18#ifndef XMLELEMENTCOLLECTION_H
19#define XMLELEMENTCOLLECTION_H
41 QDomElement
root()
const;
43 QDomNodeList
childs(
const QDomElement &parent_element)
const;
44 QDomElement
child(
const QDomElement &parent_element,
45 const QString &child_name)
const;
46 QDomElement
child(
const QString &path)
const;
48 const QDomElement &parent_element)
const;
50 const QDomElement &parent_element)
const;
52 const QDomElement &parent_element)
const;
54 const QDomElement &parent_element)
const;
55 QDomElement
element(
const;
56 QDomElement
directory(
const;
59 const QString &elmt_name,
60 const QDomElement &xml_definition);
64 const QString& rename = QString(),
65 bool deep_copy =
true);
66 bool exist (
const;
73 QDomElement dom_element = QDomElement(),
84 const QString& rename = QString(),
85 bool deep_copy =
true);
88 const QString& rename = QString());
The ElementsLocation class This class represents the location, the location of an element or of a cat...
Definition elementslocation.h:47
Definition nameslist.h:37
Definition qetproject.h:77
QList< QDomElement > directories(const QDomElement &parent_element) const
XmlElementCollection::directories.
Definition xmlelementcollection.cpp:236
QDomElement directory(const QString &path) const
XmlElementCollection::directory.
Definition xmlelementcollection.cpp:342
bool removeDir(const QString &path)
XmlElementCollection::removeDir Remove the directory at path path.
Definition xmlelementcollection.cpp:654
ElementsLocation copyElement(ElementsLocation &source, ElementsLocation &destination, const QString &rename=QString())
XmlElementCollection::copyElement Copy the element represented by source to destination (must be a di...
Definition xmlelementcollection.cpp:884
QString addElement(ElementsLocation &location)
XmlElementCollection::addElement Add the element at location to this collection. The element is copie...
Definition xmlelementcollection.cpp:366
bool removeElement(const QString &path)
XmlElementCollection::removeElement Remove the element at path path.
Definition xmlelementcollection.cpp:549
void cleanUnusedDirectory()
XmlElementCollection::cleanUnusedDirectory Remove the empty directories of this collection.
Definition xmlelementcollection.cpp:754
XmlElementCollection(QETProject *project)
XmlElementCollection::XmlElementCollection Build an empty collection. The collection start by :
Definition xmlelementcollection.cpp:37
QDomElement child(const QDomElement &parent_element, const QString &child_name) const
XmlElementCollection::child If parent_element have child element with an attribute name = child_name,...
Definition xmlelementcollection.cpp:182
QList< QDomElement > elements(const QDomElement &parent_element) const
XmlElementCollection::elements.
Definition xmlelementcollection.cpp:280
ElementsLocation copy(ElementsLocation &source, ElementsLocation &destination, const QString &rename=QString(), bool deep_copy=true)
XmlElementCollection::copy Copy the content represented by source (an element or a directory) to dest...
Definition xmlelementcollection.cpp:578
QStringList directoriesNames(const QDomElement &parent_element) const
XmlElementCollection::directoriesNames.
Definition xmlelementcollection.cpp:259
void elementRemoved(QString collection_path)
elementRemoved This signal is emitted when an element is removed from this collection
bool exist(const QString &path) const
XmlElementCollection::exist Return true if the path path exist in this collection.
Definition xmlelementcollection.cpp:602
QDomDocument m_dom_document
Definition xmlelementcollection.h:123
ElementsLocation copyDirectory(ElementsLocation &source, ElementsLocation &destination, const QString &rename=QString(), bool deep_copy=true)
XmlElementCollection::copyDirectory Copy the directory represented by source to destination....
Definition xmlelementcollection.cpp:782
bool createDir(const QString &path, const QString &name, const NamesList &name_list)
XmlElementCollection::createDir Create a child directory at path path with the name name....
Definition xmlelementcollection.cpp:620
ElementsLocation domToLocation(QDomElement dom_element) const
XmlElementCollection::domToLocation Return the element location who represent the xml element : dom_e...
Definition xmlelementcollection.cpp:720
void cleanUnusedElement()
XmlElementCollection::cleanUnusedElement Remove elements in this collection which is not used in the ...
Definition xmlelementcollection.cpp:744
QList< ElementsLocation > elementsLocation(QDomElement dom_element=QDomElement(), bool childs=true) const
XmlElementCollection::elementsLocation Return all locations stored in dom_element (element and direct...
Definition xmlelementcollection.cpp:675
QDomNodeList childs(const QDomElement &parent_element) const
XmlElementCollection::childs.
Definition xmlelementcollection.cpp:162
void elementChanged(QString collection_path)
elementChanged This signal is emitted when the definition of the element at path was changed
void directoryRemoved(QString collection_path)
directoryRemoved This signal is emitted when a directory is removed from this collection
QDomElement element(const QString &path) const
XmlElementCollection::element.
Definition xmlelementcollection.cpp:324
bool addElementDefinition(const QString &dir_path, const QString &elmt_name, const QDomElement &xml_definition)
XmlElementCollection::addElementDefinition Add the element definition xml_definition in the directory...
Definition xmlelementcollection.cpp:510
void directorieAdded(QString collection_path)
directorieAdded This signal is emitted when a directory is added to this collection
QETProject * m_project
Definition xmlelementcollection.h:124
QDomElement root() const
XmlElementCollection::root The root is the first DOM-Element the xml collection, the tag name of the ...
Definition xmlelementcollection.cpp:142
QStringList elementsNames(const QDomElement &parent_element) const
XmlElementCollection::elementsNames.
Definition xmlelementcollection.cpp:302
void elementAdded(QString collection_path)
elementAdded This signal is emitted when a element is added to this collection
QDomElement importCategory() const
XmlElementCollection::importCategory.
Definition xmlelementcollection.cpp:152
