diagrameventaddelement.h
1/*
14
17*/
18#ifndef DIAGRAMEVENTADDELEMENT_H
19#define DIAGRAMEVENTADDELEMENT_H
20
23
24class Element;
25class QStatusBar;
26
33{
34 Q_OBJECT
35
36 public:
37 DiagramEventAddElement(ElementsLocation &location, Diagram *diagram, QPointF pos = QPointF(0,0));
38 ~DiagramEventAddElement() override;
39
40 void mouseMoveEvent (QGraphicsSceneMouseEvent *event) override;
41 void mousePressEvent (QGraphicsSceneMouseEvent *event) override;
42 void mouseReleaseEvent (QGraphicsSceneMouseEvent *event) override;
43 void mouseDoubleClickEvent (QGraphicsSceneMouseEvent *event) override;
44 void keyPressEvent (QKeyEvent *event) override;
45 void init() override;
46
47 private:
48 bool buildElement();
49 void addElement();
50
51 private:
55 QPointer<QStatusBar> m_status_bar;
56};
57
58#endif // DIAGRAMEVENTADDELEMENT_H
QPointer< QStatusBar > m_status_bar
Definition diagrameventaddelement.h:55
Element * m_element
Definition diagrameventaddelement.h:53
bool buildElement()
DiagramEventAddElement::buildElement Build the element, if the element is build successfully,...
Definition diagrameventaddelement.cpp:204
DiagramEventAddElement::init Init this event.
Definition diagrameventaddelement.cpp:194
DiagramEventAddElement::~DiagramEventAddElement Destructor Enable context menu for each view of diagr...
Definition diagrameventaddelement.cpp:78
ElementsLocation m_location
Definition diagrameventaddelement.h:52
void mouseReleaseEvent(QGraphicsSceneMouseEvent *event) override
DiagramEventAddElement::mouseReleaseEvent Right button finish this event (isRunning = false) and emit...
Definition diagrameventaddelement.cpp:131
void mousePressEvent(QGraphicsSceneMouseEvent *event) override
DiagramEventAddElement::mousePressEvent Do nothing, but return true for not transit the event to othe...
Definition diagrameventaddelement.cpp:120
void keyPressEvent(QKeyEvent *event) override
DiagramEventAddElement::keyPressEvent Press space key rotate the element to 90° (return true) else ca...
Definition diagrameventaddelement.cpp:178
QString m_integrate_path
Definition diagrameventaddelement.h:54
void mouseMoveEvent(QGraphicsSceneMouseEvent *event) override
DiagramEventAddElement::mouseMoveEvent Move the element to new pos of mouse the event is always accep...
Definition diagrameventaddelement.cpp:100
void mouseDoubleClickEvent(QGraphicsSceneMouseEvent *event) override
DiagramEventAddElement::mouseDoubleClickEvent If mouse left double clic, finish this event (isRunning...
Definition diagrameventaddelement.cpp:158
void addElement()
DiagramEventAddElement::addElement Add an element at the current pos and current rotation,...
Definition diagrameventaddelement.cpp:232
DiagramEventAddElement(ElementsLocation &location, Diagram *diagram, QPointF pos=QPointF(0, 0))
DiagramEventAddElement::DiagramEventAddElement Defaut constructor.
Definition diagrameventaddelement.cpp:42
DiagramEventInterface(Diagram *diagram)
Definition diagrameventinterface.cpp:25
The Diagram class This class represents an electric diagram. It manages its various child elements,...
Definition diagram.h:54
Definition element.h:44
The ElementsLocation class This class represents the location, the location of an element or of a cat...
Definition elementslocation.h:47
