LogRing Class Reference
The LogRing class Fixed-capacity, always-on in-memory ring of the most recent log lines, preallocated once at construction – append() never allocates. More...
#include <logring.h>
Collaboration diagram for LogRing:
struct  Entry
 LogRing ()
void append (const QByteArray &line) noexcept
QVector< QByteArray > snapshot () const
void dumpToFd (int fd) const noexcept
void clear ()
Static Public Attributes
static constexpr int kCapacityEntries = 4096
static constexpr int kEntryBytes = 512
std::vector< Entry > m_entries
std::atomic< quint64 > m_write_cursor {0}
Lock-free by construction, not just "thread-safe": step 4 (see crashhandler.h) reads this ring from inside a POSIX signal handler, where taking any lock is unsafe – if the crashing thread happens to be the one that already holds it (or any other thread does and never gets scheduled again), the handler hangs forever, and you lose both the ring dump and the core dump. So there is no mutex here at all: append() claims a slot with a single atomic fetch-add, and dumpToFd()/snapshot() read the preallocated entries directly.
Accepted tradeoff: if dumpToFd() runs while another thread is mid-append into the exact slot being read (only possible in the crash-handler case, and only for at most one slot), that one entry may be read torn – part old content, part new. Every other entry is unaffected. This is deliberate: the alternative (a seqlock or similar to detect and retry torn reads) adds real complexity for a window that, per discussion #644, is not worth trading "the handler must never block" against.
◆ LogRing()
LogRing::LogRing ( )
◆ append()
void LogRing::append ( const QByteArray & line)
noexcept
Append one already-formatted, already-truncated log line. Bytes beyond kEntryBytes are dropped with a truncation marker. Never allocates, never blocks. Safe to call from any normal (non-signal) thread concurrently.
◆ clear()
void LogRing::clear ( )
◆ dumpToFd()
void LogRing::dumpToFd ( int fd) const
noexcept
Async-signal-safe: writes every entry currently held to fd via write(2) only – no allocation, no Qt, no locks. May write a torn entry under the rare race described above; never blocks.
◆ snapshot()
QVector< QByteArray > LogRing::snapshot ( ) const
Snapshot of the entries currently held, oldest first. Normal (non-signal) context only.
◆ kCapacityEntries
int LogRing::kCapacityEntries = 4096
staticconstexpr
◆ kEntryBytes
int LogRing::kEntryBytes = 512
staticconstexpr
◆ m_entries
std::vector<Entry> LogRing::m_entries
◆ m_write_cursor
std::atomic<quint64> LogRing::m_write_cursor {0}
