terminalstripeditor.h
1/*
14
17*/
18#ifndef TERMINALSTRIPEDITOR_H
19#define TERMINALSTRIPEDITOR_H
20
21#include <QWidget>
22
23#include "terminalstripmodel.h"
24
25namespace Ui {
26 class TerminalStripEditor;
27}
28
29class QETProject;
30class TerminalStrip;
31
37class TerminalStripEditor : public QWidget
38{
39 Q_OBJECT
40
41 public:
42 explicit TerminalStripEditor(QETProject *project, QWidget *parent = nullptr);
43 ~TerminalStripEditor() override;
44 void setProject(QETProject *project);
45 void setCurrentStrip(TerminalStrip *strip_);
46 void reload();
47 void apply();
48
49 private:
50 void clear();
52 void selectionChanged();
55 QPair<TerminalStripModel::Column, QVector<modelRealTerminalData>> singleColumnData() const;
56
57 private slots:
61 void on_m_level_sb_valueChanged(int arg1);
62 void on_m_type_cb_activated(int index);
63 void on_m_function_cb_activated(int index);
64 void on_m_led_cb_activated(int index);
67 void on_m_bridge_color_cb_activated(const QColor &col);
69
70 private:
71 Ui::TerminalStripEditor *ui;
72 QPointer<QETProject> m_project;
73 QPointer<TerminalStrip> m_current_strip;
75};
76
77#endif // TERMINALSTRIPEDITOR_H
Definition qetproject.h:77
TerminalStripEditor::~TerminalStripEditor.
Definition terminalstripeditor.cpp:71
void on_m_group_terminals_pb_clicked()
TerminalStripEditor::on_m_group_terminals_pb_clicked.
Definition terminalstripeditor.cpp:446
Definition terminalstripeditor.cpp:669
TerminalStripModel * m_model
Definition terminalstripeditor.h:74
TerminalStripModel::Column isSingleColumnSelected() const
TerminalStripEditor::isSingleColumnSelected If all current QModelIndex are in the same column return ...
Definition terminalstripeditor.cpp:387
Definition terminalstripeditor.cpp:524
void on_m_auto_ordering_pb_clicked()
TerminalStripEditor::on_m_auto_pos_pb_clicked.
Definition terminalstripeditor.cpp:436
void on_m_bridge_terminals_pb_clicked()
TerminalStripEditor::on_m_bridge_terminals_pb_clicked.
Definition terminalstripeditor.cpp:607
TerminalStripEditor(QETProject *project, QWidget *parent=nullptr)
TerminalStripEditor::TerminalStripEditor.
Definition terminalstripeditor.cpp:40
Definition terminalstripeditor.cpp:557
QSize setUpBridgeCellWidth()
Definition terminalstripeditor.cpp:361
Definition terminalstripeditor.cpp:586
void on_m_ungroup_pb_clicked()
TerminalStripEditor::on_m_ungroup_pb_clicked.
Definition terminalstripeditor.cpp:489
Ui::TerminalStripEditor * ui
Definition terminalstripeditor.h:71
TerminalStripEditor::selectionChanged Update the editor according to the current selection.
Definition terminalstripeditor.cpp:258
QPair< TerminalStripModel::Column, QVector< modelRealTerminalData > > singleColumnData() const
TerminalStripEditor::singleColumnData.
Definition terminalstripeditor.cpp:417
void on_m_unbridge_terminals_pb_clicked()
TerminalStripEditor::on_m_unbridge_terminals_pb_clicked.
Definition terminalstripeditor.cpp:640
void reload()
TerminalStripEditor::reload Reload this editor and and reset all unapplied change.
Definition terminalstripeditor.cpp:153
void on_m_move_to_pb_clicked()
Definition terminalstripeditor.cpp:692
TerminalStripEditor::on_m_level_sb_valueChanged.
Definition terminalstripeditor.cpp:507
Definition terminalstripeditor.cpp:75
void clear()
Definition terminalstripeditor.cpp:216
QPointer< QETProject > m_project
Definition terminalstripeditor.h:72
TerminalStripEditor::setCurrentStrip Set the current terminal strip edited to strip_.
Definition terminalstripeditor.cpp:86
void apply()
TerminalStripEditor::apply Apply current edited values.
Definition terminalstripeditor.cpp:174
void spanMultiLevelTerminals()
TerminalStripEditor::spanMultiLevelTerminals Span row of m_table_widget for multi-level terminal.
Definition terminalstripeditor.cpp:236
QPointer< TerminalStrip > m_current_strip
Definition terminalstripeditor.h:73
The TerminalStrip class This class hold all the datas and configurations of a terminal strip (but the...
Definition terminalstrip.h:45
Definition terminalstripmodel.h:53
Column
Definition terminalstripmodel.h:55
Definition autonumberingdockwidget.h:30
