BorderProperties Class Reference
The BorderProperties class This class is a container for dimensions and display properties of a diagram. More...
#include <borderproperties.h>
Collaboration diagram for BorderProperties:
 BorderProperties ()
 BorderProperties::BorderProperties constructor Initializes a BorderProperties object with default properties.
virtual ~BorderProperties ()
 BorderProperties::~BorderProperties destructor.
bool operator== (const BorderProperties &)
 BorderProperties::operator ==.
bool operator!= (const BorderProperties &)
 BorderProperties::operator !=.
void toXml (QDomElement &) const
 BorderProperties::toXml Exports dimensions as XML attributes added to element e.
void fromXml (QDomElement &)
 BorderProperties::fromXml Import dimensions from XML attributes of element e.
void toSettings (QSettings &, const QString &=QString()) const
 BorderProperties::toSettings Export dimensions in a QSettings object.
void fromSettings (QSettings &, const QString &=QString())
 BorderProperties::fromSettings Import dimensions from a QSettings object.
static BorderProperties defaultProperties ()
 BorderProperties::defaultProperties.
Public Attributes
int columns_count
 Columns count.
qreal columns_width
 Columns width.
qreal columns_header_height
 Column headers height.
bool display_columns
 Whether to display column headers.
int rows_count
 Rows count.
qreal rows_height
 Rows height.
qreal rows_header_width
 Row headers width.
bool display_rows
 Whether to display row headers.
Remarks
Attributes are public
◆ BorderProperties()
BorderProperties::BorderProperties ( )
Initializes a BorderProperties object with the following default properties:
  • 17 columns of 60.0 px wide by 20.0px high
  • 8 lines of 80.0 px high by 20.0px wide
◆ ~BorderProperties()
BorderProperties::~BorderProperties ( )
virtual
◆ defaultProperties()
BorderProperties BorderProperties::defaultProperties ( )
static
the default properties stored in the setting file
◆ fromSettings()
void BorderProperties::fromSettings ( QSettings & settings,
const QString & prefix = QString() )
settings: QSettings object to read
prefix: prefix to be added before the names of the parameters
◆ fromXml()
void BorderProperties::fromXml ( QDomElement & e)
e: XML element whose attributes will be read
◆ operator!=()
bool BorderProperties::operator!= ( const BorderProperties & bp)
bp: Other BorderProperties container/class.
False if it and this container are identical, true otherwise.
◆ operator==()
bool BorderProperties::operator== ( const BorderProperties & bp)
True if it and this container are identical, false otherwise.
◆ toSettings()
void BorderProperties::toSettings ( QSettings & settings,
const QString & prefix = QString() ) const
settings: QSettings object to write
◆ toXml()
void BorderProperties::toXml ( QDomElement & e) const
e: XML element to which attributes will be added
◆ columns_count
int BorderProperties::columns_count
Columns count.
◆ columns_header_height
qreal BorderProperties::columns_header_height
◆ columns_width
qreal BorderProperties::columns_width
Columns width.
◆ display_columns
bool BorderProperties::display_columns
◆ display_rows
bool BorderProperties::display_rows
◆ rows_count
int BorderProperties::rows_count
Rows count.
◆ rows_header_width
qreal BorderProperties::rows_header_width
Row headers width.
◆ rows_height
qreal BorderProperties::rows_height
Rows height.
