict in the shortcut editor's tooltip.
void resetAllRows ()
void populateTable ()
 ShortcutsConfigPage::populateTable Fill the tree with one collapsible top-level node per category and one child per shortcut known to ShortcutManager, sorted by category then action name.
void applyFilter ()
 ShortcutsConfigPage::applyFilter Hide every row that doesn't match both the search box and the quick filter. The text query is split on whitespace and every term must match the category, action name or current sequence (accent- and case-insensitively). Matching category nodes are expanded so hits are not hidden inside collapsed groups, and the "N actions" label tracks how many actions remain visible.
void resetRow (int row_index)
 ShortcutsConfigPage::resetRow Reset the shortcut editor at row_index to its default sequence.
QLineEdit * m_filter_edit
QComboBox * m_quick_filter
QLabel * m_count_label
QTreeWidget * m_tree
QList< Row > m_rows
◆ QuickFilter
Enumerator
ShowAll
BoundOnly
UnboundOnly
ConflictsOnly
◆ ShortcutsConfigPage()
ShortcutsConfigPage::ShortcutsConfigPage ( QWidget * parent = nullptr)
explicit
parent
◆ ~ShortcutsConfigPage()
ShortcutsConfigPage::~ShortcutsConfigPage ( )
◆ applyConf()
void ShortcutsConfigPage::applyConf ( )
overridevirtual
Implements ConfigPage.
◆ applyFilter()
void ShortcutsConfigPage::applyFilter ( )
◆ checkConflicts
void ShortcutsConfigPage::checkConflicts ( )
privateslot
◆ filterRows
void ShortcutsConfigPage::filterRows ( const QString & filter_text)
privateslot
◆ icon()
QIcon ShortcutsConfigPage::icon ( ) const
overridevirtual
the configuration page icon
◆ populateTable()
void ShortcutsConfigPage::populateTable ( )
◆ quickFilterChanged
void ShortcutsConfigPage::quickFilterChanged ( int index)
privateslot
◆ resetAllRows
void ShortcutsConfigPage::resetAllRows ( )
privateslot
◆ resetRow()
void ShortcutsConfigPage::resetRow ( int row_index)
◆ title()
QString ShortcutsConfigPage::title ( ) const
overridevirtual
the configuration page title
◆ m_count_label
QLabel* ShortcutsConfigPage::m_count_label
◆ m_filter_edit
QLineEdit* ShortcutsConfigPage::m_filter_edit
◆ m_quick_filter
QComboBox* ShortcutsConfigPage::m_quick_filter
◆ m_rows
QList<Row> ShortcutsConfigPage::m_rows
◆ m_tree
QTreeWidget* ShortcutsConfigPage::m_tree
