XRefPropertiesWidget Class Reference
The XRefPropertiesWidget class This class provide a widget to edit the XRefProperties. More...
#include <xrefpropertieswidget.h>
Inherits QWidget.
Collaboration diagram for XRefPropertiesWidget:
 XRefPropertiesWidget (QHash< QString, XRefProperties > properties=QHash< QString, XRefProperties >(), QWidget *parent=nullptr)
 XRefPropertiesWidget::XRefPropertiesWidget Default constructor.
 ~XRefPropertiesWidget () override
 XRefPropertiesWidget::~XRefPropertiesWidget Default destructor.
void setProperties (const QHash< QString, XRefProperties > &properties)
 XRefPropertiesWidget::setProperties set new properties for this widget.
QHash< QString, XRefProperties > properties ()
 XRefPropertiesWidget::properties.
void setReadOnly (bool=true)
 XRefPropertiesWidget::setReadOnly Set all of this widget disable if true.
Private Slots
void updateDisplay ()
 XRefPropertiesWidget::updateDisplay Update display with the current displayed type.
void typeChanged ()
 XRefPropertiesWidget::typeChanged manage the save of the current properties, when the combo box of type change.
void enableOffsetSB (int i)
 XRefPropertiesWidget::enableOffsetSB Enable Offset SB only if Snap to Footer is selected.
void buildUi ()
 XRefPropertiesWidget::buildUi Build some widget of this ui.
void saveProperties (int index)
 XRefPropertiesWidget::saveProperties Save the properties of the type define at index of the combo box m_type_cb.
Ui::XRefPropertiesWidget * ui
QHash< QString, XRefProperties > m_properties
int m_previous_type_index
◆ XRefPropertiesWidget()
XRefPropertiesWidget::XRefPropertiesWidget ( QHash< QString, XRefProperties > properties = QHash <QString, XRefProperties>(),
QWidget * parent = nullptr )
propertiesproperties to use
parentparent widget
◆ ~XRefPropertiesWidget()
XRefPropertiesWidget::~XRefPropertiesWidget ( )
◆ buildUi()
void XRefPropertiesWidget::buildUi ( )
◆ enableOffsetSB
void XRefPropertiesWidget::enableOffsetSB ( int i)
privateslot
◆ properties()
QHash< QString, XRefProperties > XRefPropertiesWidget::properties ( )
the properties edited by this widget
◆ saveProperties()
void XRefPropertiesWidget::saveProperties ( int index)
index
◆ setProperties()
void XRefPropertiesWidget::setProperties ( const QHash< QString, XRefProperties > & properties)
properties
◆ setReadOnly()
void XRefPropertiesWidget::setReadOnly ( bool ro = true)
ro
◆ typeChanged
void XRefPropertiesWidget::typeChanged ( )
privateslot
◆ updateDisplay
void XRefPropertiesWidget::updateDisplay ( )
privateslot
◆ m_previous_type_index
int XRefPropertiesWidget::m_previous_type_index
◆ m_properties
QHash<QString, XRefProperties> XRefPropertiesWidget::m_properties
◆ ui
Ui::XRefPropertiesWidget* XRefPropertiesWidget::ui
