xrefproperties.h
1/*
14
17*/
18#ifndef XREFPROPERTIES_H
19#define XREFPROPERTIES_H
20
21#include <QStringList>
22#include <QHash>
23
24#include "propertiesinterface.h"
25
31{
32 public:
34
39
40 enum SnapTo {
43 };
44
45 void toSettings (QSettings &settings,
46 const QString = QString()) const override;
47 void fromSettings (const QSettings &settings,
48 const QString = QString()) override;
49 QDomElement toXml (QDomDocument &xml_document) const override;
50 bool fromXml(const QDomElement &xml_element) override;
51
52 static QHash<QString, XRefProperties> defaultProperties();
53
54 bool operator == (const XRefProperties &xrp) const;
55 bool operator != (const XRefProperties &xrp) const;
56
57 void setShowPowerContac (const bool a) {m_show_power_ctc = a;}
58 bool showPowerContact () const {return m_show_power_ctc;}
59
60 void setShowTerminalName (const bool a) {m_show_terminal_name = a;}
61 bool showTerminalName () const {return m_show_terminal_name;}
62
63 void setDisplayHas (const DisplayHas dh) {m_display = dh;}
64 DisplayHas displayHas () const {return m_display;}
65
66 void setSnapTo (const SnapTo st) {m_snap_to = st;}
67 SnapTo snapTo () const {return m_snap_to;}
68
69 void setXrefPos(const Qt::AlignmentFlag xref) {m_xref_pos = xref;}
70 Qt::AlignmentFlag getXrefPos() const {return m_xref_pos;}
71 void setPrefix (const QString &key, const QString &value) {m_prefix.insert(key, value);}
72 QString prefix (const QString &key) const {return m_prefix.value(key);}
73
74 void setMasterLabel (const QString master) {m_master_label = master;}
75 QString masterLabel () const {return m_master_label;}
76
77 void setSlaveLabel(const QString slave) {m_slave_label = slave;}
78 QString slaveLabel () const {return m_slave_label;}
79
80 void setOffset(const int offset) {m_offset = offset;}
81 int offset() const {return m_offset;}
82
84 int slaveOffset() const {return m_slave_offset;}
85
86 void setKey(QString& key) {m_key = key;}
87
88 private:
93 Qt::AlignmentFlag m_xref_pos;
94 QHash <QString, QString> m_prefix;
95 QStringList m_prefix_keys;
100 QString m_key;
101};
102
103#endif // XREFPROPERTIES_H
PropertiesInterface()
PropertiesInterface::PropertiesInterface.
Definition propertiesinterface.cpp:23
The XRefProperties class this class store properties used by XrefItem.
Definition xrefproperties.h:31
static QHash< QString, XRefProperties > defaultProperties()
XRefProperties::defaultProperties.
Definition xrefproperties.cpp:181
Definition xrefproperties.h:70
QString prefix(const QString &key) const
Definition xrefproperties.h:72
int m_offset
Definition xrefproperties.h:98
SnapTo m_snap_to
Definition xrefproperties.h:92
bool operator==(const XRefProperties &xrp) const
Definition xrefproperties.cpp:200
bool m_show_power_ctc
Definition xrefproperties.h:89
DisplayHas displayHas() const
Definition xrefproperties.h:64
void setSlaveOffset(const int offset)
Definition xrefproperties.h:83
void setShowPowerContac(const bool a)
Definition xrefproperties.h:57
void setMasterLabel(const QString master)
Definition xrefproperties.h:74
bool showTerminalName() const
Definition xrefproperties.h:61
SnapTo snapTo() const
Definition xrefproperties.h:67
Definition xrefproperties.h:80
void setPrefix(const QString &key, const QString &value)
Definition xrefproperties.h:71
QString masterLabel() const
Definition xrefproperties.h:75
QString m_master_label
Definition xrefproperties.h:96
Definition xrefproperties.h:93
void toSettings(QSettings &settings, const QString=QString()) const override
XRefProperties::toSettings Save to settings.
Definition xrefproperties.cpp:49
QString m_slave_label
Definition xrefproperties.h:97
SnapTo
Definition xrefproperties.h:40
@ Label
Definition xrefproperties.h:42
@ Bottom
Definition xrefproperties.h:41
bool operator!=(const XRefProperties &xrp) const
Definition xrefproperties.cpp:213
bool showPowerContact() const
Definition xrefproperties.h:58
QHash< QString, QString > m_prefix
Definition xrefproperties.h:94
int m_slave_offset
Definition xrefproperties.h:99
XRefProperties::fromXml Load from xml.
Definition xrefproperties.cpp:147
void fromSettings(const QSettings &settings, const QString=QString()) override
XRefProperties::fromSettings load from settings.
Definition xrefproperties.cpp:82
void setSnapTo(const SnapTo st)
Definition xrefproperties.h:66
QString m_key
Definition xrefproperties.h:100
void setDisplayHas(const DisplayHas dh)
Definition xrefproperties.h:63
DisplayHas m_display
Definition xrefproperties.h:91
void setShowTerminalName(const bool a)
Definition xrefproperties.h:60
QDomElement toXml(QDomDocument &xml_document) const override
XRefProperties::toXml Save to xml.
Definition xrefproperties.cpp:110
DisplayHas
Definition xrefproperties.h:35
@ Cross
Definition xrefproperties.h:36
@ Contacts
Definition xrefproperties.h:37
Definition xrefproperties.h:77
QString slaveLabel() const
Definition xrefproperties.h:78
Definition xrefproperties.h:69
Definition xrefproperties.h:95
int offset() const
Definition xrefproperties.h:81
XRefProperties()
XRefProperties::XRefProperties Default Constructor.
Definition xrefproperties.cpp:29
bool m_show_terminal_name
Definition xrefproperties.h:90
void setKey(QString &key)
Definition xrefproperties.h:86
Definition xrefproperties.h:84
