4#ifndef ZIP7_INC_CPU_ARCH_H
5#define ZIP7_INC_CPU_ARCH_H
24 || defined(_M_AMD64) \
25 || defined(__x86_64__) \
26 || defined(__AMD64__) \
30 #define MY_CPU_NAME "x32"
31 #define MY_CPU_SIZEOF_POINTER 4
33 #define MY_CPU_NAME "x64"
34 #define MY_CPU_SIZEOF_POINTER 8
43 #define MY_CPU_NAME "x86"
45 #define MY_CPU_SIZEOF_POINTER 4
49#if defined(_M_ARM64) \
50 || defined(__AARCH64EL__) \
51 || defined(__AARCH64EB__) \
52 || defined(__aarch64__)
55 #define MY_CPU_NAME "arm64-32"
56 #define MY_CPU_SIZEOF_POINTER 4
58 #define MY_CPU_NAME "arm64"
59 #define MY_CPU_SIZEOF_POINTER 8
66 || defined(_M_ARM_NT) \
69 || defined(__thumb__) \
70 || defined(__ARMEL__) \
71 || defined(__ARMEB__) \
72 || defined(__THUMBEL__) \
73 || defined(__THUMBEB__)
76 #if defined(__thumb__) || defined(__THUMBEL__) || defined(_M_ARMT)
78 #define MY_CPU_NAME "armt"
81 #define MY_CPU_NAME "arm"
84 #define MY_CPU_SIZEOF_POINTER 4
91 #define MY_CPU_NAME "ia64"
96#if defined(__mips64) \
97 || defined(__mips64__) \
98 || (defined(__mips) && (__mips == 64 || __mips == 4 || __mips == 3))
99 #define MY_CPU_NAME "mips64"
101#elif defined(__mips__)
102 #define MY_CPU_NAME "mips"
107#if defined(__ppc64__) \
108 || defined(__powerpc64__) \
109 || defined(__ppc__) \
110 || defined(__powerpc__) \
111 || defined(__PPC__) \
114#define MY_CPU_PPC_OR_PPC64
116#if defined(__ppc64__) \
117 || defined(__powerpc64__) \
119 || defined(__64BIT__)
121 #define MY_CPU_NAME "ppc64-32"
122 #define MY_CPU_SIZEOF_POINTER 4
124 #define MY_CPU_NAME "ppc64"
125 #define MY_CPU_SIZEOF_POINTER 8
129 #define MY_CPU_NAME "ppc"
130 #define MY_CPU_SIZEOF_POINTER 4
136#if defined(__riscv) \
137 || defined(__riscv__)
138 #if __riscv_xlen == 32
139 #define MY_CPU_NAME "riscv32"
140 #elif __riscv_xlen == 64
141 #define MY_CPU_NAME "riscv64"
143 #define MY_CPU_NAME "riscv"
148#if defined(MY_CPU_X86) || defined(MY_CPU_AMD64)
149#define MY_CPU_X86_OR_AMD64
152#if defined(MY_CPU_ARM) || defined(MY_CPU_ARM64)
153#define MY_CPU_ARM_OR_ARM64
160 #define MY_CPU_ARM_LE
164 #define MY_CPU_ARM64_LE
168 #define MY_CPU_IA64_LE
174#if defined(MY_CPU_X86_OR_AMD64) \
175 || defined(MY_CPU_ARM_LE) \
176 || defined(MY_CPU_ARM64_LE) \
177 || defined(MY_CPU_IA64_LE) \
178 || defined(__LITTLE_ENDIAN__) \
179 || defined(__ARMEL__) \
180 || defined(__THUMBEL__) \
181 || defined(__AARCH64EL__) \
182 || defined(__MIPSEL__) \
183 || defined(__MIPSEL) \
184 || defined(_MIPSEL) \
185 || defined(__BFIN__) \
186 || (defined(__BYTE_ORDER__) && (__BYTE_ORDER__ == __ORDER_LITTLE_ENDIAN__))
190#if defined(__BIG_ENDIAN__) \
191 || defined(__ARMEB__) \
192 || defined(__THUMBEB__) \
193 || defined(__AARCH64EB__) \
194 || defined(__MIPSEB__) \
195 || defined(__MIPSEB) \
196 || defined(_MIPSEB) \
197 || defined(__m68k__) \
198 || defined(__s390__) \
199 || defined(__s390x__) \
200 || defined(__zarch__) \
201 || (defined(__BYTE_ORDER__) && (__BYTE_ORDER__ == __ORDER_BIG_ENDIAN__))
206#if defined(MY_CPU_LE) && defined(MY_CPU_BE)
207 #error Stop_Compiling_Bad_Endian
210#if !defined(MY_CPU_LE) && !defined(MY_CPU_BE)
211 #error Stop_Compiling_CPU_ENDIAN_must_be_detected_at_compile_time
214#if defined(MY_CPU_32BIT) && defined(MY_CPU_64BIT)
215 #error Stop_Compiling_Bad_32_64_BIT
218#ifdef __SIZEOF_POINTER__
219 #ifdef MY_CPU_SIZEOF_POINTER
220 #if MY_CPU_SIZEOF_POINTER != __SIZEOF_POINTER__
221 #error Stop_Compiling_Bad_MY_CPU_PTR_SIZE
224 #define MY_CPU_SIZEOF_POINTER __SIZEOF_POINTER__
228#if defined(MY_CPU_SIZEOF_POINTER) && (MY_CPU_SIZEOF_POINTER == 4)
230 #error Stop_Compiling_Bad_MY_CPU_PTR_SIZE
236 #define MY_CPU_pragma_pack_push_1 __pragma(pack(push, 1))
237 #define MY_CPU_pragma_pop __pragma(pack(pop))
239 #define MY_CPU_pragma_pack_push_1
240 #define MY_CPU_pragma_pop
244 #define MY_CPU_pragma_pack_push_1 _Pragma("pack(1)")
245 #define MY_CPU_pragma_pop _Pragma("pack()")
247 #define MY_CPU_pragma_pack_push_1 _Pragma("pack(push, 1)")
248 #define MY_CPU_pragma_pop _Pragma("pack(pop)")
255 #define MY_CPU_NAME "LE"
256 #elif defined(MY_CPU_BE)
257 #define MY_CPU_NAME "BE"
270 #define Z7_has_builtin(x) __has_builtin(x)
272 #define Z7_has_builtin(x) 0
276#define Z7_BSWAP32_CONST(v) \
277 ( (((UInt32)(v) << 24) ) \
278 | (((UInt32)(v) << 8) & (UInt32)0xff0000) \
279 | (((UInt32)(v) >> 8) & (UInt32)0xff00 ) \
280 | (((UInt32)(v) >> 24) ))
283#if defined(_MSC_VER) && (_MSC_VER >= 1300)
289#pragma intrinsic(_byteswap_ushort)
290#pragma intrinsic(_byteswap_ulong)
291#pragma intrinsic(_byteswap_uint64)
293#define Z7_BSWAP16(v) _byteswap_ushort(v)
294#define Z7_BSWAP32(v) _byteswap_ulong (v)
295#define Z7_BSWAP64(v) _byteswap_uint64(v)
296#define Z7_CPU_FAST_BSWAP_SUPPORTED
298#elif (defined(__GNUC__) && (__GNUC__ > 4 || (__GNUC__ == 4 && __GNUC_MINOR__ >= 3))) \
299 || (defined(__clang__) && Z7_has_builtin(__builtin_bswap16))
301#define Z7_BSWAP16(v) __builtin_bswap16(v)
302#define Z7_BSWAP32(v) __builtin_bswap32(v)
303#define Z7_BSWAP64(v) __builtin_bswap64(v)
304#define Z7_CPU_FAST_BSWAP_SUPPORTED
308#define Z7_BSWAP16(v) ((UInt16) \
309 ( ((UInt32)(v) << 8) \
310 | ((UInt32)(v) >> 8) \
313#define Z7_BSWAP32(v) Z7_BSWAP32_CONST(v)
315#define Z7_BSWAP64(v) \
316 ( ( ( (UInt64)(v) ) << 8 * 7 ) \
317 | ( ( (UInt64)(v) & ((UInt32)0xff << 8 * 1) ) << 8 * 5 ) \
318 | ( ( (UInt64)(v) & ((UInt32)0xff << 8 * 2) ) << 8 * 3 ) \
319 | ( ( (UInt64)(v) & ((UInt32)0xff << 8 * 3) ) << 8 * 1 ) \
320 | ( ( (UInt64)(v) >> 8 * 1 ) & ((UInt32)0xff << 8 * 3) ) \
321 | ( ( (UInt64)(v) >> 8 * 3 ) & ((UInt32)0xff << 8 * 2) ) \
322 | ( ( (UInt64)(v) >> 8 * 5 ) & ((UInt32)0xff << 8 * 1) ) \
323 | ( ( (UInt64)(v) >> 8 * 7 ) ) \
331 #if defined(MY_CPU_X86_OR_AMD64) \
332 || defined(MY_CPU_ARM64)
333 #define MY_CPU_LE_UNALIGN
334 #define MY_CPU_LE_UNALIGN_64
335 #elif defined(__ARM_FEATURE_UNALIGNED)
338 #define MY_CPU_LE_UNALIGN
343#ifdef MY_CPU_LE_UNALIGN
345#define GetUi16(p) (*(const UInt16 *)(const void *)(p))
346#define GetUi32(p) (*(const UInt32 *)(const void *)(p))
347#ifdef MY_CPU_LE_UNALIGN_64
348#define GetUi64(p) (*(const UInt64 *)(const void *)(p))
349#define SetUi64(p, v) { *(UInt64 *)(void *)(p) = (v); }
352#define SetUi16(p, v) { *(UInt16 *)(void *)(p) = (v); }
353#define SetUi32(p, v) { *(UInt32 *)(void *)(p) = (v); }
357#define GetUi16(p) ( (UInt16) ( \
358 ((const Byte *)(p))[0] | \
359 ((UInt16)((const Byte *)(p))[1] << 8) ))
361#define GetUi32(p) ( \
362 ((const Byte *)(p))[0] | \
363 ((UInt32)((const Byte *)(p))[1] << 8) | \
364 ((UInt32)((const Byte *)(p))[2] << 16) | \
365 ((UInt32)((const Byte *)(p))[3] << 24))
367#define SetUi16(p, v) { Byte *_ppp_ = (Byte *)(p); UInt32 _vvv_ = (v); \
368 _ppp_[0] = (Byte)_vvv_; \
369 _ppp_[1] = (Byte)(_vvv_ >> 8); }
371#define SetUi32(p, v) { Byte *_ppp_ = (Byte *)(p); UInt32 _vvv_ = (v); \
372 _ppp_[0] = (Byte)_vvv_; \
373 _ppp_[1] = (Byte)(_vvv_ >> 8); \
374 _ppp_[2] = (Byte)(_vvv_ >> 16); \
375 _ppp_[3] = (Byte)(_vvv_ >> 24); }
381#define GetUi64(p) (GetUi32(p) | ((UInt64)GetUi32(((const Byte *)(p)) + 4) << 32))
385#define SetUi64(p, v) { Byte *_ppp2_ = (Byte *)(p); UInt64 _vvv2_ = (v); \
386 SetUi32(_ppp2_ , (UInt32)_vvv2_) \
387 SetUi32(_ppp2_ + 4, (UInt32)(_vvv2_ >> 32)) }
391#if defined(MY_CPU_LE_UNALIGN) && defined(Z7_CPU_FAST_BSWAP_SUPPORTED)
393#define GetBe32(p) Z7_BSWAP32 (*(const UInt32 *)(const void *)(p))
394#define SetBe32(p, v) { (*(UInt32 *)(void *)(p)) = Z7_BSWAP32(v); }
396#if defined(MY_CPU_LE_UNALIGN_64)
397#define GetBe64(p) Z7_BSWAP64 (*(const UInt64 *)(const void *)(p))
402#define GetBe32(p) ( \
403 ((UInt32)((const Byte *)(p))[0] << 24) | \
404 ((UInt32)((const Byte *)(p))[1] << 16) | \
405 ((UInt32)((const Byte *)(p))[2] << 8) | \
406 ((const Byte *)(p))[3] )
408#define SetBe32(p, v) { Byte *_ppp_ = (Byte *)(p); UInt32 _vvv_ = (v); \
409 _ppp_[0] = (Byte)(_vvv_ >> 24); \
410 _ppp_[1] = (Byte)(_vvv_ >> 16); \
411 _ppp_[2] = (Byte)(_vvv_ >> 8); \
412 _ppp_[3] = (Byte)_vvv_; }
417#define GetBe64(p) (((UInt64)GetBe32(p) << 32) | GetBe32(((const Byte *)(p)) + 4))
421#define GetBe16(p) ( (UInt16) ( \
422 ((UInt16)((const Byte *)(p))[0] << 8) | \
423 ((const Byte *)(p))[1] ))
427#if defined(MY_CPU_BE)
428#define Z7_CONV_BE_TO_NATIVE_CONST32(v) (v)
429#define Z7_CONV_LE_TO_NATIVE_CONST32(v) Z7_BSWAP32_CONST(v)
430#define Z7_CONV_NATIVE_TO_BE_32(v) (v)
431#elif defined(MY_CPU_LE)
432#define Z7_CONV_BE_TO_NATIVE_CONST32(v) Z7_BSWAP32_CONST(v)
433#define Z7_CONV_LE_TO_NATIVE_CONST32(v) (v)
434#define Z7_CONV_NATIVE_TO_BE_32(v) Z7_BSWAP32(v)
436#error Stop_Compiling_Unknown_Endian_CONV
440#if defined(MY_CPU_BE)
442#define GetBe32a(p) (*(const UInt32 *)(const void *)(p))
443#define GetBe16a(p) (*(const UInt16 *)(const void *)(p))
444#define SetBe32a(p, v) { *(UInt32 *)(void *)(p) = (v); }
445#define SetBe16a(p, v) { *(UInt16 *)(void *)(p) = (v); }
447#define GetUi32a(p) GetUi32(p)
448#define GetUi16a(p) GetUi16(p)
449#define SetUi32a(p, v) SetUi32(p, v)
450#define SetUi16a(p, v) SetUi16(p, v)
452#elif defined(MY_CPU_LE)
454#define GetUi32a(p) (*(const UInt32 *)(const void *)(p))
455#define GetUi16a(p) (*(const UInt16 *)(const void *)(p))
456#define SetUi32a(p, v) { *(UInt32 *)(void *)(p) = (v); }
457#define SetUi16a(p, v) { *(UInt16 *)(void *)(p) = (v); }
459#define GetBe32a(p) GetBe32(p)
460#define GetBe16a(p) GetBe16(p)
461#define SetBe32a(p, v) SetBe32(p, v)
462#define SetBe16a(p, v) SetBe16(p, v)
465#error Stop_Compiling_Unknown_Endian_CPU_a
469#if defined(MY_CPU_X86_OR_AMD64) \
470 || defined(MY_CPU_ARM_OR_ARM64) \
471 || defined(MY_CPU_PPC_OR_PPC64)
472 #define Z7_CPU_FAST_ROTATE_SUPPORTED
476#ifdef MY_CPU_X86_OR_AMD64
480#if defined(MY_CPU_AMD64)
481#define Z7_IF_X86_CPUID_SUPPORTED
483#define Z7_IF_X86_CPUID_SUPPORTED if (z7_x86_cpuid_GetMaxFunc())
486BoolInt CPU_IsSupported_AES(
void);
487BoolInt CPU_IsSupported_AVX(
void);
488BoolInt CPU_IsSupported_AVX2(
void);
489BoolInt CPU_IsSupported_VAES_AVX2(
void);
490BoolInt CPU_IsSupported_CMOV(
void);
491BoolInt CPU_IsSupported_SSE(
void);
492BoolInt CPU_IsSupported_SSE2(
void);
493BoolInt CPU_IsSupported_SSSE3(
void);
494BoolInt CPU_IsSupported_SSE41(
void);
495BoolInt CPU_IsSupported_SHA(
void);
496BoolInt CPU_IsSupported_PageGB(
void);
498#elif defined(MY_CPU_ARM_OR_ARM64)
500BoolInt CPU_IsSupported_CRC32(
void);
501BoolInt CPU_IsSupported_NEON(
void);
504BoolInt CPU_IsSupported_CRYPTO(
void);
505#define CPU_IsSupported_SHA1 CPU_IsSupported_CRYPTO
506#define CPU_IsSupported_SHA2 CPU_IsSupported_CRYPTO
507#define CPU_IsSupported_AES CPU_IsSupported_CRYPTO
509BoolInt CPU_IsSupported_SHA1(
void);
510BoolInt CPU_IsSupported_SHA2(
void);
511BoolInt CPU_IsSupported_AES(
void);
516#if defined(__APPLE__)
517int z7_sysctlbyname_Get(
const char *name,
void *buf,
size_t *bufSize);
518int z7_sysctlbyname_Get_UInt32(
const char *name,
UInt32 *val);
int BoolInt
Definition 7zTypes.h:259
unsigned int UInt32
Definition 7zTypes.h:180
#define EXTERN_C_BEGIN
Definition 7zTypes.h:20
#define Z7_FASTCALL
Definition 7zTypes.h:308
#define EXTERN_C_END
Definition 7zTypes.h:21
